Proper A/C Chilling (pics)
This is a chiller I made with a window air conditioner and a cooler to cool my aging socket 478 system. The temperature of the liquid in the reservoir after about an hour of running time is about -32C, at an ambient of about 20C and without load, other than the heat dump from the in-line pump.
http://i74.photobucket.com/albums/i2...o/DSCN0108.jpg
http://i74.photobucket.com/albums/i2...o/DSCN0085.jpg
http://i74.photobucket.com/albums/i2...o/DSCN0116.jpg
http://i74.photobucket.com/albums/i2...o/DSCN0086.jpg
http://i74.photobucket.com/albums/i2...o/DSCN0124.jpg
http://i74.photobucket.com/albums/i2...o/DSCN0098.jpg
A/C unit: Sears Kenmore 5300 BTU (with remote control), modified as follows: Removed the plastic face and louvers. Removed the evaporator fan. Mounted the controls on the side of the unit. Placed the end of the temperature probe underneath the condenser. Attached rubber feet to the bottom of the unit, which raised it about three inches, to allow the evaporator to be placed down into the reservoir. Painted the housing red. Put a blue cold cathode inside the housing. Cut away some of the plastic inside the unit around the evaporator to give me some space to bend tubes and move the evaporator. Carefully bent the tubing to the evaporator to allow me to pull the evaporator about three inches forward, for placement in the reservoir.
Reservoir: Rubbermaid 13.2 qt slim cooler, modified as follows: Removed lid. Cut hinges off lid and cooler. Mounted ½ inch ID brass couplings through lid, sealed with 2-part epoxy. Filled interior of lid with expandable foam. Drilled hole and inserted thermometer through lid. Cut away small piece from back of reservoir to allow placement of evaporator in reservoir, and placed evaporator in reservoir. Trimmed this piece down to make space for the evaporator tubing, glued the piece back into place using expandable foam, and sealed with silicone. Attached clearflex tubing to brass fittings on inside of lid with hose clamps. Placed weather-stripping along lip of reservoir. Filled reservoir with coolant. Tightened lid down with cargo straps.
Coolant: About 1/3 anti-freeze and 2/3 denatured alcohol.
Tubing: ½ inch ID Tygon tubing, attached with hose clamps.
Pump: Danner Mag Supreme, model 3. The pump was disassembled, and reassembled with Devcon 250 used to seal all potential leaks. Devcon 250 was layered on the outside of the pump impeller housing to further prevent leaks and cracking. I think I should have used the model 2 pump: less flow but it also produces less heat.
Waterblocks: Swiftech cpu and gpu waterblocks. Each waterblock was disassembled. The base plate and block housing were sealed with Devcon 250. The plastic barbs were removed and replaced with ½ inch ID brass barbs, which were glued in place with Devcon 250.
Devcon 250 is an industrial adhesive. Its operating temperature is from -67F to 250F. It is not affected by high and low pH’s, and has a strength of 3,200 psi, according to the product datasheet. I found this stuff at J & M Industrial Supply online.
The total cost for this chiller was about $375.
Some things to remember: Devcon 250 is toxic, use in a well ventilated area. Denatured alcohol is flammable, and evaporates rapidly. Use in a well ventilated area, and make sure the finished chiller is sealed to prevent evaporation.
I have run the chiller for 24 hours with no leaks. I added some more silicon on the inside of the reservior around the evaporator tubing. I am going to let it run for another couple of days and check the coolant level to see if it is evaporating. The next step is to insulate the tubing, pump impeller housing, and the waterblocks. Then I will mount the blocks to the computer and start overclocking, benching, and playing Oblivion. I will update this thread when this project is complete.
Many thanks to XS and the users of this forum.
