Originally Posted by
Lestat
quit buying high VID chips i mean,, how many bad purchases does it take to learn
interesting little twist.
RMClock will actually change the default VID in coretemp when using RMClock to lock the multi and vcore.
try it out,, you'll see.
now unfortuantely i have only used this on dell systems and dell systems, unfortunately do not have overclocking options and only a select few boards allow setfsb to change the fsb, but because of no vdimm control you cant change the fsb very much without taking the ram out of spec.
either way someone should give it a try and see what happens.
