Found this link and thought i'd post it:
http://www.cpuid.com/beta/cpuz.zip
anything new with it?
yea im using and i noticed 0 differences compared with 1.40, any info?
nice...correctly reads the voltage on my e6420 now. thanks.
Finally good voltage reading:
http://img518.imageshack.us/img518/347/cpuz14us2.jpg
Check your SPD tab as well. More detailed specs. Also just noticed that the memory tab does as well, but they are grayed out. Prolly why I didn't notice em earlier.
That or my sanity is taking further steps off the rock.
Your guys voltages are working? nice.. mine still are always 1.138v
I love it. Correct voltages, right cpu name, nice memo spd page. Not correct memo freq. (on my notebook)
for me it reads the VID value instead of real vcore, so 1.350 instead of 1.472
please fix
uhmmm wasnt this version released 2 weeks ago?
So far 1.40.5 seems to be latest final anyway..
http://www.cpuid.com/cpuz.php
Shows the Command Rate of my P35 Boards Now :D
this is beta..
Hi guys,
Well I completely rewrote the voltage detection part. If the voltage is not correct (or in case of any other problem), please save a register dump and send it to me (or post it here).
SPD page also displays voltages. This is really relevant if EPP is present, otherwise it will just display the jedec voltage for all frequencies.
Oh and also I included a very beta detection for K10, but nothing really exciting unfortunately, I still miss a lot of information.
Edit : I forgot the last addition : the support for IA64 CPUs (Itanium 1&2)
Here is the old version 1.40.8 showing higher Core VID:
And here is the new beta showing lower voltage :eek:Quote:
CPU-Z version 1.40.5
Processors Map
Number of processors 1
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 2
Number of threads 2 (max 2)
Name Intel Core 2 Duo E6300
Codename Conroe
Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Package Socket 775 LGA (platform ID = 0h)
CPUID 6.F.6
Extended CPUID 6.F
Core Stepping B2
Technology 65 nm
Core Speed 3150.1 MHz (7.0 x 450.0 MHz)
Rated Bus speed 1800.0 MHz
Stock frequency 1866 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 7.0x
max VID 1.213V
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 01008001h
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Function eax ebx ecx edx
0x00000000 0x0000000A 0x756E6547 0x6C65746E 0x49656E69
0x00000001 0x000006F6 0x00020800 0x0000E3BD 0xBFEBFBFF
0x00000002 0x05B0B101 0x005657F0 0x00000000 0x2CB4307D
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x04000121 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04000122 0x01C0003F 0x0000003F 0x00000001
0x00000004 0x04004143 0x01C0003F 0x00000FFF 0x00000001
0x00000005 0x00000040 0x00000040 0x00000003 0x00000020
0x00000006 0x00000001 0x00000002 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000400 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x07280202 0x00000000 0x00000000 0x00000000
0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
0x80000001 0x00000000 0x00000000 0x00000001 0x20000000
0x80000002 0x65746E49 0x2952286C 0x726F4320 0x4D542865
0x80000003 0x43203229 0x20205550 0x20202020 0x20202020
0x80000004 0x30303336 0x20402020 0x36382E31 0x007A4847
0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
0x80000006 0x00000000 0x00000000 0x08006040 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
0x80000008 0x00003024 0x00000000 0x00000000 0x00000000
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0x000000E8 edx = 0x0000017C eax = 0x756D25AE
MSR 0x00000017 edx = 0x00000000 eax = 0x8A048728
MSR 0x000000CD edx = 0x00000000 eax = 0x00000800
MSR 0x0000003F edx = 0x00000000 eax = 0x000000EA
MSR 0x000000CE edx = 0x001B0728 eax = 0x7F7F071B
MSR 0x000001A0 edx = 0x00000044 eax = 0x60950481
MSR 0x000000EE edx = 0xA8000000 eax = 0xC17D4300
MSR 0x0000019C edx = 0x00000000 eax = 0x88250000
MSR 0x00000198 edx = 0x07280728 eax = 0x06000728
MSR 0x00000199 edx = 0x00000000 eax = 0x00000728
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
Type 01008001h
0x00000001 0x000006F6 0x01020800 0x0000E3BD 0xBFEBFBFF
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00800
MSR 0x000000E8 edx = 0x00000325 eax = 0x84518879
MSR 0x0000019C edx = 0x00000000 eax = 0x88230000
Chipset
Northbridge NVIDIA nForce 680i SLI SPP rev. A2
Southbridge NVIDIA 680i SLI MCP rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 450.0 MHz (1:1)
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Cycle Time (tRAS) 12
Bank Cycle Time (tRC) 25
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Manufacturer (ID) Corsair (7F7F9E0000000000)
Size 1024 MBytes
Max bandwidth PC2-6400 (400 MHz)
Part number CM2X1024-6400C4
Manufacturing date Week 23/Year 06
Attributes
Number of banks 2
Data width 64 bits
Correction None
EPP yes (1 profiles)
Timings table
Frequency (MHz) 270 400
CAS# 4.0 5.0
RAS# to CAS# delay 4 5
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
EPP profile 1 (full)
Voltage level 2.100 V
Address Command Rate 2T
Cycle time 2.500 ns (400.0 MHz)
tCL 4.0 clocks
tRCD 4 clocks (10.00 ns)
tRP 4 clocks (10.00 ns)
tRAS 12 clocks (30.00 ns)
tRC 22 clocks (55.00 ns)
tWR 6 clocks (15.00 ns)
DIMM #2
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
tCL 4.0 clocks
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 08 0E 0A 61 40 00 05 25 40 00 82 08 00 00
10 0C 04 30 03 02 00 03 37 50 00 00 32 1E 32 2D 80
20 18 25 05 13 3C 1E 1E 00 00 37 69 80 14 1E 00 56
30 78 6F 3F 26 31 50 2E 65 30 3E 00 00 00 00 12 90
40 7F 7F 9E 00 00 00 00 00 01 43 4D 32 58 31 30 32
50 34 2D 36 34 30 30 43 34 20 20 20 20 20 06 1D 00
60 00 00 00 6D 56 4E B1 10 8C 50 01 20 25 25 10 28
70 28 1E 3C 37 FF FF FF FF FF FF FF FF FF FF FF FF
Dump Module #2
Monitoring
Sensor Chip Winbond W83627DHG
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03A1
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Capabilities
HyperTransport Capability
Offset 40h
Revision 0.16
Interface type Host/Secondary
Device number 0
Link 0 width (in/out) 8 bits/8 bits
Link 0 frequency 1000MHz
Dump
00 DE 10 A1 03 06 00 B0 00 A2 00 00 06 00 00 80 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 DE 10 5E C5
30 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
40 08 00 01 20 22 00 00 00 10 26 3F 00 03 01 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 21 49 44 44 13 01 00 00 00 00 00 00 10 00 00 00
70 07 05 22 00 00 00 00 00 81 01 85 01 00 00 00 00
80 00 00 00 00 00 00 00 00 70 00 00 80 00 00 00 00
90 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00
B0 CB 10 00 02 F4 FF 00 00 00 00 00 00 00 00 00 00
C0 11 31 03 00 31 00 00 10 0B 00 00 00 00 50 07 00
D0 01 0A 00 00 00 00 00 00 FF FF 71 07 10 00 00 00
E0 08 00 01 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
F0 00 E4 FF FF 00 00 00 00 00 00 00 00 00 00 00 00
RAM Memory Controller
bus 0 (0x00), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03AC
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 AC 03 00 00 20 00 A1 00 00 05 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 21 21 16 00 11 11 00 00 04 00 00 00
60 21 08 12 06 DE 8F E1 1F 08 42 48 18 22 8F 00 20
70 10 32 54 0A 10 00 00 00 20 00 00 00 1F 00 FD 00
80 00 00 00 00 03 00 00 00 00 00 50 3F 90 7F 00 00
90 08 10 00 FE FD 00 00 00 FC FF FF FF FF 00 01 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 08 10 00 FE FD 01 01 B0 01 1D 00 00 80 F9 FD 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 C7 02 28 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03AA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 AA 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 DE 10 5E C5 2C D8 20 81 00 00 02 00 2C D8 12 00
50 00 00 00 00 00 00 00 00 00 00 00 00 86 20 1D 61
60 21 40 56 4E FF FF 00 00 FF FF 00 00 FF FF 00 00
70 FF FF 00 00 11 40 56 00 03 2C 1C 80 03 2C 1C 00
80 00 00 00 00 01 00 00 00 07 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 20 00 72 0B 00 00 00 31 65 07 00
C0 FF FF FF FF FF FF FF BF 00 00 00 00 77 80 77 00
D0 00 21 09 00 01 00 00 00 00 00 00 00 00 00 00 00
E0 80 00 52 00 92 14 00 00 80 00 4B 61 64 02 13 00
F0 1B 1B 1B 1B 00 FF 21 00 77 77 77 77 00 00 0F 80
bus 0 (0x00), device 0 (0x00), function 3 (0x03)
Common header
Vendor ID 0x10DE
Model ID 0x03A9
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 A9 03 06 00 A0 00 A1 00 00 05 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00
40 DE 10 5E C5 00 00 00 00 04 28 1C 80 04 20 1C A0
50 04 18 1C 90 04 20 1C 90 04 28 1C 90 04 18 1C 80
60 04 20 1C 80 04 28 1C 80 04 30 1C 80 04 38 1C 80
70 02 20 1C 80 1F 20 00 C0 02 00 00 00 00 00 00 00
80 00 00 00 00 47 10 BE F4 02 1F 1C 80 60 10 00 40
90 8D DA 01 09 00 00 00 00 11 00 01 00 00 00 00 00
A0 00 00 80 99 80 00 00 00 19 00 A8 61 00 00 00 00
B0 00 00 00 00 80 1E 00 00 00 00 02 00 01 84 01 84
C0 FF FF FF FF 00 00 00 00 1C 00 00 00 00 00 00 00
D0 00 00 00 00 20 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 10 10 18 00 00 40 01 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 4 (0x04)
Common header
Vendor ID 0x10DE
Model ID 0x03AB
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 AB 03 06 00 A0 00 A1 00 00 05 00 00 00 00
40 DE 10 5E C5 00 00 00 00 00 00 00 00 00 00 00 00
50 43 88 30 02 22 80 02 08 20 00 01 0A 81 10 21 06
60 43 08 11 08 84 08 31 02 22 90 B5 18 8C 31 A5 1C
70 6B A5 B4 12 29 31 11 08 85 10 84 0A A5 90 94 18
80 CB 38 D7 1C E6 A0 34 08 00 00 00 00 00 00 00 00
90 20 80 01 00 43 08 01 00 00 00 00 00 00 00 00 00
A0 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00
E0 01 00 00 00 22 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 5 (0x05)
Common header
Vendor ID 0x10DE
Model ID 0x03A8
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 A8 03 04 00 A0 00 A2 00 00 05 00 00 80 00
40 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 6 (0x06)
Common header
Vendor ID 0x10DE
Model ID 0x03B5
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 B5 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 00 F0 0F 3F 00 00 00 00 00 00 00 00 00 00 00 00
50 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 0 (0x00), function 7 (0x07)
Common header
Vendor ID 0x10DE
Model ID 0x03B4
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
00 DE 10 B4 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 DE 10 5E C5 00 00 00 00 00 00 00 00 11 00 00 00
50 00 00 00 00 60 00 00 00 00 00 00 00 00 00 00 00
B0 FF FF FF FF FF FF FF FF 10 21 00 00 AC 00 20 00
C0 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03AD
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 AD 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 10 01 00 00 3F 44 04 00 00 00 00 00 00 00 00 00
50 08 F8 F0 A0 0C 0C 04 7E 0C 00 00 00 02 2B 7F 04
60 55 00 52 00 00 00 00 00 00 00 00 00 33 00 20 00
70 36 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 3F 63 00 00 00 00 00 00 00 00 00 00 00 30 0C 44
90 46 B9 23 40 50 A4 94 35 0D 34 22 65 03 04 33 12
A0 00 00 19 19 F0 11 02 00 20 00 27 01 00 00 00 00
B0 00 80 00 80 00 80 00 80 00 80 00 80 00 80 00 80
D0 31 26 61 24 31 26 61 24 31 26 61 24 31 26 61 24
E0 03 00 00 00 10 08 71 0F F1 01 00 00 11 11 70 11
F0 10 18 FF 08 08 10 03 04 11 00 00 00 53 03 77 40
bus 0 (0x00), device 1 (0x01), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03AE
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 AE 03 00 00 20 00 A1 00 00 05 00 00 80 00
50 00 00 00 00 FF FF 07 00 00 00 00 00 27 5E 00 80
60 01 01 00 00 10 10 00 00 01 01 00 00 10 10 00 00
70 01 08 A0 CE 00 00 00 00 01 08 A0 CE 00 00 00 00
80 01 10 00 16 23 40 F0 03 10 00 40 00 10 40 F0 00
