http://farm4.static.flickr.com/3156/...3abab93a_o.jpg
Nehalem A1(CPU Frequency 1Ghz ,QPI Frequency 1.66Ghz ,Superpi run 3min..)
http://farm3.static.flickr.com/2260/...8ce4a4f4_o.jpg
Gigabyte 7TESN-RN
Thank Gigabyte to release this picture...XD
Gigabyte 7TESN-RN
That cpu looks big.
Why only pci-e 8x slots on the mobo?
its a server board and nehelam has more pins so its bigger
The MoBo is using Digital PWM without heatsink? I dont think it will last longer, unless servers mobo are different in this area
I think this pic is just for show, as all the other coolers are missing too (NB etc) ;)
I'm wondering, are those landgrids on top of the cpu real
Looks weird.
Well...its an early ES with a low clockspeed- the TDP will probably be low so a small cooler can be used and the test points can be probed?
Is that SuperPi time 1M or 32M? :p:
hmmQuote:
any more info on this?
not any cooling on chipset neither...
Thought has crossed my mind... Maybe they will apply, but just show us some eyecandy? ;)
think so too. a naked board is damn sexy *drools*
Things are rolling out fast!
Tis a showoff pic, heatsinks would def be added later.
If this is really 1M, thats extremely slow for 1GHz clock.
Is that a fb-dimm or r-ddr3 board?
sexy pic of Nehalem A1... i love those Debug contacts... im sure you can change many things on the processor using it ;)
this is the new 1207 or whatever socket?
Those slots on the board doesn't looks like to be FB-DIMMs.
You do know that :banana::banana::banana::banana: is forbidden here? :p:
Can you give more info on the board and the CPU?
what chipset is that? looks like p35? :confused:
thanks for posting this here sxs112! :toast:
Gasp :eek2:
Ummm....isn't that the upcoming (Q2 2008) Gigabyte GA7-TESH series workstation motherboard that was shown at CES? :S
thats hot. sexy sexy
That looks damned good. :cool:
Oh yeah baby!
So the server version has a secretary for a "north bridge" then? :p:
screw on sockets on the board, nice. replaceable in case of bend pin.
replaceable bios, nice but the fan headers a placed screwy.
there has to be cooling added
24-pin power plug on the bottom while both 4 pin plugs are on the top.
why are they so far apart, i foresee mesy wiring
Slick looking setup.. Now we need to get some speed into that bugger
As to SP1M,I can do 15.562s on a dual clover at 3157.
I'd guess a dual Harpertown would be in the 12s range at 4000mhz
Wonder what this will do at even 3000mhz?
Eagerly awaits Intel's phone call telling us to come over and play with it :D :cool:
//Andreas
I don't think you're supposed to release those :) . How'd you get your hands on one.. or is that picture taken in the lab? ;) . B1's should be out in a few weeks ^^.
what about pins side?
Everything I know about engineering( which isn't much) is first make it work, then make it work better(faster,less heat,etc)
My guess is that they start at a slow speed to see if the theory actually works in practice,then look at all the individual components to see any potential flaws and then they start to make it go faster.
Just a guess but maybe closer to the truth than we know.
exactly:up:
most of the time the further steppings always include various speed path fixes to help ramp up the clocks and stomp out performance hampering bugs.
my job is pretty much the same thing. All the PHD guys make the process work (sometimes it only looks like it works), then they give it to my cohorts and I and we make it work safer, with less defects, and faster.
