OC Report - G.SKILL Perfect Storm F3-16000CL8T - simply PERFECT
Today, we have G.SKILL's 6GB F-3 16000 Cas 8 Perfect Storm modules up for review.
Specification
Main Board - Intel
System - Desktop
System Type - DDR3
M/B Chipset - Intel X58
CAS_Latency - 8-8-8-21
Capacity - 3GB (1GBx3) , 6GB (2GBx3)
Speed - DDR3-2000 (PC3 16000)
Test_Voltage - 1.65 Volts
Registered/Unbuffered - Unbuffered
Error_Checking - Non-ECC
Type - 240-pin DIMM
Warranty - Lifetime
The G.SKILL Perfect Storm shipped to me in a plastic package.
http://img231.imageshack.us/img231/5790/81477314.jpg
These sticks are built around Elpida's MHN-E Hyper ICs and rated for DDR3-2000 speeds with 8-8-8-21-1T timings at 1.65vdimm.
http://img81.imageshack.us/img81/2830/38264532.jpg
The Perfect Storm series Core i7 kits which come with a dual 60mm air cooler plus blue LEDs with a 4-pin connector.
http://img231.imageshack.us/img231/468/29779502.jpg
The standard heatspreaders are epoxied to the ICs and the PCB.
http://img517.imageshack.us/img517/3961/80603264.jpg
Test System
Today, we'll be using our Biostar X58 testbed ,the OS Microsoft Windows XP Pro and the benchmarking applications Everest v4.60 and SuperPi 1.5mod.
The G.SKILL Perfect Storm were clocked at DDR3 2000MHz with 7-7-7-21-1T,for stable performance vDIMM was set to 1.68v and DDR3 1900MHZ with 6-7-6-21-1T timings at 1.88vDIMM.
http://img512.imageshack.us/img512/3160/80559180.jpg
Biostar Tpower X58 test platform
CPU - Core i7 920 D0
Cooling - Thermalright Ultra 120 Extreme
VGA - ATI HD4770
SSD - Transcend 32gb
OS - Windows XP Pro
PSU - Giga EZ 1000w
DDR3 2000MHz Cas7 7-7-21-1T (1.68vDIMM)
http://img142.imageshack.us/img142/5...zcas7pi32m.jpg
DDR3 1900MHz Cas6 7-6-21-1T (1.88vDIMM)
http://img148.imageshack.us/img148/8...zcas6pi32m.jpg
For the overclocking results vDIMM was kept at 1.68v.
DDR3 2140MHz Cas7 7-7-21-1T (1.68vDIMM)
http://img518.imageshack.us/img518/4663/gskillcpuz.jpg