90 13 00 00 10 00 00 00 10 00 00 00 10 00 00 00 10
A0 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 DE 06 82 81 20 00 00 00 01 01 00 00
D0 4A 0A 00 01 04 00 10 00 00 00 20 00 00 00 30 00
E0 80 74 AA 0A 80 77 AA 0A 00 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03AF
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 AF 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 D0 00 00 00 00 00 00 00 5C 17 5C 80 1B 03 00 06
50 74 00 02 00 26 00 08 11 FF 7F FF FF 7F 7F 7F 3F
60 F8 FF 03 04 0E 00 00 00 2E 80 8A 00 00 00 00 00
70 01 01 01 01 08 00 B1 3C 0A 22 07 07 50 00 F2 02
80 95 13 00 00 21 F2 CE FB E1 00 51 00 00 00 00 00
90 08 00 3F 70 08 00 1F 0C 08 0F 17 00 08 0F 18 00
A0 50 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00
F0 FF FF 00 02 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 3 (0x03)
Common header
Vendor ID 0x10DE
Model ID 0x03B0
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 B0 03 00 00 20 00 A1 00 00 05 00 00 80 00
50 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 71 71 00 00 55 00 00 00 44 14 00 00 44 00 00 00
70 55 00 00 00 44 14 00 00 44 00 00 00 05 02 03 04
80 03 02 02 00 00 40 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 22 22 22 22 21 32 22 31 77 77 77 77
A0 77 77 77 77 AE 0A E0 00 08 0A 0F 0F 08 09 08 09
B0 0C 0A 0E 0F 09 0C 0B 00 FF FF 03 00 00 07 00 00
C0 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
D0 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
E0 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
F0 00 07 00 00 00 07 00 00 00 07 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 4 (0x04)
Common header
Vendor ID 0x10DE
Model ID 0x03B1
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 B1 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 73 7F 00 00 FF FF 03 00 98 3A 30 80 80 01 00 02
50 00 00 00 00 1F 1F 00 00 0F 0F 0F 0F F4 F1 41 00
60 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F F0 F1 41 00
70 0F 0F 0F 0F 0F 0F 0F 0F 07 00 00 00 0F 0F 00 00
80 0F 0F 00 00 F0 F1 41 00 0F 0F 0F 0F 0F 0F 0F 0F
90 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F 0F
A0 0F 0F 0F 0F F0 F1 41 04 0F 0F 0F 0F 0F 0F 0F 0F
B0 03 01 00 00 40 24 44 11 42 44 45 44 64 64 44 00
C0 00 00 00 04 00 00 00 04 00 00 00 00 0C 00 04 00
D0 03 00 04 00 0F 0F 00 00 0F 0F 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 44 00 00 00 44 00 00 00
F0 FF FF 00 02 00 00 00 00 0F 0F 0F 0F 0F 0F 0F 0F
bus 0 (0x00), device 1 (0x01), function 5 (0x05)
Common header
Vendor ID 0x10DE
Model ID 0x03B2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 B2 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 F9 01 A0 0A 00 00 00 00 00 00 00 00 00 00 00 00
bus 0 (0x00), device 1 (0x01), function 6 (0x06)
Common header
Vendor ID 0x10DE
Model ID 0x03B3
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 B3 03 00 00 20 00 A1 00 00 05 00 00 80 00
40 00 00 00 00 33 33 33 33 00 00 00 00 33 33 33 33
70 00 00 00 00 00 00 00 00 00 07 00 00 00 07 00 00
80 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
90 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
A0 00 07 00 00 00 07 00 00 00 07 00 00 00 07 00 00
B0 00 07 00 00 00 07 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 07 07 07 07 88 88 88 88 88 88 88 88
D0 00 00 00 00 00 00 00 00 40 40 40 40 88 88 77 00
F0 00 00 00 00 88 88 88 88 88 88 88 88 00 01 02 00
bus 0 (0x00), device 2 (0x02), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03B6
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 B6 03 00 00 20 00 A1 00 00 05 00 00 80 00
50 00 08 00 00 00 00 20 00 00 00 00 00 00 00 00 00
70 74 D6 04 B7 80 42 77 99 C4 86 73 BC A4 06 50 40
80 40 05 40 64 1C 62 86 31 00 00 00 00 00 00 00 00
bus 0 (0x00), device 2 (0x02), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x03BC
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 BC 03 06 00 A0 00 A1 00 00 05 00 00 00 00
bus 0 (0x00), device 2 (0x02), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x03BA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 BA 03 00 00 20 00 A1 00 00 05 00 00 80 00
70 FF FF 0F 00 00 00 00 00 00 00 00 00 00 00 00 00
90 44 44 44 11 40 64 43 64 64 64 44 00 00 00 00 04
A0 00 00 00 04 00 00 00 00 06 00 00 00 03 00 00 00
B0 41 45 54 00 40 04 40 04 00 00 00 00 00 00 00 00
C0 10 00 04 00 09 00 04 00 51 45 55 00 40 04 40 04
D0 00 00 00 00 00 00 00 00 13 00 00 00 09 00 00 00
E0 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40
PCI to PCI Bridge
bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x03B7
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Subsystem Vendor Capability
Offset 40h
Subsystem ID 0x0C55
Sub. Vendor ID 0x10DE
Power Management Capability
Offset 48h
Version 1.1
Message Signalled Interrupts Capability
Offset 50h
Offset 60h
Interface type MSI mapping
PCI Express Capability
Offset 80h
Device type Root Port of PCI-E Root Complex
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Link width 16x (max 16x)
Extended capabilities
Virtual Channel
Offset 100h
Dump
00 DE 10 B7 03 07 00 10 00 A1 00 04 06 10 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 91 91 00 00
20 00 CA F0 CD 01 B0 F1 BF 00 00 00 00 00 00 00 00
30 00 00 00 00 40 00 00 00 00 00 00 00 FF 00 0C 00
40 0D 48 00 00 DE 10 55 0C 01 50 02 F8 00 00 00 00
50 05 60 82 00 00 00 00 00 00 00 00 00 00 00 00 00
60 08 80 00 A8 00 00 E0 FE 00 00 00 00 00 00 00 00
80 10 00 41 01 01 80 00 00 10 28 00 00 01 35 11 00
90 40 00 01 31 00 00 00 00 C0 01 48 01 00 00 00 00
bus 0 (0x00), device 9 (0x09), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0369
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 44h
Revision 1.03
Interface type Slave/Primary
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
PCI Capability class 0x0
Offset E0h
Dump
