Bends on my MCR320 Radiator Fins
Playing Battlefield 2 Special Forces yesterday i heard a loud boom, and my computer shuts off. I look inside my Silverstone TJ07 and the tubing came off of the cpu water block.
I decided to change the distilled water and change the tubing as well, since my computer has been running for over six months without a change.
I take everything out of my computer and notice a good amount of bends on my radiator's fins.
Would it be best to straighten out the bends with a flat head screw driver?
I also have 8 fans in my computer that all run above 100cfm, i need a fan controller badly since my ears ring on a daily bases with all noise.
I was thinking to get this. http://www.newegg.com/Product/Produc...82E16811999171
Since this has 6 fans it can control, I need to control two with one of the controls. Would the best option be to have a y splitter to have one control run two fans simultaneously?
Thanks for the help :D
