I've just got brand new 3x2B Crucial. The weird thing is that they have D9KPV chips, and even google doesnt give any matches. Does anyone knows those chips?
Well...what kind of clocks can you get out of them?
1600 CAS 9 for my 1 gig stick at 1.7 volts
i have some D9KPT its 2x2gb kit 1333mhz cas7
http://www.ewiz.com/detail.php?name=W1333UX4GM
i was able to get to 1800 im limited my by my motheroard i think
it was ~1.7 . i have kpt. the same stuff thats on some of the ocz blade.
1600 cas9??? thats awful!
even the worst d9gtr and d9jnl did better than that :S
kpv is 2gb were gtr is 1gb. my kpt can do 1400 cas 6 with 1.65 lowest my board goes
those sticks won't run fast but they will run super tight like cl6 1333 mine will not run on the 1600 divider with cpu at any speed voltage 1.64 max on asus p6t.
i was thinking of getting this stick(supertalent 1333mhz),not sure how good this chips are,can they get 1600cl7@1.7/8v?
what about corsair 6gb 1600 cl8,what chips they have and how far they can go?
what it can run 1600 cl7 on 1.65v?? supertalent,kpv chips???
if true one is mine....
here is 1600 cas 9 1.65 i ran them loose. i can tighten them to cas 8 if you want
http://img18.imageshack.us/img18/6051/1800.jpg
cas8
http://img402.imageshack.us/img402/1425/cas8.jpg
cas7
http://img19.imageshack.us/img19/545/cas7s.jpg
my friend has OCz Platinum 3X1 GB 1600 Mhz Cas 7. Micron D9 JNL 1.65V
and while benching video cards etc. 2000 Mhz Cas7 2.05 V That's no problem...
1.7 V not good...Code:1600 CAS 9 for my 1 gig stick at 1.7 volts
whe3ls thank you for this! Have you tryed even higher clocks?:D
pfff 1600MHz cl7@1.65v, really nice!!!
have you got heatspreders also or it is just on picture??
and i thought so,what do you think are this chips better than d9jnm?? i mean 1600 cl7@1.65 is unbilivable....maybe i will get them i need to search more, this is module i can buy DDR3 2GB PC3-10600 (1333MHz), SuperTalent, for 45€,probably they have kpv chips??
I've personally never had anything but GOOD LUCK with super talent... :):)
then why do i have a 1 gb stick of kpv. do you need a picture of it.
this is the stick
http://www.newegg.com/Product/Produc...82E16820148147
so don't say something you dont know
i had a stick of 533 i got to 1066 that was super talent
yeah but what volatge??
I will get them tomorrow, with a 720BE , tests soon.
They are a Pair of 2x2Gb Supertalent 1333Mhz CAS7 , without heatspreaders
Micron D9KPV 3 x 2GB
DDR3-1600 8-8-8-24 @ 1.65V
http://individual.utoronto.ca/bzhou/...j07/tj07-f.jpg
http://individual.utoronto.ca/bzhou/...1600-88824.png
Booted into Win7, running Prime95 for now.
7-7-7-24 @ 1.70V is a no go, but then again this is my first go at i7 + DDR3 :shrug:
Try higher freqencies instead of tighter timings. :)
Running some SuperPI 32M's right now. 1800 8-8-8-24-1T 1.7V - Bumped HTT to 150 and QPI to 1.3 left everything else on default (AUTO).
This noise is KILLING me. I'm used to 5V S-Flex F's, and now I've got stock coolers on everything going full tilt lol.
http://individual.utoronto.ca/bzhou/...1800-88824.png
[QUOTE=zoob;3758126]Micron D9KPV 3 x 2GB
[QUOTE]
also supertalent???
has anyone pushed volts to see if these will do 1800 CL7?
I can do this with my new Supertalent 2x2Gb
http://img188.imagevenue.com/loc1010...122_1010lo.jpg
(I unlocked the fourth core :D)
PD: They have no heatspreader and Micron D9KPV
Sry , 1.65v
Hi guy.