00 DE 10 69 03 06 00 B0 00 A1 00 00 05 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 00 00 00
40 DE 10 5E C5 08 E0 E9 01 22 20 11 00 D0 00 00 00
50 23 06 7F 00 03 00 00 00 00 00 03 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 06 06 0A 00
70 44 44 44 00 50 09 00 00 11 00 00 00 11 11 88 00
80 23 99 88 00 FA 00 64 0E 02 00 00 00 7F 00 00 00
90 70 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 01 01 01 01 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 80 00 0F 0F
D0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 A8
E0 00 00 E0 FE 00 00 00 00 00 00 80 00 F0 FF D0 00
PCI to ISA Bridge
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0360
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000FC00
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
00 DE 10 60 03 0F 00 A0 00 A2 00 01 06 00 00 80 00
10 01 FC 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 DE 10 5E C5 00 00 FF FE FA 3E FF 00 FA 3E FF 00
50 FA 3E FF 00 00 5A 62 02 00 00 00 01 00 00 FE 7F
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F9 FF
70 10 00 FF FF C9 00 00 00 00 00 45 19 00 C0 03 00
80 09 10 00 21 82 D2 00 80 FC 00 00 01 F0 00 00 00
90 00 08 33 00 00 00 00 00 21 47 95 86 EF CD AB 00
A0 01 00 10 80 00 00 01 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 95 02 F4 02 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 50 70 00 FE FD 02 00 B0
F0 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00
SMBus Controller
bus 0 (0x00), device 10 (0x0A), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0368
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000F800
Address 4 (port) 0x0000F400
Address 5 (port) 0x0000F000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 68 03 01 00 B0 00 A2 00 05 0C 00 00 80 00
10 01 F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 F4 00 00 01 F0 00 00 00 00 00 00 DE 10 5E C5
30 00 00 00 00 44 00 00 00 00 00 00 00 FF 01 00 00
40 DE 10 5E C5 01 00 02 C0 00 00 00 00 00 00 00 00
60 01 10 00 00 01 14 00 00 01 18 00 00 00 00 C8 FE
70 01 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00
C0 D4 30 80 00 01 00 00 00 00 00 00 00 00 00 00 00
E0 B4 10 04 00 F7 7B 00 43 80 30 00 00 46 44 44 11
F0 5A FF 5F 3F 00 00 00 C0 10 00 00 00 00 00 00 00
USB Controller (OHCI)
bus 0 (0x00), device 11 (0x0B), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x036C
Revision ID 0xA1
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xCFFFF000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 6C 03 07 00 B0 00 A1 10 03 0C 00 00 80 00
10 00 F0 FF CF 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 03 01
40 DE 10 5E C5 01 00 02 FE 00 00 00 00 00 00 00 00
50 40 03 00 00 1D 47 40 00 10 00 00 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 11 (0x0B), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x036D
Revision ID 0xA2
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xCFFFE000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x17
Int. Pin 0x02
Capabilities
Debug Port Capability
Offset 44h
Offset 80h
Version 1.1
Dump
00 DE 10 6D 03 06 00 B0 00 A2 20 03 0C 00 00 80 00
10 00 E0 FF CF 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 17 02 03 01
40 DE 10 5E C5 0A 80 98 20 00 00 00 00 00 00 00 00
60 20 20 01 00 00 60 18 85 03 3C 3F 01 00 00 00 00
70 00 00 08 05 00 10 20 80 89 3D B6 22 77 25 04 00
80 01 00 02 FE 00 00 00 00 00 00 00 00 15 16 00 00
90 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 01 00 00 00 00 00 00 C0 00 00 00 00 00 00 00 00
B0 22 33 44 00 11 00 00 00 FF 03 00 00 00 00 00 00
C0 10 10 2D 0D 00 00 00 00 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x036E
Revision ID 0xA1
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 4 (port) 0x0000EC00
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Version 1.1
Dump
00 DE 10 6E 03 05 00 B0 00 A1 8A 01 01 00 00 00 00
20 01 EC 00 00 00 00 00 00 00 00 00 00 DE 10 5E C5
30 00 00 00 00 44 00 00 00 00 00 00 00 00 00 03 01
40 DE 10 5E C5 01 00 02 00 00 00 00 00 00 00 00 00
50 02 F0 00 00 00 00 00 00 A8 A8 20 20 6A 00 99 20
60 00 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 F4 44 ED 3A 00 00 9E 1F 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01
IDE Controller
bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009F0
Address 1 (port) 0x00000BF0
Address 2 (port) 0x00000970
Address 3 (port) 0x00000B70
Address 4 (port) 0x0000D800
Address 5 (memory) 0xCFFFD000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
00 DE 10 7F 03 07 00 B0 00 A2 85 01 01 00 00 80 00
10 F1 09 00 00 F1 0B 00 00 71 09 00 00 71 0B 00 00
20 01 D8 00 00 00 D0 FF CF 00 00 00 00 DE 10 5E C5
40 DE 10 5E C5 01 B0 02 00 00 00 00 00 00 00 00 00
50 0F 78 08 80 00 00 00 00 A8 A8 A8 A8 AA 00 99 99
60 00 00 00 00 41 0C 00 00 00 0F 06 42 00 00 00 00
70 2C 78 C4 40 01 10 00 00 01 10 00 00 20 00 20 00
80 00 00 00 00 FF FF FD F7 00 00 7D 2F 9B EF FE FF
90 00 00 6C 1C 00 00 00 00 06 00 06 10 7F 03 01 01
A0 12 0A 00 00 80 00 00 00 00 00 00 00 33 31 00 02
B0 05 CC 84 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 0A 00 0A 00 08 00 02 A8
D0 0A 00 02 03 42 00 00 00 00 00 00 00 0E 00 00 00
E0 0A 00 02 03 42 00 00 00 00 00 00 00 00 00 E0 07
F0 00 00 00 00 00 00 00 00 10 00 0C 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 14 (0x0E), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x000009E0
Address 1 (port) 0x00000BE0
Address 2 (port) 0x00000960
Address 3 (port) 0x00000B60
Address 4 (port) 0x0000C400
Address 5 (memory) 0xCFFFC000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x17
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
10 E1 09 00 00 E1 0B 00 00 61 09 00 00 61 0B 00 00
20 01 C4 00 00 00 C0 FF CF 00 00 00 00 DE 10 5E C5
80 00 00 00 00 FF BB FD 9B 00 00 06 33 3D FD AE F9
90 00 00 17 22 00 00 00 00 06 00 06 10 7F 03 01 01
D0 0A 00 02 03 42 00 00 00 00 00 00 00 0F 00 00 00
E0 0A 00 02 03 42 00 00 00 00 00 00 00 00 00 40 07
IDE Controller
bus 0 (0x00), device 14 (0x0E), function 2 (0x02)
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (port) 0x0000C000
Address 1 (port) 0x0000BC00
Address 2 (port) 0x0000B800
Address 3 (port) 0x0000B400
Address 4 (port) 0x0000B000
Address 5 (memory) 0xCFFFB000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x14
Int. Pin 0x03
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
10 01 C0 00 00 01 BC 00 00 01 B8 00 00 01 B4 00 00
20 01 B0 00 00 00 B0 FF CF 00 00 00 00 DE 10 5E C5
30 00 00 00 00 44 00 00 00 00 00 00 00 14 03 03 01
50 0F 78 08 80 00 00 00 00 A8 20 A8 20 66 00 20 20
60 00 C7 00 C7 41 0C 00 00 00 0F 06 42 00 00 00 00
80 00 00 00 C0 00 60 B3 07 00 00 08 80 00 60 B3 07
90 00 00 08 A0 00 00 00 00 06 00 06 10 7F 03 01 01
A0 12 0A 00 18 80 00 00 00 00 00 00 00 33 31 00 02
D0 0A 00 02 03 42 00 00 00 00 00 00 00 00 00 50 E1
E0 0A 00 02 03 42 00 00 00 00 00 00 00 00 00 90 E7
PCI to PCI Bridge
bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0370
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset B8h
Subsystem ID 0xCB84
Offset 8Ch
Dump
00 DE 10 70 03 07 01 B0 00 A2 01 04 06 00 00 81 00
10 00 00 00 00 00 00 00 00 00 02 02 20 F0 00 80 02
20 F0 FF 00 00 F0 FF 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 B8 00 00 00 00 00 00 00 FF 00 04 0A
40 00 00 33 07 01 00 02 00 05 00 00 00 00 00 48 00
50 00 00 FE 7F 00 00 00 00 E8 1F FF 1F 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 FE FF 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 A8
90 00 00 E0 FE 00 00 00 00 00 00 00 00 00 00 00 00
A0 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 FF FF 00 00 0D 8C 00 00 DE 10 84 CB
C0 DE 10 84 CB 03 00 00 00 00 00 00 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 15 (0x0F), function 1 (0x01)
Common header
Vendor ID 0x10DE
Model ID 0x0371
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Address 0 (memory) 0xCFFF0000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset 50h
Offset 6Ch
Dump
00 DE 10 71 03 06 00 B0 00 A2 00 03 04 00 00 80 00
10 00 00 FF CF 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 15 02 02 05
40 DE 10 5E C5 01 50 02 C0 00 00 00 00 01 01 0F 00
50 05 6C 80 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 0F 00 00 00 08 00 02 A8
F0 00 00 00 00 00 00 00 47 10 29 00 00 00 00 00 00
Bridge device
bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0373
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCFFFA000
Address 1 (port) 0x0000AC00
Address 2 (memory) 0xCFFF9000
Address 3 (memory) 0xCFFF8000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
MSI-X Capability
Offset 70h
Offset 50h
Offset 6Ch
Dump
00 DE 10 73 03 07 00 B0 00 A2 00 80 06 00 00 00 00
10 00 A0 FF CF 01 AC 00 00 00 90 FF CF 00 80 FF CF
30 00 00 00 00 44 00 00 00 00 00 00 00 16 01 01 14
40 DE 10 5E C5 01 70 02 FE 00 00 00 00 0C 00 00 00
50 05 6C 86 01 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 FF 00 00 00 08 00 02 A8
70 11 50 07 00 02 00 00 00 03 00 00 00 00 00 00 00
F0 00 00 00 00 11 00 00 00 52 01 00 00 00 00 00 00
Bridge device
bus 0 (0x00), device 18 (0x12), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0373
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCFFF7000
Address 1 (port) 0x0000A800
Address 2 (memory) 0xCFFF6000
Address 3 (memory) 0xCFFF5000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
MSI-X Capability
Offset 70h
Offset 50h
Offset 6Ch
Dump
10 00 70 FF CF 01 A8 00 00 00 60 FF CF 00 50 FF CF
30 00 00 00 00 44 00 00 00 00 00 00 00 14 01 01 14
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x10DE
Model ID 0x0191
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Address 0 (memory) 0xCC000000
Address 1 (memory) 0xB0000000
Address 3 (memory) 0xCA000000
Address 5 (port) 0x00009C00
Subvendor ID 0x3842
Subsystem ID 0xC831
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Offset 68h
Offset 78h
Device type PCI-E Endpoint Device
Port 0
Version 1.0
Virtual Channel
Offset 100h
Power Budgeting Capability
Offset 128h
Dump
00 DE 10 91 01 07 00 10 00 A2 00 00 03 10 00 00 00
10 00 00 00 CC 0C 00 00 B0 00 00 00 00 04 00 00 CA
20 00 00 00 00 01 9C 00 00 00 00 00 00 42 38 31 C8
30 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
40 42 38 31 C8 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
60 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
70 00 00 00 00 00 00 00 00 10 00 01 00 80 04 00 00
80 10 28 00 00 01 2D 01 00 48 00 01 11 00 00 00 00
OHCI FireWire Controller
bus 2 (0x02), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x104C
Model ID 0x8023
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x02
Header 0x00
PCI header
Address 0 (memory) 0xCFDFF000
Address 1 (memory) 0xCFDF8000
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
00 4C 10 23 80 06 00 10 02 00 10 00 0C 10 02 00 00
10 00 F0 DF CF 00 80 DF CF 00 00 00 00 00 00 00 00
30 00 00 00 00 44 00 00 00 00 00 00 00 13 01 02 04
40 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00
F0 00 00 00 00 00 00 00 00 DE 10 5E C5 00 00 00 00
DMI
DMI BIOS
vendor Phoenix Technologies, LTD
version 6.00 PG
date 06/30/2007
DMI System Information
manufacturer EVGA
product 122-CK-NF68
version 2
serial 1
UUID 05808080-4B040000-06808080-4B040000
DMI Baseboard
vendor EVGA
model 122-CK-NF68
revision 2
serial 1
DMI System Enclosure
manufacturer EVGA
chassis type Desktop
chassis serial unknown
DMI Processor
manufacturer Intel
model Intel(R) Core(TM)2 CPU
clock speed 3143.0MHz
FSB speed 449.0MHz
multiplier 7.0x
DMI Memory Controller
correction unknown
Max module size 32MBytes
DMI Memory Module
designation A0
size 1024MBytes (double bank)
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
