Hondacity's HeatKillers GTX285 in Triple Sli (simple test)
Another fine weekend as I got some points from HWbot.
But anways, just sharin about tri sli, in parallel.
Simple Setup:
Single loop: Dual 355s > Koolance 350 > HeatKillers > HWlabs 480 GTX with 4 Scythe Gentle Typhoons 28dB :D
My flow is alittle below 1.5gpm...look at k350 + dual 355's 480gtx, dunno what the tri sli gpu's introduce as restriction...but I don't care. Flow is overrated.
http://i24.photobucket.com/albums/c5...4flowrates.jpg
MY STFF, Watercool did not commission me in anyway, FU who thinks otherwise.
http://i24.photobucket.com/albums/c5...y25/hondaa.jpg
Anyways..lets get to the idle temps
notice all three gpu's idling, no worries here...
http://i24.photobucket.com/albums/c5...mpsoneloop.jpg
Load temps, here I used OCCT's power supply test, cpu and gpu are stressed, psu is also stressed, i love my Enermax Evo1250 :D
http://i24.photobucket.com/albums/c5...oadedtemps.jpg
Well its obvious parallel gpu blocks work.
HWlabs 480GTX + 4 Gentle Typhoons work too and its silent without undervolting
Part2
****cpu ang gpu's are on separate loops****
The important stuff : The RAD and FANS, quad for the cpu, dual quad for the tri-sli
http://i24.photobucket.com/albums/c5...city25/fff.jpg
First 20minutes
http://i24.photobucket.com/albums/c5.../20minutes.jpg
40minutes later
http://i24.photobucket.com/albums/c5.../40minutes.jpg
gpu1 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu1.jpg
gpu2 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu2.jpg
gpu3 graph from occt
http://i24.photobucket.com/albums/c5...ity25/gpu3.jpg
************idle temps aren't really that interesting, nvidia throttles the gpu speed to around 300mhz versus max set, temps go down at 300mhz
************restriction on these blocks aren't bad.
Enjoy
Hondacity
Part2 added to post1, and answers/comments
Originally Posted by
shazza
OK ... let me see if I understand the bar chart ...
Starting on the left, it shows lower flow rates for the 3 different CPU water block setups. As you add pumps/tops, you get a higher flow rate. Then you get even higher when you switch from the 480GTX to the PA120.3. The config you are running is the third one ... and that's the one you used to get the CPU/GPU temps you posted. Is this right so far?
I also take it from your comment about flow being overrated, that you didn't test the 1st or 2nd setup (or at least didn't post temp results). So would you expect to get the same performance level on the GPU temps with the lower flow rates? (I think this is what SNiiPE was saying, just not sure).
NOTE -- I'm not questioning your testing or your conclusions, just trying to make sure I understand. I guess I'm confused with the fact that you've shown multiple flow rate setups, yet posted only one set of temps. Maybe the flow rate data was from another test, and you included it here for info?
long overdue answer : yes it was from my flow testing
IanY
Yeah. tell him to put four in a row in a 50C case ambient (not an open bench) and then tell me what temps he has
Want me to show you 40C ? I'll set my own parameters... hell, I'll show you 35C my way.
Why don't I wait for January to come along, take the sucker outside and brag to you that my gpus load at 5C ?
its 20C inside the apartment ...i'm getting load temps of 37-38c on my 285s. 50c :ROTF:
Erasmus354
check part 2 at post1.
KaptCrunch
Shazza its corrected by Hondacity ;)
just noting missing data, nothing wrong with your data ;)
Hondacity can u run another screenie
screenie on the new setup yes, single loop is gone.
Humminn55
Interesting show, but I had thought it was already pretty established that cooling gpu's was not dependent upon high flow or massive radiator capacity.
On the other hand, I see your monitoring sofware you're using is all over the place in reference to your cpu's core temps. One has the highest core at 66C, one has it at 74C....odd, that.
But what makes you use comments like that? Completely uncalled for and really shows a lack of thinking, at the least.
log my cpu temps? thats too easy, if its odd to you. i'll say it to you ODD it is :)
IanY
Regarding the state of the hobby, there was once when performance actually mattered. Now, gltiz and show takes center stage.
you saying this as glitz?
vantage 3x285s
http://i24.photobucket.com/albums/c5/hondacity25/xy.jpg
NaeKuh
can i ask an off question.
sorry about the slight detrail, but honda it looks like your running everest ultimate.
How did you get that program to play nice on a 64-bit i7? Skinnee and i were dying almost an entire day because that program kept crashing our i7's.
its 32bit dude, i get some weird bsods with the ssd and 64bit
anyways post1 is updated somewhat
Part2
First 20minutes
40minutes later
