Hi, i am crazy with E6600 B2 and Asus P5W DH, if i will set FSB above 285MHz my rig does not post, i have to reset CMOS ... is board or CPU wrong? Please post anybody settings of BIOS or some idea what is wrong.
try turning off hyperpath 3
I will try turn off it, i payed really lot of money for new MoBo, 8500 RAM and latest CPU and my OC is finally only 2.61Ghz .... sh*t ....
I was thinking the same.
Disabling hyperpath 3 let me get past that wall though.
Still, I think my cpu sucks, doesn't look like mine is stable 3ghz stock volts. How fking disappointing tbh
Thats really a bummer man. I think my 6600 is a crappy clocker aswell its kind of disapointing after seeing all these engineering samples. I can't get much post much past 360 fsb and its not even stable no matter the voltage lol.
Lawrywild whats the max clocks your hitting on that 975 board?
Oh man, thanks a lot! You are my Saviour ...:worship:
http://img182.imageshack.us/img182/7...chemem5gv9.jpg
My problem is only crapy memory divider in this Asus MoBo, i cant use other than 800Mhz, i have 1066 Memories but this board do not to post with memory frequency above 950Mhz ...
Wow, one bios option and now your flying good for you! How much vcore are you using for 3.6? Is that a retail or OEM?
It is a Retail boxed CPU, 3.2@1.4V in BIOS and 3.6@1.5V in BIOS.Quote:
Originally Posted by foch3 -USA-
not too bad this little thing - more possible or fsb limit ~400?Quote:
Originally Posted by OBR
Thats not bad at all. Atleast some ones retail is hitting nice clocks. What cooling are you using and what are the temps like a 3.6
i couldnt get prime stable at 3.6, im super stable at 3.4 on 1.49v
all the mem dividers seem to be dodgy.
I have some trouble with the board too.
As soon as I want to set mem timings manually, it doesnt post. Not even when I set the same settings it picks with auto... Using a single 512MB MDT PC667 CL4 and lowest divider with 701 bios.
I can set the timings from 266-400, but cant boot at 401+ :/
Have to set timings to auto to boot.
lol no problem mate, I was sitting at my pc for about 2 hours thinking OMFG I MUST HAVE THE WORST CLOCKER IN THE WORLD. Finally found out the fking hyperpath 3 was causing it lolQuote:
Glad to see it's not doing too bad for you.
I need to play a little more atm i'm 3ghz 1.36v... havn't really primed higher though so I dunno yet, need a few more days with this thing. It's really strange to oc but oh well, I'll get used to it at some point.. :rolleyes:
Sounds just like mine mate lol, seriously JUST like mine..Quote:
Well, I am working on my retail boxed 6700 in the P5W Dh aand I also am locked at 360 fsb. It will not go 1 fsb further.
Also, like several here, you have to leave mem at "by spd" or no boot.
Sucks because I spent good money on this ram and the best I got right now is ddr 900 with timings of 5_6_6_18 that I cannot change or no boot adn the divider is 4:5 At least it is a lot closer than I started and I am not sure how I got it better LOL For a while I was stuck at 2:3. If you try to use memset in windows.........crash and reboot.
But,,,, this 360 fsb wall has gotta come down!
I have tried 1.65 vmch, no help. If I try to use AiBooster to go up OR down with fsb from 360, windows locks right up. I tried to boot at fsb of 365, 370, 375, 400. nada
I have not gone over 1.45 vcore though. Thats as high as I am comfortable with right now on air. My temps are 38c idle at this vcore.
I jsut think something is screwy with so many people haveing this 360 fsb issue and the ram problems.
Wow! For about a week I played with my DQ6 and was about to return it because I couldn't get past the 360-380FSB with my retail E6700 either.Quote:
Originally Posted by Tallman
I was able to do 380 X 10 3.8ghz and completed 3DM06 but the system in general was pretty unstable.
Vcore was somewhere close to 1.6 but my temperatures were not too bad. 38-40c
Right now I'm running 350FSB X 10 1.46 Vcore
25-30c AIR Zalman 9500LED (AC is on)
People who can't go past 360~370FSB, it's not because your board is crappy. It's by design. ASUS is forcing tight chipset timings at 1066 strap, which will set the FSB wall at base 266FSB +100FSB. (It's too long to explain and I just learned about it myself). If you want to go past that wall, you HAVE TO give up 4:5, 3:5, etc. 1:1 will take you up around 430 (333 base FSB + 100). After that you have to give up 1:1 to go up higher, but at that point the chipset will physically give up at 1.65V max. Again, it's by design. Asus went on the route to tighten the chipset timings that's why we see the fastest PI scores on this board. On the contrast, Gigabyte went on the opposite way (w/ DS3, I don't know about other models) and that's why we see such sky high FSB but their memory dividers/timings are all messed up.