designation PRIMARY IDE (internal)
connector On Board IDE
DMI Port Connector
designation FDD (internal)
port type 8251 FIFO Compatible
connector On Board Floppy
DMI Port Connector
designation COM1 (internal)
port type Serial Port 16450
connector 9 Pin Dual Inline (pin 10 cut)
connector DB-9 male
DMI Port Connector
designation Keyboard (internal)
port type Keyboard Port
connector PS/2
connector PS/2
DMI Port Connector
designation PS/2 Mouse (internal)
port type Mouse Port
connector PS/2
connector PS/2
DMI Port Connector
designation USB0 (external)
port type USB
DMI Port Connector
designation USB1 (external)
port type USB
DMI Port Connector
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (external)
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 2048MBytes
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type DRAM
total width 128bits
data width 128bits
size 1024MBytes
DMI Memory Device
designation A1
format DIMM
type DRAM
total width 128bits
data width 128bits
size 1024MBytes
DMI Memory Device
designation A2
format DIMM
type DRAM
DMI Memory Device
designation A3
format DIMM
type DRAM
Software
Windows Version Microsoft Windows XP Home Edition Service Pack 2 (Build 2600)
DirectX Version 9.0c
Resources
Port I/O Space, BA=0xCF8, size=0x8
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xF800
Port I/O Space, BA=0xF400
Port I/O Space, BA=0xF000
Memory I/O Space, BA=0x00000000CFFFF000
Memory I/O Space, BA=0x00000000CFFFE000
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0x9F0
Port I/O Space, BA=0xBF0
Port I/O Space, BA=0x970
Port I/O Space, BA=0xB70
Port I/O Space, BA=0xD800
Memory I/O Space, BA=0x00000000CFFFD000
Port I/O Space, BA=0x9E0
Port I/O Space, BA=0xBE0
Port I/O Space, BA=0x960
Port I/O Space, BA=0xB60
Port I/O Space, BA=0xC400
Memory I/O Space, BA=0x00000000CFFFC000
Port I/O Space, BA=0xC000
Port I/O Space, BA=0xBC00
Port I/O Space, BA=0xB800
Port I/O Space, BA=0xB400
Port I/O Space, BA=0xB000
Memory I/O Space, BA=0x00000000CFFFB000
Memory I/O Space, BA=0x00000000CFFF0000
Memory I/O Space, BA=0x00000000CFFFA000
Port I/O Space, BA=0xAC00
Memory I/O Space, BA=0x00000000CFFF9000
Memory I/O Space, BA=0x00000000CFFF8000
Memory I/O Space, BA=0x00000000CFFF7000
Port I/O Space, BA=0xA800
Memory I/O Space, BA=0x00000000CFFF6000
Memory I/O Space, BA=0x00000000CFFF5000
Memory I/O Space, BA=0x00000000CC000000
Memory I/O Space, BA=0x00000000B0000000
Memory I/O Space, BA=0x00000000CA000000
Port I/O Space, BA=0x9C00
Memory I/O Space, BA=0x00000000CFDFF000
Memory I/O Space, BA=0x00000000CFDF8000
Memory I/O Space, BA=0x00000000E0000000, size=0x1000
Port I/O Space, BA=0x1008, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
CPU-Z version 1.40.8
Processors Map
Number of threads 2
Processor 0
-- Core 0
-- Thread 0
-- Core 1
-- Thread 0
Number of cores 2
Codename Conroe
CPUID 6.F.6
Extended CPUID 6.F
Core Stepping B2
Technology 65 nm
Core Speed 3150.6 MHz (7.0 x 450.1 MHz)
Rated Bus speed 1800.3 MHz
FID/VID Control yes
max VID 1.213 V
Thread dumps
CPU Thread 0
APIC ID 0
Type 01008001h
MSR 0x000000E8 edx = 0x0000017E eax = 0xBF4A533E
CPU Thread 1
APIC ID 1
Type 01008001h
MSR 0x000000E8 edx = 0x0000032A eax = 0x39975DD0
Chipset
Memory Type DDR2
Memory Frequency 450.1 MHz (1:1)
CAS# 4.0
RAS# to CAS# 4
RAS# Precharge 4
Command Rate 2T
Memory SPD
DIMM #1
General
Memory type DDR2
Module format Regular UDIMM
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Nominal Voltage 1.80 Volts
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
Voltage level 2.100 Volts
tCL 4.0 clocks
DIMM #2
General
Memory type DDR2
Size 1024 MBytes
Attributes
Number of banks 2
Data width 64 bits
Correction None
Timings table
CAS# 4.0 5.0
RAS# Precharge 4 5
TRAS 13 18
TRC 15 22
tCL 4.0 clocks
Dump Module #1
Dump Module #2
Monitoring
Mainboard Model 122-CK-NF68 (0x27F - 0x5801680)
LPCIO
Vendor Winbond
Model W83627DHG
Vendor ID 0x5CA3
Chip ID 0xA0
Revision ID 0x23
Config Mode I/O address 0x2E
Dump config mode register space, LDN = 0xB
00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
20 A0 23 FF 00 14 00 00 FF 50 00 7E C0 EA 21 00 FF
30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Hardware monitor ID=0xC1 hardware monitor
Dump hardware monitor
LPC Register space, base address = 0x0290
00 84 FF 04 FF 00 00 30 30 01 80 01 C0 3C 3C 0A 0A
10 84 FF 50 00 00 01 01 3C 43 37 00 00 FF FF FF C0
20 9C E0 CC CC 96 C5 E2 BF FF 47 FF DA 00 01 20 EE
30 B4 A8 00 80 BC 0A 88 85 80 00 7F 81 29 02 38 FF
40 01 FA 1F FF FF FF 07 D4 28 00 40 44 18 15 00 A3
50 FF FF 00 FF FF FF 00 00 C1 33 FF FF 00 07 04 05
60 84 FF 03 25 80 C0 3C FF 0A FF 0A FF FF FF FF FF
70 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
80 84 FF 04 FF 00 00 30 30 01 80 01 C0 3C 3C 0A 0A
90 84 FF 50 00 00 01 01 3C 43 37 00 00 FF FF FF C0
A0 9C E0 CC CC 96 C5 E2 BF FF 47 FF DA 00 01 20 EE
B0 B4 A8 00 80 BC 0A 88 85 80 00 7F 81 29 02 38 FF
C0 01 00 10 FF FF FF 07 D4 28 00 40 44 18 15 00 A3
D0 FF FF 00 FF FF FF 00 00 C1 33 FF FF 00 07 04 05
E0 84 FF 03 25 80 C0 3C FF 0A FF 0A FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor
Intel Core 2 Duo E6300 hardware monitor
Temperature sensor 0 48°C (118°F) [0x25] (core #0)
Temperature sensor 1 50°C (121°F) [0x23] (core #1)
PCI Device List
Host Bridge
Common header
Vendor ID 0x10DE
Model ID 0x03A1
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 40h
Revision 0.16
Device number 0
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03AC
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03AA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03A9
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
B0 00 00 00 00 86 1E 00 00 00 00 02 00 01 84 01 84
Common header
Vendor ID 0x10DE
Model ID 0x03AB
