X58 Chipset B3 Stepping Changes
Found the changes for B3 here:
http://www.intel.com/Assets/PDF/specupdate/320839.pdf
If you have B2 and are curious what changed in B3, then it looks like the following were either fixed or do not apply to B3:
3319486, 3319733: DEVCON2[3:0] and CTOCTRL not accurately set the
completion timeout value.
3319609: Boot-dependent QPI CRC errors
3319688: Some Gen2 endpoints will not complete the training in Gen2 mode.
3319737: MIERRCNT does not properly count persistent SMBus retry failures
and MINNERRST doesn't log the errors (HEDT only)
3319811: EOI to the I/OxAPIC can be blocked
3319755: GTIME upper 32 bits can not be read or written.
3319791: Intel® QuickPath Interconnect (QPI) L0s and L1 Power Management
Link State Fails
3319795:PCI Express* 2.0 L0s Link Recovery Fails
3319874: IOH May Falsely Assert THERMTRIP_N Signal After a Reset Event
3319408: VT-d queue-based invalidation is enabled only when enabled on both
channels (WS only)
3319432: VTd does not support the draining of compatibility-format interrupts
(WS only)
3319452: Hardware applies HPA_LIMIT to upstream memory request when VTd
is disabled (WS only)
3319630: VT-d: Memory read request with AT=11 results in malformed TLP
3319532: VT-d: IOTLB Domain-page-selective invalidation not working
correctly.
3319847: The IOH Ignores Snoop Behavior Bit in VT-d Page Table.
3319819: VT-d reports an Invalidation Queue Error when the Queue size is 7
(HEDT only)
Now I want to know if/when the DX58SO desktop board will include this. The latest revision E29331-503 does not mention this new B3 X58.
Confirmed B3 chipset here...
Originally Posted by
003
When the hell are we gonna get some kind of confirmation that there are boards circulating with the B3 stepping??!
Figured id chime in , my P6T7 WS Supercomputer has it for sure :yepp:
