The Problem:
Having owned a few cases until now (from midi towers to CoolerMaster Stacker) I was always a little bit unhappy about the room availalbe inside. The most annoying thing was that with almost all the cases I owned they had to be modded in one way or another in order to put in a radiator.
The Solution:
So I was always on the lookout for something better. Recently I came across a new thread at xs.org in which I saw the MoutainMods U2-UFO Opti-1203 case.
This seemed like the case I always wanted!! Huge case, plenty of room inside, already modded for 120.3 Thermochill radiator. Yes this was my case! I decided to start from scratch - with almost everything new.
Just to give you an idea - this was my old setup:
http://www.auswebserv.com/Cubic/Oldsetup.JPG
It was pretty good while it lasted.
The Parts:
So about 2 weeks ago I started ordering new stuff in. Here is the list with what has been ordered so far:
6 x Logisys 120mm Quad Blue LED Fan
1 x U2-UFO Opti-1203 Black Powder Coat - Diamond Top
4 x Logisys 80mm Quad Blue LED Fan
3 x 120MM Chrome Grill
3 x Mountain Mods 120MM Fan Grill (VERSION 2)
3 x Mountain Mods black Acrylic 5-1/4 bay cover
1 x ThermoChill PA 120.3 Radiator
3 x 80MM Chrome Grill
1 x Dual 12 Inch Blue Cold Cathode Kit
1 x Dual 12 Inch UV Cold Cathode Kit
1 x Microsoft Windows Vista Ultimate DVD 32bit
1 x Silverstone 1000W OP1000 Power Supply, Black, 80mm fan, 4 x PCI-E 6pin connectors, 2 x PCI-E 8pin connectors, 2 x triple SATA connectors single rail 80A
1 x Intel® Core 2 Quadro™ QX6700 2.66G LGA775 2x4M 1066 FSB XD EM64T EIST VT
1 x Asus P5k DeLuxe Wifi
1 x mCubed TBAN-SH Transparent Analog Sensor Hub
1 x mCubed bigNG
1 x DDC-2 18W water pump with 1/2" D-Tek high-flow bars
1 x Petra's DDCT-01s top
1 x BLue UV Reactive Pentosin
1 x biocide
1 x Arctic Silver 5
1 x Aero GateWatch 2 (black) fan controller
1 x ClearFlex 60 Tubing
3 x CoolSleeves
1 x Blue UV Sleeving Kit
1 x 8800 GTX (oc 600 Point of View) - petty as I wanted an ATI 2900HD but the benchmarks does not favour this video card
1 x Swiftec MCW60 GPU water block
1 x Thermalright 775 Bolt thru kit
1 x 1.44 black floppy
1 x sata dvd writer black
1 x dvd rom black
- yeah a lot of parts.
On top of this I kept (from my old PC):
2 x 36GB Raptors
2 x 320 Sata2 16MB cache hdds
1 x G.Skill HZ 2GB DDR2 PC8500 Dual Channel Kit (1066Mhz) CL=4-4-4-5
The Pictures:
And this is what I got so far:
U2-UFO Opti-1203 Black Powder Coat - Diamond Top case from Mountain Mods
http://www.auswebserv.com/Cubic/Case.JPG
Thermochill PA 120.3 radiator
http://www.auswebserv.com/Cubic/rad.JPG
D-Tek Fuzion CPU block + Swiftec MCP355 with Petras top pump
http://www.auswebserv.com/Cubic/water.JPG
Other accessories (read bling :) ) for my new case (neons, led fans, grills, bay covers)
http://www.auswebserv.com/Cubic/accessories.JPG
The hardware that is going to be overcloked by the above is:
P5k DeLuxe motherboard
QX6700 Quad CPU
2 x 1GB G-Skill ram
SilverStone OP1000w power supply (single rail 80A)
black 1.44 and dvd writer
and of course Vista Ultimate 32bit OEM edition (I could not pass up in getitng this at a bargain price together with the hardware). The intention is to run WnXP until need to move to Vista. Here are the mandatory pics:
http://www.auswebserv.com/Cubic/Hardware.JPG
http://www.auswebserv.com/Cubic/cpu.JPG
http://www.auswebserv.com/Cubic/powersupply.JPG
http://www.auswebserv.com/Cubic/ram.JPG
As I am an overcloker, I am not too concerned about noise (hell I run a quad cpu 2GB XEON 8GB RAM DELL server in my room=lots of noise) but what I want is a very stable system overclocked to the "edge" if I can say so.
Apart from the above bits and pieces I am still waiting on two more parcels to arrive with more hardware (fan control, video card, cable sleeving etc)
As most of the stuff only arrived in the last couple of days I have not started my water cooling project yet. Most of the hardware is still in its boxes :)
I hope to get a start in the next day or two. Will keep this thread updated with my progress.
