*** please mod your own risk ***
big boost for all clocks (core/shader/mem)
recap stock to higher capacitance/lower esr
http://img398.imageshack.us/img398/8061/8800bgfkap6.jpg
cap vacant c111/c112/c114/c116
http://i46.tinypic.com/nx1fgg.jpg
That is a nice clockspeed increase. I didn't knew that such a "simple" mod could make such a difference.
its not just clock increase.. PQ aswell ;)
the caps in the pic above are the 1000uf.. right now im on the 1500uf and PQ improved over the 1000uf
ive never seen this level of texture/detail before on the 8800
no core gain just some shader/memory mhz
next attempt: 2200uf caps
Whoa! Could you explain in Layman's terms what you've done or how this works?
Thx for sharing mate :D
Great mod! Are these standard Blackgates, or are they the K series?
Great effort, especially on the Auzentech cards before. You stated +20Mhz in the first post but no gain in the second. I don't see how caps can improve picture quality. I tried recapping before and soldering in parallel to each phases using Panasonic FM series with zero improvements, most likely placebo effect in your case. Too much capacitance just ruins the circuit, but with BlackGates caps you never know :D.
where did you get the caps from?
do you think 3300 and 3900 would be too much? I've got 2 cards to do and two old mobos with 5 of each...
you also did the OCP, OVP mods as well? Can you say exactly what you did for those, the thread is pretty jumbled and includes lots of stuff on GTS, GT's as well (this thread http://www.xtremesystems.org/forums/...d.php?t=162124)
TIA
edit: nm these caps are only 6.3V and they need to be 16V, looks like I will be getting some...
also gonna do the chokes and caps and ovp mod... any advice?
ive removed the five little stock 180uf caps in the pic and replaced with high quality audio caps: blackgates :)
if you read up a bit on caps/blackgates.. these caps increase/expand frequency.. filter/remove noise.. etc
sure mate :D
the FK.. the 1000uf one is an amazing cap :up:
well even vcore modded 750 core wasnt stable.. so im not surprised there is no gain from the 1500uf theres only so much caps can do.. im suspecting some parts on the card are hindering anymore than 740 stable
idk how the panasonic fm do.. but these blackgates warranted 20 core and 50 shader/mem: 740/1800/2400DDR and i can game at these clocks nonstop - just wasnt able to do this before no way no how
as for picture quality idk what to say.. im not that knowledgeable to tell you guys why it has improved.. in my own words probably these caps push more of the graphics the gpu produces to the display :shrug: what i can tell you guys for sure is that im just enjoying the results im getting..
from soniccraft.. @ canada you can getem from partsconnexion
idk what kind of effect the 2200/3300/or more would have on the card/gpu.. so far i only went 1500uf
the only vmod i did was the vcore mod but since then ive removed it.. too much heat for air cooling and i got an ac x8800 cooler on now
highest ive taken it to on the vcore mod + caps is 770/2100/2500DDR - light benching
i wouldve done the choke/caps mods in that thread but theres no more space to work with on air cooling.. if id go water/phase than yeh..
ovp: i didnt get to need that mod
if youre gonna do any vmod no less than water cooling
yeh go ahead and do the chokes/caps and see what u get out of that
good luck
well i went back to the 1000uf FK but paralleled
not pretty but works
http://img379.imageshack.us/img379/7290/62379938ml7.jpg
without a doubt i can say that caps do have an affect on lighting/shading/texturing/coloring.. though not all textures are affected
ETQW looks better on the 1500uf NX: more lighting/depth
UT3 looks better on the 1000uf FK: more shading
looks like ill be installing caps suited to the game lol
up to you guys to try.. just sharing with you guys what i do :)
unfortunately still no 750 core.. that will be another project
Looks great :up:, what do you use to remove smd caps, what tip and how many watts? You should try soldering one cap for each phase, there are 4 on your ultra. Next time try recapping a mobo especially memory/northbridge/cpu phases to see how these blackgates perform :D.
Is this same to the 8800GTX ?
just my fingers to remove smd caps :) just like i removed the 74 smd caps on the xmeridian
yeh the 4 caps @ phase i would replace but since im using air cooling no space for even 12.5mm caps.. maybe 10mm caps would fit.. before ill sacrifice the card to the oc gods ill use 2200uf gb nx there :)
ive attempted recap on mars but somehow ive managed to splatter solder onto the back of the mobo was quick to remove and it removed traces with it.. so i didnt get to find out what the 1000uf fk can do on the mobo
I really want to vmod and do this to my 8800GTX now.. Crazyness.
