It is unfairly skewed toward Nano on the power measurements. You could power both these boards with a 1200 W power supply if you wanted... why you would do this is beyond me... in fact, why you would use even a 200W power supply is beyond me. But that is what these numnuts did... they used a high rated power supply to power a low wattage board. Just because a PSU is rated at say 500 Watts does not mean that it outputs to that wattage to the board. The PSU will only output what the load is requesting.
Just a quick lesson in power supplies. Power supplies come rated in the total peak power they are able to deliver, sustained power is a bit lower....
Power supply makers are also interested in quoting you power efficiency, which is essentially the % of the power input that makes it to power output at a given load.
For example, say I measure at the wall socket 100 Watts, but the efficiency is only 80%, the actual power delivered is only 80 Watts.
Ok... now, here is the kicker. The efficiency quoted for a power supply is between 20% and 80% of it's rated power. Above or below that, the efficiency is drops of rapidly.
Here is an example Anandtech did of a recent 900 W PSU:
http://www.anandtech.com/casecooling...spx?i=3364&p=7
Notice at 200 W the efficiency starts to drop off rapidly, going to 73% at 90 W load... now look at how steep that curve is.... at 20 W (which is about what these boards are pulling) efficiency is down near the 40 or 50% range.
Ok... now think about it. If 30 or so W of the raw numbers in these reviews is wasted by the PSU, how much penalty does that put on a 2-3 W CPU vs a 17 W CPU?
Example ... 17 out 70 is much less than 17 out 30 (percent wise), but 2-3 out of 50 is nothing, you are essentially vs 2-3 out 30 is quite a bit different.
If you are thinking of building a very low wattage nettop like computer --- the last thing you want to buy is a 650 W thermaltake toughpower to power you Nano or Atom board. This is a much better power supply to build the system:
http://www.mini-box.com/picoPSU-90-power-kit
And after all is said and done, the peak atom draw will be in the 30-35 range.
Not 60 like they review sites are telling you. In fact, their data is so far off... you should completely disregard any conclusions they make about power efficiency or performance per Watt. I am writing it off as either laziness or groteseque incompetency.
Jack
