here comes a quick shot:
http://i82.photobucket.com/albums/j2...minix-pack.jpg
Looks nice. Specs and $$?
this would make the bestestesest carpc everz!!!!!!!!!!!!!!!!111111111111111111111
Here you go (but no price) - http://www.jwele.com/motherboard_detail.php?419#_spec
I read that overseas it's currently selling for the equivalent of $170. So I would expect ~ $200.
This board is selling for HK$1199. ~=US$154. So I guess the selling price in US will be ~ $175-$180.
is it any good? i mean can it oc to?
If it can OC, i see that as PERFECT for lan parties. A good phenom + 4850 = epic set up.
Shame it didn't incorporate full PCI-E 2.0 X16 slot.... the PCIe slot is a x4 linkwidth only.... 4850 would be choked on that IMO...
Still very nice.... I'd love to have one of these mobos, and a X4 9750 and a compact WC setup, for a compact and portable HTPC...
I feel a new build coming on... :D:D
Ugh, WTF. It's a mini-ITX board guys:ROTF:. Dont expect anything ground breaking for that except very low power purposes.
Although it looks damn nice, it will only be any good for the same reason as any other mini-ITX; SFF/HTPC. If you need to OC with a small PC for Lanparty's, get DFI's JR 790GX-M2RS instead:p:
And thinking about it , you will probabli need a good(big and large) PSU it you want to put a phenom and 4850 (ie) in this board , and that defeats the purpuse.
Going to a lan with a ring that as a PSU bigger than the Mobo:ROTF::rofl:
My 780g is micro and has 16x pcie:up:
A low wattage Athlon X2 + Radeon 4670/4650 would be a pretty good portable-mini-itx-gaming-system-cube. For anything more powerful I'd say MicroATX FTW!
Another one, although it looks exactly the same, just a different name
http://www.vr-zone.com/articles/Alba...oard/6082.html
might be getting 1 or 6 of these. Or not, as I am more interested in the IGP then the PCIe x16 slot. The whole point of me going ITX is the lower power consumption and the IGP being powerful enough paired with a 35w or 45w cpu along with 2gb maybe even 4gb of ram to do what I need. I mean, if you get a vid card that is worth getting over the onboard IGP, then that card is about the size of the mobo and probably eats up 5 times the power or more then the cpu. Might as well just get a M-ATX. But no doubt other people have different uses and want different things from it.
Anyway, anyone know of a 780G ITX board with just PCI or PCIe x1? At least with that I am not limited to only using a vid card in the slot, because either the IGP fullfills the performance I need or I get an M-ATX. And I already know an M-ATX with nvidea 6100 and even Intel extreme 2 IGP performs just about well enough for my needs here, so hopefully the 780G, intel G45 or Nvidea 8200 outperforms a 6100/intel extreme.
Speaking of which, anyone know how the G45 and 8200 compares to the 780G? And if I can use a pico-PSU to power these?
This, a 9150e and a 5400RPM drive would make a nice server that wouldent take away any space.
it doesnt have a parallel port :(
SODIMM ram is pretty cheap now, so I don't think that should be factor in buying decision.
Why have i never realy heard about J&W before?
In Hong Kong and went to Wan Chai computer center in Honk Kong, but very few sellers of ITX boards there and seemingly none of them even know what J&W is, even though it's a Chinese manufacturer and they are located right in Hong Kong. Next day, went to the Golden Computer center in Sham Shui Po and found several sellers there. All had it listed at $1190 HK. I was told that is the lowest price and thye generally don't barter there, so I bought three at that price. Will check out Mongkok later and either buy three more at Mongkok or back to Sham Shui Po. $1190 is @$153, which is less then you can get it at some places online in the US and a few dollars more then one other place. For me though, shipping per board would drastically increase the cost, so I am opting to just buy it while in HK and not pay shipping and will see how RMAing through J&W itself goes if I have problems.
http://img65.imageshack.us/img65/9656/img0790sk5.jpg
http://img90.imageshack.us/img90/9756/img0792nm6.jpg
I found one place in Europe selling this board for 170 Euro+S&H :eek:
There's an alternative: Jetway JNC81. It's cheaper, more widespreaded, but uses GDDR2 as sideport and PCI slot instead of PCI-e
What is this white connector on the bottem right corner?
http://img56.imageshack.us/img56/1051/1217225097du7.jpg
Noticed mine has it, but the first ic in this post dos not. Is it for connecting TFT LCD modules internally?
In the book, it's just listed as the "multifunctional connector" and the discription doesn't say much except to refer to device you are hooking up for more info.
So is it possible to get this in the US?
Herc130
can you please check if it's possible to undervolt the CPU and to what setting
Manual says :But it looks like an LDVS connector, just like the ones in notebooks, used to connect the tft panel...Quote:
14-J1(Multifunctional device connecter) (Optional) :
The connecter may connect external multifunctional device, ,about detail connect way and
definition,please refer to external connect device's manual.
http://linitx.com/ UK store for various mini itx stuff and Jetway boards in particular.
http://www.salland.eu dutch store for j&w board
#1 That is fantasticly nice packaging but who cares.
#2 Whats the dimensions? My Ideq 200n needs a new mobo
You can get the board through US e-sellers. Think Nerds and a couple Amazon stores sell em (probably same stores), as well as ebay. Last I looked, ebay sellers wanted $160+ US, Nerds was @there and NCIX (something like that...the Canada store that also sells to US) was @$146.
Went through Mongkok and they had it listed at $1140 HK, but no one had it in stock. Went back to Golden and bartered the price down to $1100 HK, but that guy only had 1. Next two was hard to find as they were all out of stock everywhere and I ended up paying $1190 again for the last two. 100 HK is $13 us, so whatever. Just hopefully I have no problems with the boards as I can't even check em till I get home. Also picked up 6 Seagate 5400.5 160GB 2.5" HDD's at $350 HK ($46 US). Newegg has Seagate 5400.4 160GB notebook drives at $69. Hopefully the 5400.5 is a better model and I got a good deal :)
Now to find a 45w AM2 cpu. Seen AMD LE 6xxx (supposedly 2.5GHz) cpu's at$280 HK ( @$36 US), but haven't been able to located info on such a cpu online to compare. So am hesitent to buy.
Will when I get home and actually get these up and running. These compters will be turned on alot for me and don't really need to be too powerful, so maybe even an undervolted 45w 2.5GHz will be more then enough.Quote:
