I can not think of another way to describe this...
setup 1:
p5b
2*512 5300 crucial
6600
big typhoon
At first I was running 3.7ghz 1.65v 24/7 for a week or two then it started BSODing
Set 3.6 and I was fine
Switch to water and I still can't run 3.7
setup 2:
xbx2
2*1024 6400 2gbhz and the crucials from setup 1
3060 xeon
big typhoon
When I got the chip I could:
orthos 3.75 1.5v
3946mhz 3d 1.55v
4ghz 8m 1.55v 1333 strap
I ran 3.75ghz for a while then one day it rebooted so I just stuck with 3.6
Without changing anything I vmch modded my board so I could run 4ghz on 1066 strap.
4ghz won't post.
Try 2507 bios, same thing.
Try 3946mhz again and it crashes 3dmark. 1.575v and 3946mhz works.
Try 4ghz and it black screens after post flash screen.
Previously, 4ghz would boot fine on 1333 strap and 1066 strap would hang at the windows loading screen, not it just goes to a black screen.
I remounted the typhoon twice with the same amount of pressure, same TIM (ceramique), same ambient, same CPU load temps, same BIOS settings, same EVERYTHING, and no go with my old settings. What is going on?
