hello!
Have been toying lots of ideas around in my head lately. Came down that the simplest mounting that i had would be the cheapest and the most effective. Prices of mounting used to be unrealistically high until i had a epiphany of simple, due to extremely long machining times on the more complex mountings.Today had some time after my AP test, so i started the mounting. I want to do a small run of 5 evaporators this time, as it saves a lot of time to do a couple at the same time. Ill be posting how everything fits together at the end.
Waiting on a new band saw blade until i do the evaporators, and also waiting on the evaporators done until i cut the insulation donut, but have the donut insulation here.
So ill post what i have so far:
http://img176.imageshack.us/img176/4...untingsdn0.jpg
http://img516.imageshack.us/img516/9...tingkitvd1.jpg
4) 10-32 plastic thumbscrews(may be replaced with smaller ones)
4) 10-32 machine nuts(may be replaced with black plastic ones)
4) 1/2" springs (in mail)
1) 2.5" or so 5/16" copper stub for suction
1) 1.5" or so 3/16" copper stub for cap tube
1) Mounting plate
1) donut insulation, goes around evaporator
1) snap ring for hold down
1) small circle of neoprene for between evaporator and top of mounting.
Not sure about motherboard insulation yet. don't' have a good price on anything at the moment.
Will be re-doing backplates in aluminum. I ordered the wrong size plastic for backplates, and only fit lga775, and barely at that.
Will be finalizing design of the evaporator in the coming days.
Hope you like it
regards