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03A8
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B5
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B4
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03AD
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03AE
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
E0 83 22 F3 35 03 22 F3 35 00 00 00 00 00 00 00 00
Common header
Vendor ID 0x10DE
Model ID 0x03AF
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B0
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
B0 0C 0A 0E 0F 09 0C 0B 00 00 01 02 00 00 07 00 00
Common header
Vendor ID 0x10DE
Model ID 0x03B1
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B2
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B3
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03B6
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03BC
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
Common header
Vendor ID 0x10DE
Model ID 0x03BA
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
PCI to PCI Bridge
Common header
Vendor ID 0x10DE
Model ID 0x03B7
Revision ID 0xA1
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x10
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 40h
Subsystem ID 0x0C55
Offset 48h
Version 1.1
Offset 50h
Offset 60h
Offset 80h
Port 0
Version 1.0
Physical slot #0
Presence detect yes
Virtual Channel
Offset 100h
Dump
Common header
Vendor ID 0x10DE
Model ID 0x0369
Revision ID 0xA1
PI 0x00
SubClass 0x00
BaseClass 0x05
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 44h
Revision 1.03
Offset E0h
Dump
PCI to ISA Bridge
Common header
Vendor ID 0x10DE
Model ID 0x0360
Revision ID 0xA2
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x00
Dump
SMBus Controller
Common header
Vendor ID 0x10DE
Model ID 0x0368
Revision ID 0xA2
PI 0x00
SubClass 0x05
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
Common header
Vendor ID 0x10DE
Model ID 0x036C
Revision ID 0xA1
PI 0x10
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
Common header
Vendor ID 0x10DE
Model ID 0x036D
Revision ID 0xA2
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x17
Int. Pin 0x02
Capabilities
Offset 44h
Offset 80h
Version 1.1
Dump
IDE Controller
Common header
Vendor ID 0x10DE
Model ID 0x036E
Revision ID 0xA1
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 44h
Version 1.1
Dump
IDE Controller
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
IDE Controller
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x17
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
IDE Controller
Common header
Vendor ID 0x10DE
Model ID 0x037F
Revision ID 0xA2
PI 0x85
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x14
Int. Pin 0x03
Capabilities
Offset 44h
Version 1.1
Offset B0h
Offset CCh
Dump
80 00 00 00 C0 00 60 B3 07 00 00 08 80 00 E0 E3 76
PCI to PCI Bridge
Common header
Vendor ID 0x10DE
Model ID 0x0370
Revision ID 0xA2
PI 0x01
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x81
PCI header
Primary bus 0x00
Secondary bus 0x02
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset B8h
Subsystem ID 0xCB84
Offset 8Ch
Dump
Multimedia device
Common header
Vendor ID 0x10DE
Model ID 0x0371
Revision ID 0xA2
PI 0x00
SubClass 0x03
BaseClass 0x04
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 44h
Version 1.1
Offset 50h
Offset 6Ch
Dump
Bridge device
Common header
Vendor ID 0x10DE
Model ID 0x0373
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x16
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
MSI-X Capability
Offset 70h
Offset 50h
Offset 6Ch
Dump
Bridge device
Common header
Vendor ID 0x10DE
Model ID 0x0373
Revision ID 0xA2
PI 0x00
SubClass 0x80
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x14
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
MSI-X Capability
Offset 70h
Offset 50h
Offset 6Ch
Dump
VGA Controller
Common header
Vendor ID 0x10DE
Model ID 0x0191
Revision ID 0xA2
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0x00
Header 0x00
PCI header
Subvendor ID 0x3842
Subsystem ID 0xC831
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 60h
Version 1.1
Offset 68h
Offset 78h
Port 0
Version 1.0
Virtual Channel
Offset 100h
Offset 128h
Dump
Common header
Vendor ID 0x104C
Model ID 0x8023
Revision ID 0x00
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x02
Header 0x00
PCI header
Subvendor ID 0x10DE
Subsystem ID 0xC55E
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 44h
Version 1.1
Dump
DMI
DMI BIOS
version 6.00 PG
date 06/30/2007
manufacturer EVGA
product 122-CK-NF68
version 2
serial 1
DMI Baseboard
vendor EVGA
model 122-CK-NF68
revision 2
serial 1
manufacturer EVGA
DMI Processor
manufacturer Intel
FSB speed 449.0MHz
multiplier 7.0x
correction unknown
DMI Memory Module
designation A0
DMI Memory Module
designation A1
DMI Memory Module
designation A2
DMI Memory Module
designation A3
DMI Port Connector
DMI Port Connector
DMI Port Connector
connector DB-9 male
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
connector PS/2
connector PS/2
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Port Connector
port type USB
DMI Extension Slot
designation PCI0
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
usage System Memory
correction None
max# of devices 4
DMI Memory Device
designation A0
format DIMM
type DRAM
total width 128bits
data width 128bits
size 1024MBytes
DMI Memory Device
designation A1
format DIMM
type DRAM
total width 128bits
data width 128bits
size 1024MBytes
DMI Memory Device
designation A2
format DIMM
type DRAM
DMI Memory Device
designation A3
format DIMM
type DRAM
Software
Resources
Port I/O Space, BA=0x290
Port I/O Space, BA=0x2E
I just updated. It should work now.
here dont read right Vcore also
http://aycu22.webshots.com/image/245...4449664_rs.jpg
I spoke too fast.
