Another WaterFall Reservoir
This will be the third one so far...
Kennymester ordered another waterfall reservoir.
Here's the pictorial.
http://img441.imageshack.us/img441/4921/pict9016gy8.jpg
Using Ken's Sketchup drawing I made my cut list. When making something that needs 100% perfect alignment it is critical to make all the cuts of the same dimension with tghe same set for the saw at one time. This is also the most time efficient way to proceed.
http://img247.imageshack.us/img247/1564/pict9017et3.jpg
Everything comes out of these pairs of strips cut to 5-1/16" wide and 4-27/32" wide.
http://img301.imageshack.us/img301/3713/pict9018ms6.jpg
Here are all the parts I will need.
http://img380.imageshack.us/img380/4338/pict9019sb3.jpg
Before I can glue anmything up I need to tap a number of ports into the panels...Ken loves reservoirs with lots and lots of ports...this way if I screw up a port I can simply remake the panel form leftover material already cut to width.
http://img262.imageshack.us/img262/6751/pict9020xj6.jpg
My tablesaw fence makes a handy 90 degree angle to work from for the first joint.
http://img380.imageshack.us/img380/7483/pict9021ud6.jpg
Using a capillary appplicator I fuse each joint\ with water-thin solvent.
http://img301.imageshack.us/img301/8369/pict9022xi1.jpg
It is imperative to have true 90 degree corners and perfectly straight and flat and perpendicular edges...each piece also has tgo be exactly the same width.
http://img380.imageshack.us/img380/5360/pict9023vx5.jpg
http://img144.imageshack.us/img144/9728/pict9024lu5.jpg
http://img301.imageshack.us/img301/4360/pict9025gx2.jpg
It's pretty chilly today and the solvent is actually frosting up the needle on the applicator...
http://img389.imageshack.us/img389/8782/pict9026lu3.jpg
http://img380.imageshack.us/img380/1029/pict9027dj9.jpg
http://img530.imageshack.us/img530/3899/pict9028lx4.jpg
I know it's going well when each part fits precisely...but it's one of those things where you can always screw up at the end...
Before I can seal up the reservoir I need to drill and tap the mounting holes and then place a trip of acrylic on the interior over the holes....
http://img441.imageshack.us/img441/2755/pict9029ca5.jpg
Last piece in place. All the joints are fused...
http://img389.imageshack.us/img389/6337/pict9030cd7.jpg
http://img380.imageshack.us/img380/7024/pict9031as0.jpg
There are a number of small smudges and runs that get sanded and polished out...except for the ones in the interior ;) but once filled with liquid they will dissappear.
http://img155.imageshack.us/img155/310/pict9032qh6.jpg
http://img380.imageshack.us/img380/1856/pict9033xt8.jpg
http://img247.imageshack.us/img247/3518/pict9034ui5.jpg
And that's it for tonight. I will let it cure over night and then work on buffing it. Another Kennymester designed WaterFall reservoir.
:thumb:
