P5B + Q6600 + latest BIOS == 9x ONLY multiplier??
I just bought a Q6600 to plug into my P5B. Prior to doing so, I upgraded the BIOS to the latest revision. My problem is, I can't LOWER the multiplier. It's stuck at 9x. I want to run at 8x400, but if I set the FSB to 400, it boots at 3.6 GHz, despite the 8x multiplier being set. This used to work on the old revision of the BIOS I had (1102 I think), but that revision doesn't support the Q6600 G0 stepping. Is this a known issue? If so, is there a beta BIOS I can use? Or am I stuck waiting for Asus to fix this? The last BIOS release was over a month ago...surely they would have gotten enough complaints by now that they'd fix this? :(
TIA!
It's stuck at 9x. Here's proof.
Originally Posted by
drynyks
I am 100% positive it isnt working and like I said Ive yet to find 1 post that has anyone using 8x that is working on the p5bs with a Q6600 (g0 at least). You are the first person I have seen that has reported it working. I would guess upon further inspection you would see that it wasnt working and in fact you were running at 3.6ghz. I tested at lower fsb speeds so that even if the 8x was working it would still get in to windows. I had different programs showing different speeds but Im positive it was running at the faster speed. I played with it for a whole night because I really wanted the higher fsb. So at this point rather than speculate someone show it working. Temps are a great indicator and benchmarks will show it. Not the programs that read the speed. did you maybe have a different bios? Im using 1216
I think you're right and the multiplier IS stuck.
I tried to boot at 450x"8". Of course the BIOS reported the CPU at 4 GHz. I started at 1.4875 V and it wasn't stable. I went all the way up to 1.5375, and it still wasn't stable.
So I gave up and decided to try 425x"8". I got all the way up to 1.525 and it wasn't stable.
I then tried 400x"8" and it wasn't even stable at 1.4875. I didn't bother trying to go higher, as it's getting really late. But as a reference point, it's running stable at 378x9 (3.4 GHz) at 1.4375 V. So if 400x"8" is truly 400x8 (3.2 GHz), I would think it'd be stable with 1.4875 V.
I'm really not convinced the multiplier is being honored. If it is, then I can't explain the above. I can't even get it to 400x8 stable??? It's not like a 378 FSB is much lower than 400. 3.4 GHz (9x378) at 1.4375 V
stable, but 3.2 GHz (8x400) at 1.4875 not? Something's wrong here.
If the multiplier is indeed stuck at 9, then it really explains these results. My initial attempt at 450x8 would be 4 GHz and it would make sense that not even 1.5375 V would keep it stable. Likewise, 425x9 (3.8 GHz) wasn't stable with 1.525 V and that also makes sense (I'd think I would need 1.55 or better to do 3.8, and then we're talking water cooling territory).
So can someone explain these results? The only explanation I can come up with is that the multiplier is in fact stuck at 9x.
