5 Attachment(s)
Custom Project: Black Silverstone TJ-10
First for a little bit of background: I've been involved with PCs for the past 8 yrs and I work at a computer store (not a high performance store). About 1-2yrs ago I decided to build a computer and it was a complete success. I finally decided to perform a much needed overhaul of my computer which I started in December when EVGA offered the 680i to 780i step-up to the older and newer 680i owners. During the seemingly endless wait I started to get into light modding which soon manifested itself into an obsessive hobby.
I'm completely overhauling my computer I wanted to do something "different" that hasn't been done a million times like water cooling the TJ07 (granted, some of them look amazing). The case I choose was the TJ10 which I really like the look of. As far as mods go I’ve already started painting parts black and sound proofing. I wasn’t sure what I should do for loop order but this is my plan (see pic below).
More Pictures Soon!
Current/On Order Hardware:
Case:
Silverstone ESA Edition TJ10B-WESA
Silverstone RadSupport09
Silverstone Aluminum 5.25 inches to 3.5 inches Bay Converter Kit
A.C. Ryan Acrylpanel(tm) Mirror 2
Bitspower X-Station Power Extension I
3A Link Sound Absorption Mats
CPU: Intel Core 2 Quad Q6600 2.4GHz @ 3.6GHz (Slacker)
CPU Cooler: Swiftech Apogee GTX (Copper Top)
Motherboard: EVGA NVIDIA nForce 780i SLI
Motherboard Cooler: EK Acetal 780i Northbridge Water Block, EnzoTech SLF-1, ViperJohn 780i Mosfet Heatsink Kit
Memory: CORSAIR 4GB XMS2 DOMINATOR (4x1GB) DDR2 800
Memory Cooler: CORSAIR CMXAF1 Fans
Graphics: EVGA GeForce 9800 GX2 1GB
Graphics Cooler: EK-FC9800 GX2 SLI - Nickel-Plated
Storage: 4x 150GB Western Digital Raptor X (Raid 0+1)
PSU: Gigabyte 800Watt ODIN GT
Case Fans: 6x 120mm Scythe SFF21E S-FLEX, A.C. Ryan Blackfire4 Kameleon (Special Edition) UV LEDFan - 120mm- Sleeved Silverstone RL-FX121 Case Fan
Lights: A.C. Ryan TWIN Overboost Dual 12" CCFL UV Lights, Sunbeam Tech Dual 12" UV CCD Light Kit
Radiator: Black Ice GT Stealth 240, Black Ice GT Stealth 120
Reservoir: EK-Multioption RES 150 Rev 2, EK Multioption RES Bottom Rev.2
Pump: Swiftech MCP655 12 VDC Pump MCP655-B
Tubing: 13FT - Tygon 1/2" ID (5/8" OD) Tubing with Koolance Tubing Spring Wrap, Black
Fittings:
Bitspower Ultimate G 1/4 Thread 1/2" ID x 5/8" OD Compression Fitting
Bitspower Dual G1/4" High Flow Fitting - Male to Male Thread
Bitspower Multi-Transfer Base (Coupler)
Bitspower G1/4" Stop Fitting with O-ring
Koolance Swiveling Angle Fitting (Low Profile)
Koolance Nozzle Body, Brass
Coolant: Feser One Non Conductive Cooling Fluid - 1000 ml - UV Black
Monitor:
Gateway - 24" Widescreen Flat-Panel TFT-LCD HD Monitor FHD2400
Olevia 37" LCD HDTV LT37HVS
4 Attachment(s)
Case Updates and a New Loop Order!
Sorry for taking so long with these updates! I swear I’ve redesigned this loop 10 times but now I think I’m finally content with it......For now....
The new loop order will be:
Apogee GTX -> EK 150 Reservoir -> D5 -> 120 Radiator -> 9800GX2 Block -> 240 Radiator
In my loop I use Bitspower's 1/2 ID fittings and I need to use 4 of Koolance's elbow fittings, 3 of Bitspower's high flow male-male adapters, and 2 of Bitspower's high flow female-female couplers. How negatively will the elbows and couplers affect my flow? (I would use martins flow rate estimator but it doesn’t have most of my hardware) I would also like to add a drain right before the EK 9800GX2 Water block but I fear this would really hurt my flow.
In the near future I’m hoping to sell my EVGA 780i and 4GB of Corsair Dominator ram and buy a EVGA 790i FTW (assuming its ever released) and 4GB of good DDR3 ram (CAS 5 to 7).
A word of warning to anyone who plans to attempt the 9800GX2 case mod I did: The two holes on the back side of the card (the side facing the mobo) used for holding the two parts of the case together are positioned right over the Southbridge on the 780i. To secure the two sides of the case together I used as single zip tie; unfortunately the zip tie sticks out too far and interferes with my EnzoTech SLF-1 Southbridge cooler. I’m currently working on a solution for this issue.
Silverstone’s Power supply acoustic cover
Its Silverstone’s Power supply acoustic cover. I removed the Silverstone logo and painted it black to match the case.
Here’s the link to it:
http://silverstonetek.com/products/p...=pp02&area=usa
