new evap séries on test, Ricky/sl4ck
hi :D my friend sl4ck that lives in my city has a lathe on his house :D so we meet in order to try to make my dream evap, here is the diagram, is like the other i made, but with very more area of contact:
http://img92.imageshack.us/img92/9000/evapum0.jpg
but it's :banana::banana::banana::banana:ing hard to make it on a lathe... here is were we stop:
http://img201.imageshack.us/img201/9445/imgp3446qq9.jpg
well, experimenting the lathe we saw steep by steem is more easy to make, but honestly the thig i dont like on this evaps is how heat is transfered by the center cilinder, i prefere maze styles :D why dont mix the 2?? :D.
thinking how to get more area of contact and how to cool better the central cilinder i think on somthing like this:
http://img132.imageshack.us/img132/9750/3d1cp0.jpg
liquid goes steep by steep but on 1st's steeps it is forced to run inside the central cilinder cooling, making more area and removint the heat more directly from cpu, like on a maze
http://img148.imageshack.us/img148/6664/render1tf9.jpg
here is 1st night of steep by steep evap, only need to make the holes on central cilinder .
http://img244.imageshack.us/img244/6397/1zd8.jpg
http://img96.imageshack.us/img96/8908/2aw0.jpg
http://img96.imageshack.us/img96/8250/3sy3.jpg
http://img96.imageshack.us/img96/6286/4hg7.jpg
last pic is kidding with blaster becouse of cigarrets using imitation of marlboro cigarrets, but it is good to see how small is the evap, it will fit an vapochill ls kit. using 2mm for each steep that is more than enough to get good contact.
http://img171.imageshack.us/img171/1985/5go2.jpg
it will be tested soon and we will make some with diferent sizes and get the best size/desighn.
what do you think about it? let's make bet's about performançe! lol
regards, ricky :toast:
