Real Power Consumption - 4870 X2 & GTX295 out of Spec!
Originally Posted by
Fallacy
We (german Hardware-Mag HT4U) have got some meassurings of power consumption of current graphics cards for you. The results represent the power consumption of the graphics cards only, these values are
not the consumption of the whole system. If you´re interessted in the way how we meassure -> go
here. The article is in german, but i think tables, pictures and charts are multilingual ;).
Instead of 3DMark06 we used FurMark as load. Furmark causes a much higher power consumption than other tools (for a comparison go at the end of
this page). With FurMark most notably the High-End-Cards dramaticly exceed TDP and even more worse: PCI-Express-Specification.
For example: A HD 4870 X2 (TDP of 286 Watt) consumes 373 Watt with Furmark. GTX 295 isn´t much better in this case 289 Watt (TDP) vs. 317 Watt (Furmark). For TDP-versus-Reality-values of other cards go here:
http://ht4u.net/reviews/2009/leistun...a/index14.php]
Some Cards even don´t work within PCIe-Specs using Furmark. For Example, 4870 X2
consumes over 200 Watt from the 8-Pin-Connector (specified for 150 Watt). GTX295, 285 exceed the Maximum of 6-Pin-Connector (75 Watt) with in both cases about
100 Watts.
For an overview of consumption of all tested cards, go
here.
Hope you´ll find some interessting informations in the article :).
http://forums.vr-zone.com/showthread.php?t=387997
