Hi all,
Do you know if the Fuzion NB block that comes with the Asus Striker II Extreme is made of copper or if it has some aluminium on it (I don't know if the top is just nickel plated or if it is made from alu)?
Also, how can you get 1/2" tubing to fit on it? Adapters? Is there any aftermarket block we can use without removing the heatpipe-heatsink stuff?
Thanks.
