CPU-Z 1.53.2
-fix bug version
-released 05.02.2010
CPU-Z 1.53.2
-fix bug version
thanks...i'm on 1.53.1 atm
I noticed :)
Yesterday CPU-Z went crazy :eek:
http://img695.imageshack.us/img695/4107/denebloll.png
1.53.2 still not recognizing the CPU VID or the real core voltage :(
http://img686.imageshack.us/img686/497/cpuz1532.png
By the way it's still a very useful app :up:
hey stasio do you know if they can fix the memory tab bug with i3's,if you set cas8 in bios it reads 10 in cpuz.
@Statio: any chance you can get the developers to look into the CL reading when using Clarkdale processors? Once you change the the base clock, CPU-Z will report something else for the CL value.
Cheers....
Maybe this week Franck will release 1.53.3:shrug:
1.53.2 are already removed for dl (from official link).
let hope.thanks stasio
Thanks Stasio.....
Concerning the CAS issue, could you please send a TXT report to cpuz (at) cpuid (dot) com ?
thanks.
Sent. Thanks! :up:Quote:
thanks.
been trying different versions to see if any would report the correct cas latency
and version 1.52.4 seems to get it right.so does 1.52.3
http://i45.tinypic.com/30b1ppz.jpg
Looking good there. Hope they release it to the public soon. The official site still has 1.53.1 :up:Quote:
these are old versions 1.52 not 1.53.
its strange that these older versions
get the cas right?
Thanks for info,radaja.:D
Btw,older CPU-Z version,can be dl here
no problem.looks like cpuz 1.52.2 from your link works too:D
1.52 doesnt show frequency or ratio,so stick with 1.52.2
and higher till they release a newer version for clarkies
@radaja: thanks for that. I need more coffee. :D Didn't pay attention to the versions.
cpuz made a small fix for this already, but the build is still 1.53.2 in the test file he sent. just waiting for them to make this official though.
CPU-Z 1.53.2 - updated
-fix CAS reading for Clarkdale
-released 15.02.2010
This is internal beta version and without validation.
Guys,feedback please!
working good here.i set 8-8-8-24 in bios and
cpuz 1.53.2-updated version shows the same
http://i47.tinypic.com/2cegtfk.jpg
Any CPU-Z 1.53.3 that reads the revision on an Q4EG Gulftown? 1.53.1 and 1.53.2 can't see it.
O very nice thx
Cpu-z 1.53.4
http://www.fileuploadx.de/646124
Thanks Fire4Wire,here is direct links:
http://www.cpuid.com/download/cpuz/cpuz_153_4.zip
or
http://www.fileden.com/files/2009/12...cpuz_153_4.zip
Thanks! Real Vcore is back!! :clap:
http://img687.imageshack.us/img687/9923/cpuz153401.png http://img13.imageshack.us/img13/9287/cpuz153402.png
:up:
@Stasio: is there any 64bit build for this version?
no 64bit version
thanks stasio
waiting for Valid option :(
The beta ones fixed the CL issue on i3 systems
But still no validation :shrug:
CPU-Z 1.54 -32bit
CPU-Z 1.54 -64bit
* Intel Core i7-880, Core i5-680, Core i3-550 processors.
* Intel Xeon 5600 line (32nm) processors.
* AMD Phenom II X6, Sempron II, Turion II, Turion II Ultra and Athlon II Mobile "Caspian" processors.
* NVIDIA GeForce 320M chipset.
* AMD 870/880G/890GX + SB800/SB850 chipset.
* Introduction of validation rooms.
Thanks for the update stasio!
Updated 30.March,links same.
CPU-Z 1.54.2 Beta
http://www.fileden.com/files/2009/12...-Z%20154.2.zip
From Franck:
The new release of CPU-Z 1.55 is planned for the 9th of July. Please note that the validation with version 1.54 will be disabled in the same time, so please record your validations now !
so when 1.55 is out we can validate with that right?
CPU-Z 1.55
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.55-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.55-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.55-64bits-en.zip
- VIA VX900/VX900M and VN1000/VN1000M chipsets.
- Intel Core i5-760, Core i7-875K and Core i5-655K processors.
- Intel Core i7-940XM, 840QM, 740QM mobile processors.
- Intel Core i5-450M, 540UM, 430UM, Core i3-370M mobile processors.
- Intel Pentium P6000 processor.
- New parameter in cpuz.ini : UseDisplayAPI
South bridge evolution:
http://img514.imageshack.us/img514/9404/cpuzevo.png
I know that hardware is ageing fast, but this :eek: :D
sweet thanks stasio :)
can i get support for my x5690s?
http://img.techpowerup.org/100813/Capture300.jpg
hi guys !
I uploaded a beta version. It does fix several things, and adds support for Sandy Bridge (at least, partially).
http://www.cpuid.com/medias/files/so..._1552_beta.zip
Any input is welcome !
thanks
CPU-Z 1.56
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.56-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.56-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.56-64bits-en.zip
- Intel Core i3/i5/i7 "2000" serie processors (Sandy Bridge) with new logos.
- Intel Core i7 970 "Gulftown".
- Intel P67 chipset.
- AMD Phenom II, Athlon II and Sempron II "Caspian" processors.
Seams the have a core-voltage bug, at least the cpu-z_1.56-64bits-en.zip on my ES-chips.
http://img.techpowerup.org/101026/Capture040.jpg
24v on Core
http://10pix.ru/img1/2120/2623599.th.jpg
Hum indeed a nice one.