I'll look into it in December when I get back home. This thing is going to last me well into the DX11 generation. What a great card.
could you do some screenshots where we are able to actually see the pq improvements? i'm curious to see your results :)
Sorry, but i still have doubts about these miraculous image improvements just by changing caps. I do think it does change the sound a bit on soundcards, but no way for digital 3D graphics. It's all based on how GPU processes the elements, not some silly caps. And especially not with digital connectivity where DAC's aren't even used. You may get some more stability or OC potential if used on PWM part but nothing else.
why not? sure itll make it go further but itll depend on what kind/and the quality of the caps youre gonna use
read up a bit on on how/what caps/blackgates do and youll get a better understanding of caps and why your clocks will go increase
i got ut3/etqw installed atm.. what map/screen shots would you like to compare?
ill post some pics later today when i got time..
well believe it or not the change these caps do on soundcards is miraculous! have you used blackgates on soundcards? or some half arsed cheap caps that do worse than the stock ones.. and just because you didnt get better results than no else is?
im not talking miraculous image improvement.. just more of what the gpu produces to the display.. when i got an 8800gt for a friend i noticed better pq than on my ultra.. it could well just be that the stock caps were not performing the way they shouldve been..
look guys im not here to prove anything to anyone.. just sharing what i do/results i get.. dont like it/have doubts stay away! dont attempt!
only those that will attempt will reap the benefits.. even if your not gonna notice any image improvement youll surely get higher clocks
and i surely didnt post this mod to get any glory
I said it can change sound on soundcards but not image on graphic cards. It's just not logical and makes no sense. Maybe on CRT and even there i doubt it, but with LCD through DVI, no way.
Must be placebo thing going on there. I'm not saying that you have to prove me anything but those results just don't make any sense without some kind of proof.
youre welcome mate :)
yeh right you said it can change.. youve dissed my soundcard mods cause it hasnt work for you the same way.. thats your problem.. you said youve recapped and yet you sound like you have no idea what a cap does and how it works.. seems nothing is logical/makes sense to you.. again your problem
sorry im not your beeach, you want proof do/try it yourself
there are many cap knowledgeable people that have used blackgates @ video.. go screw their brains if you want more proof
if you think youre smartarser than anyone else.. show me what youve got.. show me a freaking mod that makes sense and for crying outloud make it freaking logical!
I think Panasonic FM are overhyped, specs are really good so is the price, but nowhere near the BlackGates so probably that's why I didn't see anything improved, they helped on my Prelude X-Fi but not on 8800GT maybe because of 2-phase PWM that is really weak and cheap to start with. I still have to try BlackGates on a graphics card, I only have 2 caps ATM on my Prelude X-Fi, these things are expensive to mess around :p:.
Now that's clever when done right :), I had 50/50 success ripping them off so I still need to practice. When soldering in parallel to existing cap, do you think that it would be best to take of the original cap so it doesn't interfere, or it doesn't matter? Thanks.
Whatever man. I'll just recap my old S3 Savage 4 Pro and gain Pixel Shader 4.1 support with it and performance beyond GTX 280.
Oh and colors will be more natural and rich than the ones in nature. Khm...
I recaped my Xtreme Music because it's main cap pin was teared out a bit (long story with P5Q Dlx and VF-900 on GFX card), not because i was searching for ultimate sound. If i were looking for that, i'd replace opamps and DAC's first, not some caps. Now that makes all the sense and logic there is. But hey if you want to stick ridiculously big caps (in a ridiculously high numbers) on your hardware, well, then do it. It's just lolish to observe you describing incredible boosts and stuff. Anyone half serious would test first with some real numbers before claiming such things. Unless you want to be "The guy with biggest caps in the block". Then you're already a winner...
if id find better/cheaper caps than the blackgates id buyem.. im still waiting for the day when someone will say that they have found a better cap/s than the blackgates
2.. even better 3 x FK 1000uf in parallel where the 470uf stock condenser is on your prelude and itll knock your socks off ;) :D just a 470uf 6.3v @ 180uf stock condenser
in my opinion its best to replace the cap
look man i didnt mean/or want to be rude/nasty to you..
