Fuzion V2 base is not the same as V1
FYI,
Just got done putting some calipers to use on the V1 and V2 side by side.
Total Base Thickness
V1=.220"
V2=.200" (Also machined on the top a little)
Pin Height
V1=.160"
V2=.150"
Base thickness left
V1=.060"
V2=.050"
I think there have been more than cosmetic top changes going on here..:D
This is likely the reason the pressure drop results for V2 are more restrictive than the V1 with washer only. The pins are shorter, so that means a smaller cross section for the water to flow through, but on the posotive it means higher velocity/turbulence/heat transfer.:up:
Time to do some pressure drop testing and thermal testing..:D