This should work this time.
After trying that update I´m getting same wrong vcore readings.
E6600@3,3Ghz, vcore default (SpeedStep Enabled), load VID 1,25V (from Coretemp), idle VID 1,1625V.
On Everest (has always read the right VCore) I get 1,11V idle and 1,20V load.
Dump file attached.
Thanks in advance!
amazing work Mr. Cpuz! :D
it's just been incredible to see cpu-z progress as it has since the 1.2 era when i started using it.
It's OK for me
wohooo finally this new cpu-z reads my e6600 voltages correctly :up:
Correct voltages reading on e4300/e4400/e4500 too :up:
this version makes my computer crash to the extent that the power button doesn't work, and i have to turn off the psu... never had that happen with cpu-z before.
One question.
since yesterday I'm on Vista x64 (with these prices of memory I want full usable 4GB working), and I was wondering would it be possible to compile CPU-Z for native 64bit??
There's CrystalCPUID (http://dl.crystaldew.info/download/C...PUID413x64.zip) but I much, much more prefer your awesome utill!
BR
Nedjo
Mine doesnt shows correctly
according to CoreTemp VID is 1.35v
yep, reads my voltage correctly now and adds more spd info. thanks for the link mate :)
cool. got rid of the 3rd decimal place, but cool. reads 1.50v like everything else now
woot voltage fixed for me too
Reads core voltage wrong here , dumpfile is attached.
Vcore is in bios 1350v , cpu-z says 1.26v
Thanks Franck !
Is it possible to put a the CPU VID there too ? :D
Cheers works a treat :up:
nice work Franck
1.40.8
1.40.5
These 2 versions don't work with Vista x64
err sorry it just says Voltage 1.248 v under cpz 1.40.5
1.40.8 says Core Voltage and it shows up as 1.25 V
I just noticed it uses a capital V and not lower case v like 1.40.5
So what is accurate here?
According to core temp my VID is 1.3250
hey, where did the command rate go?
1.40.5 works fine under vista x64 but you have to run it as admin.
http://s184.photobucket.com/albums/x...1_bios0501.jpg
Voltage & everything works great here, thnx Mr. CPU-Z :)
At first, I couldn't run it from vista x64, it would just crash, then I downloaded it again, ran directly from winrar, it worked :) .
Now i have extracted it, and it still works, good stuff added, like the proper voltage readings with my e6600.
One problem I have noticed on my (and a buddy's) Turion 64 X2 processors that was present in 1.40.5 and still in 1.40.8 is that the VCore is reported wrong when the CPU is undervolted (for throttling/battery). It reads fine @ 1.075v when running normal, but when I undervolt it to 0.700v, CPU-Z displays 1.425v...
-Thanks
Franck,
Any possibility to put the CPU VID in CPUZ ?
Its OK for me :D.
http://mekk.homeip.net/imagesharing/...c6621717a8.png
Thank you DR. CPUZ
p5k and xeon 3060 working great!
I just recently noticed the following CPU-Z Version 1.40.8 behavior concerning Command Rate using my P5K Deluxe.
Here I don't have Command Rate...
Attachment 62785
But as soon as I open MemSet...
Attachment 62786
Thanks for the 1.40.9.
Same behavior...
Attachment 62787
When I ran MemSet the Command Rate appeared.
Installed 1.40.9 in Vista64 and it shows the correct voltage.
Well Done!
HAPPY MOTORING!!
vcore fine for me to :) thanks!
Works fine here.
Oh wait no it doesnt.
1.7V you having a laugh!?!
http://i144.photobucket.com/albums/r...llyvoltage.jpg
1.40.9 cause a lock-up on my system. dfi r600 with e6600 2gb ballistix? downloaded twice both either cause reboot or lock-up?
I have come across a very strange problem when using pcprobe2 und cpu-z 1.40.9. I never had this problem when using older versions, but it also appeared when using 1.40.8. BTW, voltage isn't correct, too. Is this a known problem?
pm sent btw no .ini file or latency file in downloaded 1.40.9 so i used 1.40.5
maybe that was why it would crash?
The two programs may be conflicting.
To all please :
If you notice any problem with cpuz, please do the following :
- if the program does not lock-up, please save a register dump (in the last tab) and send it to me (cpuz [ at ] cpuid.org) with a short description of the probelm.
- if cpuz causes the system to lock-up, please go to this page :
http://forum.x86-secret.com/showthread.php?t=4402
and refer to Q4.
Thanks !
Mail has been sent with register dump cpuz. :)
hello Franck
did some benching today with a few different boards and noticed that this version of CPUz does not respond to F7 command any more :(
F5 screenshots work great but F7 validation don't which is a shame as i tested my E6700 past 5GHz but only F5 screenshot was on the drive :(
http://img182.imageshack.us/img182/9132/cpu5013kg9.png
vcore works great :D
downloaded the file and now the program is 1.40.9
works gr8
My vcore core is still inaccurate.It's around 1.15 in CPUz , actual Vcore is 1.450
my vcore is not accurate.. i have mines at 1.4V but it says 1.360V
mine says 1.40.9
it reads my voltage finamundo.
speedfan 4.32: 1.39 v
cpuz 1.40.9: 1.392 v
pc probeII: 1.39 v
i dunno, the one i downloaded from richard and the final version give me the same problem
1. Wrong voltages or jumps from like 1.1 to 1.3( pretty weird to me)
2. The multiplier is jumping from 6 to 9 and back to 6 in like 1 second. My multiplier is locked at nine, Version 1.38 shows it locked at 9 but showing is 6 is weird. I dunno what to do.
If u can help me that would be great i use a e6600 and an intel 975xbx
Hi Cpuz,
Ever though of integrating a temp read out in the first main tab? That would really kill the need to list out the temperatures from another program.
Regards K