Can you please send the TXT reports to cpuz[a]cpuid[dot]com ?
thanks.
with the new cpuz 1.56 version from 23.45 o clock the field is grey
look
http://www.abload.de/img/zwischenablage01xhvf.jpg
dump sended
Got it, thanks.
I think I fixed the problem.
So another "glitch", but that time it was made on purpose : in that version I had to remove the VCORE report on ROG mainboards (as yours Fire4Wire).
This is of course temporary, we had to do that because the concurrent accesses to the ROG chips caused troubles. We work on a fix with Asus, and I will release a sub-version just to restore support for ROG (and that time a clean one).
thx can you send me the fixed version to my email adress when you finished it pls
the funny thing is that 1.55 reads my vcore correct
http://www.abload.de/img/zwischenablage01ugqq.jpg
1.56 doesnt
any news ranck
new beta for rog bords
and where is the cpuz forum
link?
CPU-Z 1.56 -update 18.12.2010
CPU-Z 1.56 -update 26.12.2010
https://dl.dropbox.com/u/4668167/cpuz%201.56.zip
System information tool CPU-Z has received a new update to get full support for Intel's incoming Sandy Bridge processors and the flagship P67 chipset. The 1.56 release also adds Core i7-970 support and improved Phenom II, Athlon II and Sempron II recognition.
CPUID Reviewer Kit for Intel Sandy Bridge
http://www.cpuid.com/medias/files/so...viewer_Kit.zip
For all who will review the new Intel Sandy Brige processor line, we've released a kit that includes some of our tools, plus a version of AIDA64, all updated for the new processor line.
The kit includes :
- CPU-Z 1.56.1
- HWMonitor 1.17.1
- TMonitor 1.03.1
- AIDA64 Extreme Edition 1.50.1200
Noticeable features are :
- Sandy Bridge cores temperature and power meter (HWMonitor)
- Improved clock report (CPU-Z)
- Turbo activation / remove (TMonitor)
- Support for UEFI BIOSes (all)
- AVX accelerated benchmarsk (AIDA64)
CPU-Z 1.56.1
-update 02.Jan 11
http://www.fileden.com/files/2009/12...uz%20156.1.zip
CPU-Z 1.56.2 Beta
http://www.fileden.com/files/2010/4/...uz1562beta.zip
CPU-Z 1.56.3 Beta
http://www.fileden.com/files/2010/4/.../cpuz_1563.zip
Thanks Franck and :bday:
CPU-Z 1.56.3 Beta
http://www.filehorse.com/download-cpuz/download/
-add Max TDP
-25.Jan 11
When i launch cpuz.exe (1.56.3) there's loading screen and after a while the file disappear from hdd and nothing happens.
Downloaded from different sources, 1.56.2 works perfect.
Wtfx?
ath > check your pm please.
ROG CPU-Z 1.57.1
http://www.cpuid.com/medias/files/so...asus_setup.exe
Asus and CPUID are glad to offer you a version of the CPU-Z utility with the ROG look and feel. We hope that you will appreciate that very special version of CPU-Z.
this works for my asus p5e :D
thanks stasio
CPU-Z 1.56.4 Beta
http://www.fileden.com/files/2009/12.../cpuz_1564.zip
CPU-Z 1.57
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-64bits-en.zip
* Intel Xeon "Westmere-EX" support
* GPU frequency report on Intel Sandy Bridge processor
* AMD Zacate/Ontario processors support
* Report TDP on main page when available
* Cores clocks on floating menu
* P67/H67 stepping report
CPU-Z 1.57.2 -for Asus
ftp://ftp.asus.com.tw/pub/ASUS/misc/...asus_setup.zip
My Dr.Web 6.0 ant-virus software detects a virus in the setup file.
http://img818.imageshack.us/img818/706/virusdk.png
Uploaded with ImageShack.us
CPU-Z 1.57.1
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57.1-setup-en.exe
-fix bug for Gigabyte B3 boards.
-added"Dual Channels" notification
CPU-Z 1.57.1-updated 20.04.2011
http://dl.dropbox.com/u/4668167/cpuz_1.57.1.zip
did anyone know wehen cpuz 1.58 will be released??
CPU-Z 1.58 Beta
http://www.fileden.com/files/2010/4/...-32bits-en.zip
- AMD FX "Bulldozer" processors family.
- Intel Sandy Bridge-EP processors preliminary support.
Edit:
Still bug ,
show VTT voltage on Gigabyte Z68X-UD7 (maybe new BIOS?).
http://i7.aijaa.com/b/00304/8229568.png
No x64 version?
CPU-Z 1.58
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-64bits-en.zip
- AMD FX "Bulldozer" processors family (K15).
- AMD Llano processors family (K12).
nice, thanks stasio
Thanks for 1.58 x64 :up:
Hey great. Thanks Stasio....
thx man!
CPU-Z 1.58 -Updated 28.June 2011
Attachment 116859
error?
thx for keeping it up-to-date :yepp:
CPU-Z 1.58 -ASUS
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.58-asus-setup-en.exe
Is anyone else getting the cpu-z rog 1.58 not reading the voltage? As 1.57 reads it fine under the cpu-z rog.
So i'm the only one with 1.58 showing no voltage readings in their cpu-z? Funny thing is my 1.57 worked fine but after i uninstalled 1.58 and went back it is now blank also.
Hey Statio, thanks...
CPU-Z 1.58.6 Beta
Edit:
GA-Z68X-UD7........OK.
http://i8.aijaa.com/b/00249/8829912.png
does this for bulldozer update?
The Bulldozer reviewer kit is available at CPUID.COM right now.
thanx mista legend for the kit :)
