Originally Posted by Pete@X
If you want to kill a board - there are always possibilties to do so
The whole point is that I DONT want to kill another board, but I am sure that if I put this thing through a fair second test, It will die.
IF you run high VCores without the needed precautions (cooling) - you are the one to blame - not the board :nono: ! Running high Vcores on the Board without the needed steps regarding cooling is a typical case of the "user.exe needs an update" :nono: .
Dont babble at me saying anything about the voltage that I am running is bad/scares you/degrades/whatever. I clearly have enough cooling here, as I am the one running 8+ hours prime on this voltage...
I also have run 1.65v+ daily, so your talking to the wrong person here.
You mix apples with onions with you "bad" DFI list, why not join the folks on the "680i is killing ram" thread ???
WOAH! BECAUSE MY 680I DOES NOT KILL RAM! HOW DIFFICULT TO UNDERSTAND!
... i have tested ~ 2000 CPUs on DFI nF4 Boards (part of my Job :D ) - not 1 cpu died on my Hands, Expert Issues where mostly with pre-rel. boards or alpha bioses. So the useres did know that something could go wrong - oc needs also some brain to work - just get stuff, cranck up the voltages has not always the best effect.
Is that what Kyle @ [N]ubocp told you?
Who really cares about an E6600/X3060 @3.7 or 3.8 with a VCore passt 1,5V ???
I donno? POSSIBLY XTREMESYSTEMS.org?
No1 to tell you the truth - far more interessting are the nice results in the low Vcore regions. These results leave enough room to tweak the system for stability and performance.
Who cares about low voltage? Why dont you just run stock? I booted with my X6800 for two days @ 6*435 and I didnt really notice in day to day things, whats the point? Again I say over and over, your 3.7 isnt holding a candle to the 4100 I am running 3dmark at on water, and for those things ~500 mhz and a faster chipset is kinda noticeable...
And again, I ran 3.9ghz on 1.54/1.6+/whatever I want, and it will pass any stress test that I throw at it. I am the one talking to real people here.
I am the one here, helping others like Eva2000 get those extra 50-150 mhz out of his X6800, all by using the same settings that ive talked about over and over and over and over and...
Originally Posted by EVA
BEFORE:
it's benchable at 3950mhz at 1.56v load
AFTER:
- max single Super Pi 32M = 4091Mhz at 1.675v bios set (1.65v idle/load)
You call the Abit a good Board ? I could get easy ~ 20 customers who would tell you the opposite - would that be a reason to judge the Abit a "crappy" board - i my eyes no - as there are always two sides of the coin. Some users can handel a board better than others - simple like that.
1) I bet over half of those people have E6300/E6400s
2) I bet over half have cheap ram (under 300$/2gb, not counting corsair)
3) I bet over half those users run the stock aircooled chipset
4) I bet none of those users have modded boards
5) I bet only 1% of those users even knows what a digital multimeter even is
Again, the AW9D isnt a noob-friendly board, but apparently neither is the RD600. Hell, Kyle@[T]ardforums only managed 333FSB on the AW9D. How sad is that...
VCore - why that high vcore (1,67 and so on ...) ?
Because it is fast. Duh. XS = FAST(benching or daily)
Ever had the idea to find better cores that needed less juice to perform nicely ?
Yes, I called intel and asked for a 3.9-4ghz cpu @ 1.3v and they said call newegg.
:stick:
There are dam nice Xeons around ... 3.6GHz ~ 1,3V, 3.8GHz ~ 1,4V - there is absolutly no need for insane VCores.
3.6 is slow as crap, 3.7 is below average, 3.8 is average, and 3.9 isnt too bad. Oh yea, all those are 8+ hour prime.
I have now 5 DFIs up and running, all @3,6GHz or 3,7GHz below 1,4V. More than enough for 24/7 use :D - but i guess useless to say that to you :rolleyes: .
XS is about pushing the limits of computing, daily or otherwise, and I think my 8+ hour orthos @ 3900+ mhz kinda counts on that arena.
Anyway - i have the 6th DFI here, running P 25.1 since +12h a X3060@3.7GHz@1,375VCore. PWM HS is easy to touch - no burn marks etc .... ;) - so before i extend that post - i`ll go better back to my work and skip the other thoughts i had in mind ...
3.7 is slow. My L623A did 3.7, and people like you couldnt even get 3.2 on the same stepping L623A E6600.
Just a final note - since i play with boards (+15 years) - not one has ever died in my hands / nor rams or so .... we always have to keep in mind > treat the hardware nicely - and you have fun. Go over the limts and you are lost. Simple as ABC - if you follow these rules, all will be well :D
For my side - the case is closed - as there will be always 2 sides, and i`m on the "nice board" side ... so why bother, you ruined a board in a short time. Sorry for the board - not for you - as mentioned above.
I am sorry the board is a POS as well, back to the store it goes...
