Asus P5E3 Deluxe X38 Mainboard Preview!
Good: improved slot layout (compared to other anus boards)
Bad: even with the first x16 lower, it still gets in the way of the RAM latches;
lots of heatpipes;
cramped CPU area
Thanks for posting it, at least I know I'll not be wanting one.
I like the I/O panel and how the IDE and SATA are setup. I'm glad to see the mouse PS/2, serial port and parallel port are history. The more USB ports the better.
seems like a ln2 pot and phase change hell.
think geminii doesnt fit as well?
Sweet, just wondering if my mach2 will fit with all those caps so close to the socket.
Originally Posted by
ataky
hahah you know i was just about to say that.. well i think it can be done but damn that cpu socket is cramped :rolleyes:
and heat pipes again... blaah
well im waiting for reviews before i lay my judgment on this board
looks pretty nice compared to other asus boards
too bad asus sticked to using the stock intel layout around the socket (caps about 1mm form socket edges)
This is nog really good for dice/ln2
El Snorro
I agree, if dfi can do it why not asus?
I"d feel sorry for all the guys with a big typhoon. Try getting your hand down there and screwing in those little nuts to secure the hsf. lol. that would be pure hell.
I simply don't like it.
-PCI slot is not placed were I like it
-I still prefer both mouse/keyboard ports
-wb/hs installation maybe a pain
-not sure if that red ide is for regular ide or raid setup
-sata placement is awkward for my setup
However:
-they finally moved the battery to a location easily accessible
Now...how does it clock? :p
good layout bad color combination hate 8 pin location
Liked the colour
Improved PCI-E 16x location
nice voltage options
Dont like those metal plates on north and south bridges heatspreaders.
4 pin location is in the bad place again
Frank M
Typo? :ROTF:
I can't wait to see this board really performing, see what its worth :up:
Am i the only one seeing only 3 options for the DRam divider?
wasnt x38 supposed to get MORE than other chipset? maybe its just a VERY early Beta bios, but anyway?
You think they would lay off the heatpipes.
And as others have said, this board does NOT support LN2 very well at all. It has one of the most cramped socket areas I've seen in a while.
MaxxxRacer
You could always go Hipro style though :D
Just submerge the entire board in LN2 :p
That's going to be a PITA to insulate.
BeardyMan
lol, I suppose I could do that. But you still have to insulate the backside of the board.
I cant see how the Asus silver plate on top of the cobber is going to help the cooling.
I mean, having your company name on the product is fine. But nerfing the cooling while doing it, is not.
Wel sadly enough these mosfets/components are getting pretty hot so i'm actually glad they provide so much copper...
8 x USB + dual GBit-Ethernet *hooray* who needs LPT nowadays anyway? not me :)
finally a trend I can welcome ^^ the Heatpipe doesn't matter for me because I gonna watercool my mobo anyway ;)
thats to bad. i am disappointed in this board and i had high hopes for it.
1. Way to many large heat pipes limits your air cooling and extreme cooling options and is hard to work with. why can't they just use flipin fans!!!! they work better then heatpipe crap and are way smaller. and just put small ram sink type sinks on the power regulators and vrms.
2. bad slot layout (only 2 PCI)
3. way to much stuff in the CPU area
4. bad power connector layout (bad 8pin placement)
http://my.ocworkbench.com/bbs/showthread.php?t=66437
sum other brands, like the ddr2 dfi the most i guess
Mad1723
Typo? :ROTF:
No :)
Bad Asus = Anus.
And this one has layout issues, so it's an Anus.
C'mon, we're repeating the same things over and over again (VGA-RAM, x16s,
pwr connectors, heatpipes, CPU skt area), yet we see the same mistakes
again and again.
BeardyMan
Yep, but he's one crazy bastard overclocker! :p:
Then again this board will probably be really good for watercooling.
And for phase/ln2?, dont worry, i bet ASUS releases 8 boards with X38 just as they did with P35 :rolleyes:
anus can give you good services :D
Actually I like the power regulation on this board. Sure, it's cramped, but it looks exactly the same as on P5K Premium which is a board that gives very high cpu overclocks compared to the Blitz-boards.
Yay! Even more intrusive heatpipes and copper colored aluminum than ever before!
this is crossfire only ? :confused:
i hear it had crossfire and sli support
Smy
As of today and until nvidia concedes SLi to Intel, officially the X38 chipset supports Crossfire only:(
I like the P5E's and P5E3's expansion slot layout better although the I/O panel is much better on this DELUXE model than the P5E. Between the three, I would probably go for the P5E3 but I'll probably just end up waiting for DFI's X38 boards anyway :yepp:
