Originally posted by Alexandrus
I kniow, the box is different as well, but who cares. Same regarding the rounded cables, color is not important.
Clevor, can you do me a favour ? If you still have the 1.2 and 2.0 rev. of 4PCA3+, can you tell me if there is any performance difference between the two ?
PS. As for OCing, as strange as it may seem, I've heard of many 4PCA3+ users that can take their boards to 300MHz FSB and above.
300fsb wouldn't be strange, but above is basically impossible with this board, atleast much above 300. the 4pca3+ and 4pda2+ have a bug where the agp/pci lock doesn't work over 300fsb. If you have an ati card you won't be able to get much higher, but supposedly with an nvidia card you might be able to go higher because they have a higher tolerance for higher agp/pci speeds...but then you have to use an nvidia card, and I don't even know if that actually will help. I should be able to get to about 315fsb(boot not stable) with my 2.6c, so I will be able to test +300fsb oc'ing with different cards...unfortunately the only nvidia card I have is a ti4200...wouldn't mind seeing what kind of 3dmark scores I would get with it :D
