first test
http://download.pctuner.net/upload/r...09_spi-926.jpg
motherboard no mods.really excellent product:toast:
first test
Wow nice clocking
Wanna see more!
Regards
First test as in no tweaks?
Looks good, I really want to see more :)
wow !
cas4 and its probably 9s flat :)
Nice clocks. :up:
You need better memory for 4-4-4-12 or tighter for 8.xx :clap:
With some experiments and a little bit more OC you will get it
Really nice results, you have really good CPU there. :toast: Any pics of setup?
regards
DFI P965 seems to be very good and I will buy one :)
Good SPI results ;)
realy realy realiy good work Massimo !!!!! :woot:
what's the max freq. on p5wdh with this chip ? :D :D :D
Get those RAM timings sorted and...... :slobber:
Chido!
What Vcore were you using ?
Great stuff :D
N1 run.
Try to turn off the Windows XP Theme.
Should give a small boost.
Best Regards
Dennis
Good test and great mobo,maybe with this DFI 965 someone will go under 9'@32M...
Bye,
Chris.:toast:
Very nice, you mind pointing out what type of cooling you were using, and also if it's not too much trouble, lower the cpu mult and see how far the fsb can go unmodded, I want to see if it will hit over 500fsb unmodded like the rd600 does
very nice, very very nice, only problem I would say with the ln2 though is that unlike phase, it would be difficult to leave it on 24/7
I think that if dfi did a better job on cooling their mobos, you could go plenty farther, consider some thermalright hr-09 mofset coolers imo, a great bios is nothing if your vfm explodes
Amazing clocks men !!!! Congratz :D
really amazing for a mainstream board.. :)
kudos to DFI.. :)
Bel colpo ragazzi!
With other optimizations and tweaks u can get 9.000" or less @ SuperPI 1 M?
Bye
Great!!!
this mobo might be born to be a WR breaker :D
Great benchmen of tana;)
Impressive. Tighten the memory and you'll be doing even more damage.
It's fantastic !!!
Nice result guys! Congrats!
Congrats, nice clocks guys ;) , and as Delex says , with tweaks and better timings on mem, you have 9.00 or better SPI time, keep pushing it :)
Very good run guys!!!:woot:
