that is my new bench table, after a while playing with phase change cases, that table is only a demo to see dimensions, and to test it and have some feedback by the pro user, that revision have some mistake like holes for cables, fans support, liquid cooling fixing holes, and the arch press mounting mechanism.
http://www.pc-phasechange.it/fotoupz...2/IMG_6539.jpg
http://www.pc-phasechange.it/fotoupz...2/IMG_6592.jpg
http://www.pc-phasechange.it/fotoupz...2/IMG_6594.jpg
http://www.pc-phasechange.it/fotoupz...2/IMG_6596.jpg
http://www.pc-phasechange.it/fotoupz...2/IMG_6597.jpg
http://www.pc-phasechange.it/fotoupz...2/IMG_6608.jpg
the table is composed by two parts, that can be used together or separately,
the down part can hold quite your motherboard and all the peripheric, than if you want to bench hard with the arch, you can add the top part with the arch mechanism, or simply you can use only the top part without down part, and spare your hardisk, PS, ecc...on your desk:D
comments are wellcome;)
thanks
