Get them here:
Windows XP x86
Windows XP x64
Vista x86
Vista x64
Windows 7 x86
Windows 7 x64
Get them here:
Windows XP x86
Windows XP x64
Vista x86
Vista x64
Windows 7 x86
Windows 7 x64
I've just installed the Win 7 x64 driver, and so far so good. GPU downclocking on G200 still works as per 185.81, so NV don't seem to have broken that again :D
WinSAT Graphics/Gaming Grahics are up 0.1 as well. 6.5->6.6 on my GTX 280.
Only games I'm playing are The Last Remnant and Xmen Origins: Wolverine at the moment, and these both play fine so can't offer much about game performance!
Tested briefly on Win XP x86...
So far so good as well ;)
Initial impression is that Nvidia Control Panel is more sluggish than 182.50 whql.... can't really compare to 185.68 beta as they would never install properly and even messed up my desktop resolution (could not change res from default)...
...and now for some gaming... ;)
Edit 1: Much improved scrolling on the Campaign map in Empire: Total War (still buggy as hell with useless AI, before you ask ;) )
Edit 2: Crysis Warhead is giving playable framerates (25+) @ 1920 x 1200 with 4x AA ...an improvement.
Edit 3: GTA IV is working well and a couple of buggy textures are no longer glitching...
What about ambient occlusion? Is it "awesome"?
I'll install it soon, I've been running 185.81 and been playing Fallout 3 Broken Steel.
just installed drivers and i can see 2-3 fps in crysis wars and yes ambient occlusion is awsome confirmed. :)
Did you enable it in the games individual nvidia profile or in the nvidia global settings? Im finding that the individual settings area isnt working properly in Win 7 with these drivers (games that are supported arent detected, so if you try to add a game that is "supported" it chooses that pre designed profile, then after closing disables)
What's the deal with this Ambient Occlusion? Does anyone know of an article yet with some in depth analysis on the potential benefits and performance hits?
I also just noticed an added "SLI64xQ" AA mode, this is going to interesting :rofl:
These drivers still run both my gpus at full 3d speed (in my case 666) when playing media files under vista x64 reguardless of player or viodeo format. Xp x64 does not do this though.
Nice improvements in Riddick - Assault on dark athena. Vista64.
These drivers make my screen shake when I'm flashed or partially flashed in Counter Strike - Source.
Demo comparison screenshots in a few games:
http://www.nzone.com/object/nzone_am...sion_home.html
Siggraph presentation:
http://developer.nvidia.com/object/s...2008-HBAO.html
DX Sample:
http://developer.download.nvidia.com...#ScreenSpaceAO
They went from having low, medium, high options in the control panel to just on or off in recent drivers :\
Im having trouble installing on windows 7, when i uinstall the old drivers & reboot windows uses wddm & then i have to reboot again, then install these drivers none of my games run?
Drivers work fine on my Vista HDD though
Well I was getting BSOD's with 185.81 in Win 7 on GTX 275 but 185.85 only gives me "Your display driver stopped working" and crashes whatever game I am playing at the time, so I guess thats a "fix" of some kind :p:
On my system right clicking the desktop to bring up the menu takes almost 3 secs now and another 4 secs to launch the Nvidia control panel. Even though I don't do it that often this is completely unacceptable for a 4.2Ghz i7, X25-M SSD, GTX280 SLI system on Vista 64. The latest beta 185.81 showed no such behavior...although right clicking the desktop still took about 1 sec to bring up the menu.
Anyone else experiencing the same?
I'm still on 180.84. The world is passing me by I swear.
Well, Both right clicking and the control panel are almost instant for me. Switched last night to these drivers.
And im only on a 3.57 e7300, :p
Suffering from both of these issues also. [edit] - CSS flash bang shakes fixed by switching to single-gpu mode.
Yeah i found that stuff, the Wow screen is the most impressive, definitely seems more vibrant. I found some posts on another forum though of people claiming 150fps > 50fps drops on Cod4, and something similar on CSS, which obviously isn't tolerable.
So far for me though i don't seem to be getting any performance hits, and in FO3 this option seems to get a tighter grip on the sky box's HDR, an improvement for sure, i reckon i'll have the AO on by default.
Just found the below on the Guru3D forum for the menu lag. I haven't tried it yet myself though.
Originally Posted by HeavyHemi
I just found this fix over on the EVGA forums. As always back up your registry before doing any modification. I performed this myself on Vista 64 Ult and it worked perfectly to eliminate context menu delay. What I did was first delete the context key then create the command key. No reboot required to test.
Navigate to
HKEY_CLASSES_ROOT\Directory\Background\shellex
Delete: NvCplDesktopContext key and all is good, now right click is fast as ever. If you need the Nvidia Controle Panale
all you have to do is select it from Programs and Features.
Ok now the fun part; for all of you who want the context menu this is how you add it back without the delay:
then Right click on Shell and add new Key: Name that key Nvidia Control Panel
Then Right Click on that new Key and add a new Key: Name this Key Command
Then with the new key Command selected in the right hand pane double click the Default Value Key and type:
c:\windows\system32\nvcplui.exe
This will fix your Context issue....
This is how the key will look: (By the way you can copy all of that out and past in a text document and rename to .reg
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Directory\Background\shell\Nvidi a Control Panel]
[HKEY_CLASSES_ROOT\Directory\Background\shell\Nvidi a Control Panel\Command]
@="c:\\windows\\system32\\nvcplui.exe"
The fix works :)
Yeah that's sorted it, will remember that in future :up:
:edit: Started getting random freezes all over the shop on FO3 though, have reverted to previous beta.
I kinda think that some of the difference in the WoW screenshot is the time-of-day in game... like there was a while between the screenshots. But maybe it's all due to AO. It certainly should be shadowing (like it does under the plants), not brightening the scene as a whole, which is why I think it's kind of confusing.
Is anyone else now BLIND in Left 4 Dead?.. It's like i'm suck inside a smoker haze!
http://www.xtremesystems.org/Forums/...d.php?t=211130
i think this actually belongs in the video card or software section .. :shrug:Quote:
Originally Posted by Ashraf
Tried these out. experienced 20-30 less FPS in certain areas of TF2. Wound up going back to 182.50 Vista x64 drivers.
GTX 280. Turning off AO did not yield a positive effect. :/ Tried a few different things before uninstalling.
RivaTuner can not find the Nvidia 185.85 WHQL drivers :(
