Originally posted by st0nedpenguin
It could be the board holding you back FSB wise, if you can I would try and borrow some RAM that has been tested at high FSB's before splashing out on some new stuff, you could find your FSB overclock is no better after you have forked out for new RAM.
Its ok to get more. I have an A7N8X dlx so I need another set of DDR for dual channel. I split the set to run both boards for F@H. I only have the chipset voltage at 1.6 the default, and could go higher i'll bet. It is an 8rda3+ rev 2.0.:p: Im happy with the pc3200 goin up to 3500 speeds. But I dont wanna go CAS 3 with crappy timings just to go higher.