Yesterday i've checked a Corsair XMS3 TR3X6G1600C8 Version 3.2 and used IC D9KPV ;)
http://www.corsair.com/_datasheets/TR3X6G1600C8.pdf
Next days will test them :)
what are chips in this ram
http://www.links.hr/index.php?naziv=...kl=051.210.025
What kind of sub timings are you guys using? I'll post details on my kit when I get home.
Prime LargeFFT unfortunately, as right now I'm testing CPU stability.
http://individual.utoronto.ca/bzhou/...2ghz_1.325.png
1600 cas 9 at 1.65v?
Ya 1600 CAS9 1.65V
I'm still getting a feel for i7. Will try to tighten it to 8 next
does anybody knows???
D9KPV
DDR3-1688ish 9-9-9-24 @ 1.65V 20 pass LinX stable
Tightening it to 8-8-8-24 will give me a BSOD after about 20 min of LinX.
http://individual.utoronto.ca/bzhou/...1.336_1688.png
Interesting, I just received these the other day, and still no mention of them on Corsairs website ? They seem very stable at the default XMP profile of 7-7-7-23-2 on the UD5.
http://www.ncix.com/products/index.p...acture=Corsair
had to shove 2 volts through the stick for DDR1440 8-8-8-21-29. got it to 10k read. cant wait to get a nice kit
ok got it to 6-6-6-21 at 1440. its nowhere near stable though.
10.14k read
i tried to get a ss but it bsod'd on me as i opened vista snipping tool
what voltage?
this is @2.14v on D9JNL
http://img.techpowerup.org/090407/Capture016397.jpg
that is my new crucial pc10600 (CT3KIT12864BA1339.8FF) micron d9-kpt based.
on my dfi x58 UT and i7-920 D0 with some good voltage i've reached some interesting frequency.
2272mhz - cas9 - 2volt - 1t
http://valid.canardpc.com/cache/banner/561089.png
2210mhz - cas8 - 2volt - 1t
http://valid.canardpc.com/cache/banner/561062.png
http://forum.hwproject.net/imagehost...1e41299ee9.jpg
all subtimings on auto
with more than 2 volt they can't boot on my dfi x58 and on foxconn blackops
p.s. low voltage rulez :ROTF:
More D9KPV testing. 3x2 GB DDR3-1600 8-8-8-24-1T @ 1.65V, CPU @ 20x201 SpeedStep enabled.
Rampage 2 Extreme information:
Dram timing control
1st information - 8-8-8-24-6-88-14-8-30-0
2nd information - 1N-59-61-62
3rd information - 7-7-18-9-9-9-7-6-4-7-7-4
http://individual.utoronto.ca/bzhou/...1600_88824.png
hi all
http://www.snapdrive.net/files/27509...613_resize.jpg
Today i went to the shop and i bought some memory that 4GB kit DDR3 PC1333 (D9KPT)
price around 80$
so now i just waiting for Phenom II 955BE (:shrug: still not come yet in shop here) maybe in end of this month i will see it in the shop and i will upgrade my system to AM3, i hope:p:
http://www.snapdrive.net/files/27509...617_resize.jpg
http://www.snapdrive.net/files/27509.../close_ram.jpg
http://www.snapdrive.net/files/27509...618_resize.jpg
http://www.snapdrive.net/files/27509...620_resize.jpg
my supertalent pc3 1333 has the same ic's.
Yesterday I've tryed my KPV rams. For now 1650mhz 7-7-7-20 without problems (1.65V)
Ive tested my rams and resoult is:
1.65V in Evga X58 SLI and 920 C1:
7-7-7-20 can go 828mhz
8-8-8-24 can go 875mhz
9-9-9-24 will do super pi on 930mhz
So I'm extremly happy with them. 6GB kit for only 90€ and can do 1650mhz cl7, and 1850+ at cl9. All this with "safe" voltage. I'll try higher voltage, when I'll have some spare time...
