X48 BlackOps PSU Compatibility list
Hey Guys,
To make sure our Boards work with as many PSUs as possible and to help people who build a new system pick a PSU that is know to work well, please post what PSU your using (model no if possible) and let us know if its working fine or you have any issues that could be psu related, such as:
- oc recovery issues, board getting stuck in an endless rebooting loop
- posting issues, board doesnt post properly or at all
- instability, board will shut down under load
Endless rebooting loops can be caused by the psu taking a long time to discharge.
If you turn off the psu, turn it on again and push the power button before the onboard LEDs on the motherboard have turned off, the board might end up in an endless rebooting loop or might not boot properly anymore. to fix this remove the bios battery and put it back after a few minutes.
If you still experience problems please post as many details about the PSU your using or send me or lardarse a private message.
Known to work:
Antec Truepower Trio 650w
Be Quiet Straightpower 650w
Corsair HX520W
Corsair 550W
Corsair HX620W
Corsair TX750W
Corsair HX1000W
Cooler Master Real Power M700
Cooler Master 1000W
Cooler Master Real Power M1000
Cooler Master HX1000
Cooler Master Real Power Pro 1250W
Coolmax CUQ-1200B
Dell 1000w from XPS-H2C
Enermax EG465AX-VE(W)
Enermax Liberty 500W
Enermax MODU82+ 525w
Enermax Modu82+ 625w
Enermax Galaxy 1000W EGX1000EWL
Enermax Revolution 1050W
Etasis ET850
HighPower 1000W Rock Solid
OCZ EliteXStream 1000W
PCPNC 750w
PCPNC 850W
PCPCN 850W SSI
PCPCN 1000W
PCPNC 1200w
Seasonic 600W M12
Seasonic 700W M12
Silverstone Strider 600w
Silverstone 650W
Silverstone Zeus STZF75 750W
Silverstone Zeus STZF85 850W
Silverstone DA-1000
Silverstone Olympia 1000W
Silverstone OP 1000W
Silverstone Strider 1000W (ST1000)
Silverstone OP 1200W
Silverstone Zeus ZM1200M 1200W
Tagan tg430 EasyCon
Tagan 900W
Tagan BZ 1100W
Tagan BZ 1300W
Thermaltake Tough Power 750W
Thermaltake Tough Power 850W
Thermaltake Tough Power 1200W
Ultra X3 1000W
Ultra X3 1600W
Zalman ZM1000-HP
Zippy PSL6701 700W
Might cause problems?
Abit Modular 900W?
Enermax 565W
Enermax Galaxy DXX 1000W?
OCZ GameXstream 700W
confirmed compatibility issues:
Enermax Galaxy DXX 720W - click here for details
If you have several PSUs, it would be really cool if you could check them and boot a couple of times and enter bios and save etc, just to check if they work. this will helps us to find out if there are PSU related issues, and if there are, where they come from and how we can fix them.
thanks a lot in advance! :toast:
EDIT: list updated and sorted alphabeticaly
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated
EDIT: list updated with test results
Hi saaya
You can add this one to the working list
