Passo is new to XS and speaks only Italian. Can someone help him with finding info on his card. I am assuming he wants Volt mods.Quote:
ciao!
http://i46.tinypic.com/24cs2rq.jpg
resistenza @ c57 ??
pencil c57 to lower resistenza by 10-20%
or solder vr @ r56 to ground
if that dont work try this..
http://www.overclock.net/attachments...1155368725.jpg
http://www.overclock.net/attachments...1116924335.jpg
http://www.overclock.net/general-vol...ssentials.html
GeForce 9600GT (RT8802A pwm) VID Mod: Pic1 | Pic2 Table1 Table2 Table3
I'm a 9600GT nut and would love to help. Looks like NapalmV5 has some good links for ya. ;)
Post some pictures if your card looks different then the links above.
Thanks to everyone for the fantastic help! here's photos
Can you post the #'s off the IC's circled in red please? Some close up pictures of those areas would be nice to.
Measure the voltages in the yellow areas please.
here's everything
red 1.80v
green 1.14v
OK, I've marked the leg on each IC. For the GPU I need you to test for continuity between the marked pin and the side of the resistors that I've circled. As for the MEM, you can either do the same thing or you can use the leg on the IC which is big enough to solder to.
I also need you to measure the resistances of each pin to ground.
where rt8802 @ ?? :) lol
sorry passo i mistaken rt8802 with the one found for memories
Measure resistance between marked points and any ground on the board. I Generally use the DVI bracket as ground when I'm probing.
rt8802a??:confused::shrug:
I have a doubt which is the measurement of resistance,
Look in the image of my tester.
number 1 on both on pin the GPU and mem me 0 on the ground
while the number 2 mi from 504 in mem and 463 in the GPU on the ground
Set it to 200K and test.
Here are the pin connections with the resistance
OK, you got the paths mapped, but what are the resistance values for each IC?
everything works ok with increasing the power trimmer increases the V. ..
but how do I get?
There is a rule between the V and the power of memory and gpu mhz?
I also installed a beautiful sink of thermalight'll show you the photos!:):D
and gpu??
GPU is a 10K timmer also. You can solder to any of those resistors at you showed connected to the pin I marked.
but how V would give?
Running on the stock cooler you will want to stay around ~1.25v.
i have thermalright cooler
You might be able to push it to 1.3v. How is your overclock looking on it now?
Got any pics of your mod?
hello I have not made a will because I'm very committed itself with work tomorrow but I do
You have been a great help Pizzaman. Thanks for stepping . :up:
We are looking forward to seeing your work passo :yepp:
here are the photos, do some testing tonight ... because today I changed my motherboard I replaced my old P5QL-Pro with a P5E I have done well?
Looks good.
Are those single turn trimmers?
How many times do you have to turn the nub to go from maximum resistance to no resistance?
I did some tests, the only tool I used is ATITool, and to change the power I used asus smart doctor, Riech to hold without errors ATITool:
Engine 750
Schader 1875 to 1.25 at 56 ° C
the only problem is the memory even increasing VAT 2.15 I can not go beyond 1840 but then I had the temperature at 60 ° up
I have 1810 hours at 55 ° stable with ATITool
Now I try to play ...
even in the game runs jerky, are bad memories?
I need help with volt mod for non-reference 9600GTs. One its a PNY 9600GT and the other one its a XFX 9600GT ,thats quite a challenge for you experts out there since they are different PCBs :/, i have them in SLI and work great in SLI at 750/1850/936Mhz on Stock air cooler. They are going under water and i would like to have them Maxed out to squezze every last drop of performance out of them since they are getting quite old. Please can some one help me ? I will appreciate any kind of help and guidance. Thank you in advanced.
*If you need Pictures let me know and i will post them asap*
Regards: Chispy.
Need some pics of the XFX card plz. As for the PNY, it should be reference design. All the PNY's I've seen so far are. If it's not reference or like any of the other 9600GTs I have listed here, post pics of it to. :D
GeForce 9600GT reference PCB: MEM GPU vMeasure Note: Ref designs most do a VID mod:Source1 Source2
GeForce 9600GT Galaxy non-reference PCB: GPU MEM vMeasure
GeForce 9600GT Zotac non-reference PCB (version A): MEM GPU vMeasure
GeForce 9600GT Zotac non-reference PCB (version B): GPU MEM
GeForce 9600GT MSI non-reference PCB: GPU MEM vMeasure1 vMeasure2
GeForce 9600GT MSI non-reference PCB (version B) GPU MEM vMeasure
Thank you PizzaMan , here is your challenge :).
Stock PNY 9600GT 512MB Samsung memory ICs -
Back -
http://img249.imageshack.us/img249/2793/lol010.jpg
By chispy, shot with FinePix A340 at 2010-04-19
http://img693.imageshack.us/img693/7015/lol009.jpg
http://img52.imageshack.us/img52/8642/lol005w.jpg
FRONT -
http://img9.imageshack.us/img9/5270/lol004u.jpg
http://img63.imageshack.us/img63/5382/lol003.jpg
http://img693.imageshack.us/img693/3781/lol002.jpg
http://img534.imageshack.us/img534/621/lol006c.jpg
http://img249.imageshack.us/img249/7960/lol008.jpg
http://img9.imageshack.us/img9/8940/lol007.jpg
http://img13.imageshack.us/img13/1442/lol006.jpg
Stock XFX 9600GT 512MB Quimonda Memory ICs -
FRONT -
http://img249.imageshack.us/img249/8913/lol011.jpg
http://img52.imageshack.us/img52/5130/lol012.jpg
http://img249.imageshack.us/img249/9243/lol013.jpg
http://img227.imageshack.us/img227/6751/lol015.jpg
By chispy at 2010-04-19
BACK -
http://img52.imageshack.us/img52/6186/lol027.jpg
http://img52.imageshack.us/img52/765/lol028.jpg
http://img693.imageshack.us/img693/7804/lol030.jpg
Let me know if you need more or Better pictures.
Right now they are doing 775/1950/999Mhz on H2O Furmark stable 30 minutes.
PNY memory ics are Samsung and the XFX are Quimonda.
Regards: Chispy.
Cool. Fresh meat.
I've marked the areas that look like GPU and MEM voltage measure points. I've also marked IC that we need the numbers off of. Also, go ahead and take some stock voltage measurements.
http://i170.photobucket.com/albums/u...ill/lol028.jpg
http://i170.photobucket.com/albums/u...ill/lol011.jpg
http://i170.photobucket.com/albums/u...ll/96GTmem.jpg
http://i170.photobucket.com/albums/u...ll/96GTgpu.jpg
EDIT: Need closer pic of the XFX card's ICs plz.
