Newbie needs distill water + killcoil + dye help
Hi
I never tried watercooling before and I need help from the members regarding the coolant I should use.
After reading about pre mixed coolant, I got bit cautious about using them. I am leave-and-forget kinda guy except when I need to change them on yearly or 6 monthly basis.
It seems like distill water and killcoil are best solution for water cooling. But I want color liquid and do not want to use color tubes and also not interested in uv stuff.
Which dye do you recommend? Only side effect is the components are stained which doesn't matter as I'm not planning to change colors everynow and then.
I have seen accumulation of gluey stuff on the components but isn't due to glycol stuff the members used and it is not dye's fault. Please do correct me if I'm wrong.
