Onepagebook and his 3D benchies...
Hello all....:)
First off I would like all of you to be polite...:)
READ WELL the whole post before start posting and compare....Use your mind and don't let others to use it for you....
Now...
I show his 2k5 bench with a single 8800GTX clocked at 653MHz core and 1145MHz rams - Actually it seems that his VGA rams are clocked at 1053MHz and NOT at 1145MHz as he says -
His CPU power is 5302MHz on an EVGA 680 mobo.....
Here's the links: http://service.futuremark.com/compare?3dm05=2450489 and here: http://www.hwbot.org/compare.do?resultId=563812 , http://www.hwbot.org/result.do?resultId=563812
I ran the 2k5 bench at 5405MHz on an ABIT AW9D-MAX mobo with a SINGLE VGA too at 899MHz core and 1215MHz rams.....
Here: http://service.futuremark.com/compare?3dm05=2660983
http://www.thelab.gr/images/Hipro5/C...891_1215_1.png
http://www.thelab.gr/images/Hipro5/C...891_1215_2.png
I have 100MHz more in CPU PLUS I ran it on 975 chipset and 246MHz more on VGA's core and 70MHz more on VGA's rams.....
QUESTION 1: How come and I get a lower score with higher clocks overal?....
QUESTION 2: Let's say he plays his rams at 500MHz with Cas 3-3-3-x.....and he beats me on GT1 and on GT2(which actually is both CPU and VGA)....NATURE TOO?.....
I get 150.3fps with the VGA at 899MHz/1215MHz and he gets 151.7fps at ONLY 653MHz core?.....
Sorry but I just don't bite it....:confused: :rolleyes: :stick:
SECOND:
His Aquamark score with SLI 8800GTX at ONLY 4832MHz with a Quad, is 261895 marks.....
We ALL now that the VGA's gives you about 2k - 3k MAX on this bench....
QUESTION: How come and he get's THIS score at ONLY 4832MHz?....You'll tell me it's a QUAD......Welllll I've ALSO tested it with a QUAD at 4852MHz.....NO GO....:confused:
THIRD:
His new 2k5 score with SLI : http://service.futuremark.com/compare?3dm05=2654983
k|ngp|ng's score with SLI : http://service.futuremark.com/compare?3dm05=2408750
2000 marks over k|ng|ng?....Hello!....
k|ngp|ng benches TOO MUCH time 3D and OPB JUST STARTED.....Tweaked OS ONCE AGAIN OR tweaked VIRTUAL OS?.....You tell me....
AND REMEMBER: We are talking about 2k5 bench.....You don't get THAT EASY marks from it.....It's not 2k1 with a difference of 2k marks +/- .....It's the 2k5 bench.... :stick:
Take a GOOD look at their ram speed....OPB seems to be 1094MHz and k|ngp|in's seems to be 1188MHz.....
8800GTX's ram frequency can be calculated as: 716MHz (STANDARD - MAIN) PLUS what you see on the compare link......
So k|ngp|ng's is: 716MHz + 472MHz = 1188MHz REAL
and OPB's is: 716MHz + 378MHz = 1094MHz REAL
I don't bite it either.....:stick:
FINAL:
At least as for the 2k5 with the SINGLE VGA OPB's score, I'm 100% positive that it wasn't done at 653MHz VGA's Core OR it is FAKE.....
You try it and tell me.....151fps with the VGA at ONLY 653MHz Core?...NO WAY.....
Take a look at Overklokk's SINGLE VGA clocked high: http://service.futuremark.com/compare?3dm05=2565590.....How about his NATURE score?....That bad too that is beaten with ONLY 653MHz core by OPB?......
Take a look at Oppainter's new score: http://service.futuremark.com/compare?3dm05=2646810
How about his NATURE score too?....Beaten by OPB with ONLY 653MHz Core?..... ;) :stick:
It was done at higher VGA's clocks and he doesn't want to say so?....
That's a lie as for me if he did so......Excuse me for this post of mine but that's how I feal.....:(
