Originally Posted by
Mescalamba
Well I haven't find any on XS, only ones for MSI via Google.. but not sure if MSI use same PCB.. probably not.
vCore increase depenlyds how much of pencil you use.. if it can be done, there can by only slight increase in voltage.. tough it would probably need some help from ppl that understand how to do that with this graphic card.. which is certainly not me, cause I'm not even able to understand this hardmod (I need some picture where it is clearly visible what I should solder where, than its easy:).
Tough.. it looks like founders of this thread doesn't look here anymore.. if yes.. can you make some guide for dummies? (and for pencil mod, if its possible:) ) Thanks much..