{idk why all you saw was the big caps when the first mod i did on mx300/xmeridian/prelude/prodigy hifi was the opamp/s.. than i turned to total recapping.. and when i posted the pics up i clearly stated the upgraded opamps
you want numbers? forget about it! if your ears are not able to tell the difference what will numbers offer you then? comfort? ive tuned my sound cards to my hearing delite not to some stupid numbers
you think every cap ive tried was up to my satisfaction/up to what i expected to perform? no! but i didnt stop trying.. and these are ridiculously big caps? come on man.. have you seen the 10000/50000/100000uf ones?}
but if this is a jealousy thing.. which ive suspected from the start.. thats your problem.. me? i dont hate/am jealous of someone having better stuff/hardware/money than myself.. more power to that someone
i dont have a before and after but these pics are on 10 x 1000uf 25V NX
rez: 1920x1080
drivers: 177.89
af: 16x
aa: 4x
supersampling
http://img29.picoodle.com/data/img29...1m_64603e1.jpg http://img29.picoodle.com/data/img29...2m_446e9b8.jpg http://img26.picoodle.com/data/img26...3m_2bf143f.jpg
http://img26.picoodle.com/data/img26...4m_6ffcb32.jpg http://img28.picoodle.com/data/img28...5m_84a4fc7.jpg http://img34.picoodle.com/data/img34...6m_ba427f7.jpg
http://img29.picoodle.com/data/img29...8m_5784105.jpg http://img32.picoodle.com/data/img32...9m_296fdf5.jpg http://img37.picoodle.com/data/img37...0m_3e850c5.jpg
F11 -> GIMP2 -> saved as jpeg 100% quality
These pics would be more useful if you'd also have stock images. But i guess we can't expect you to change everything back to stock again...
If i'd ever recap anything i'd do it on PWM part in hope for better overclock. I just don' think it's worth for anything else.
more useful? but of course i knew exactly how this would turn out :rolleyes: this is my first video recap ever pq never crossed my mind.. expected a measily 5 maybe 10 mhz increase at best.. i wouldnt have bothered to post this mod but instead i got 20 core/50 shader/50 memory - thats real numbers if you want numbers.. i didnt pullem out of my arse
even if id be able to go back to stock caps and show you clear difference.. youd still be unsatisfied
do whatever you think its right for your mod
Amazing results mate :up::up: i couldn't find those caps here...damn :mad: talked to a friend that's electronic Ing and told me to use others that can be find on good boards, same as my mate Cryptik told me, problem is that i don't wanna put used ones...i will keep on searching...
very happy with my GTX vmod...at 684/1836/2268 I can now play Crysis at 1680x1050 al high except shadows and X2AA totall fluid not any lag as i had before...So soon as i find those caps I wil test :D
Thank you mate keep is posted with your results :up:
Nice recap man, very clean work
So you just pull out the caps using your hands? Im still getting practice capping, any tips you can offeR?:)
thanks.. yeh just ripem off by rocking till come off :)
NapalmV5, how do you know wich volt caps to use in your recap projects? When to use 16V caps and when 100V caps?
The Voltage ain't the important bit you can use one a bit higher, its the " μm " you go by.
No it's not. You need to know what the voltage is that the cap is a certain position will be exposed to, and use a cap that will suit.
You don't want to use a 63v cap for a 2v +/- 0.5v signal where a 4v cap was originally. There are a few schools of thought on this but in my opinion around 80% utilization regarding voltage rating/tolerance of a given cap is considered optimal. Never use a cap with lower voltage rating than it will exposed to.
Regarding farad rating, going too high or too low will affect circuit dynamics negatively, there again is an acceptable range of farad rating, ESR etc that will have optimal effects, however calculating these optimal specs will be well above the average non electrical engineer, so try to stay around the values of the cap you are replacing.
^ exactly what cryptik stated above :up:
capping vacant c111/c112/c114/c116 big boost for all clocks
http://i49.tinypic.com/10zvlf5.png
Amazing 8800Ultra
I'm taking a stab in the dark, but a theory for better picture quality would be bigger caps = smoother voltages?