If your memory is good up to 1066MHz, try running 1:2 @266FSB. It'll run like a charm. :)
I have Prime STABLE E6600 with FSB 400Mhz, FSB on this board is not problem for me. Really problem is the memory dividers, i have Corsairs 1066 but with this MoBo i can run them only 800@8-3-3-3 because any other divider (950,1000,1067,1100 ...) does not work, system dont post with these settings of RAM.
AMEN to that. Been saying this for a while.
My highest post with ES 6600 and P5WDH is 400FSB with DDR2 @ 800 3-3-3-8. It simply will not go farther.
That's the price we pay for having the 1066 strap locked.
Not a price worth paying, imho. How i wish it was simple, like the DFI NF4 Ultra-D days.
It is not working, if i have everything on default, FSB 266, and i set 1066 memory, no post ... i have 1066 memory and on Intel board they are great at 1150Mhz ...Quote:
Originally Posted by lopri
you upped vdimm?
yeah, to max 2.4V, but my Corsair are 1066MHz, 15-5-5-5, 2.2V at default...Quote:
by now, no??Quote:
Originally Posted by Theta
ASUS couldn“t disable the 1066 strap lock in the nextest bios?? or this crap is intrinsic of the mobo design??
It seems I have same issue.Quote:
Retail boxed 6700 in P5W DH, Air cool.
3.20Ghz 1.30v (default vcore) in bios, pass superpi 32M
3.33Ghz 1.375v superpi 32M stable
3.60Ghz 1.50v in bios, pass superpi 32M
400x10, 1.50v in bios, no post. :(
edit: 380X10 1.55v in bios, 1.55v vMCH, mobo posted but crashed when loading windows
wtf lol you just jumped 400mhz and wondering why it doesn't POST? :slap:Quote:
Originally Posted by bobov
Try first 370x10, 380x10:DQuote:
400x10 32M stable it's very very good also for an X6800.
is it prime stable also ?Quote:
i am wondering if this B2 stepping to correct for Raid 5 utilization has screwed the pooch for overclocking.Quote:
What i've read so far is that there's an FSB wall past 360 on retail e6700 with Gigabyte 965 boards and the P5WDH due to 1066 strap
So, this isn't a problem on other 975 boards where 1333 strap is an option?
yeh.. :mad:Quote:
Originally Posted by Ace-a-Rue
I managed 3.4 with 1.55v.. seems stable but not primed it yet, only gamed for a couple of hours
The big problem is: if you select anything over ddr900 in bios, it will not even post. My ram is ddr 1000 4 5 4 15.Quote:
Try 270FSB and select DDR900. Still doesn't boot?
Tried 370X10 1.525v vCore and 380X10 1.55v vcore, 1.55v vMCH, mobo did post but crashed when loading windows. I guess my E6700 doesn't have 360MHz fsb wall, just need better cooling (currently on thermalright Ultra-120) and more voltage.Quote:
Originally Posted by nachthymnen
Haven't tried it yet but...isn't 365 fsb 1:1 better than 270 fsb and anything?Quote:
EDIT: OK, I tried it and I am in windows with 270 fsb and my ram is ddr 1080! Too bad spuer Pi 1m is 5 seconds slower than with 360 fsb
The wall FSBs aren't exactly set on stone. Some will go higher and some will be lower. And in theory, if you don't mind running your memory slower than FSB you can go up to 500FSB (which is 400 Base FSB + 100) And that's why you can select up to 500FSB. I've run Prime95 Small FFT @440FSB with 3:4 (memory:FSB)
Yes of course 365FSB 1:1 is better than 270FSB. (Unless you have an X6800. In that case I'd suggest you actually test each setting) What's important is neither your memory nor your board is defective. After a certain point, in order to achieve higher FSB you need to lower memory ratio. (on P5W-DH, that is)Quote:
That's exactly what happened to me. My e6600 would'nt go over 2700Mhz. Disabling Hyperpath3 must have been the last option I tried :p:Quote:
ATM, I'm trying to get it prime stable at 3.3Ghz :)
I have the same problem with memory, like every owner of this board. If i will set frequency above 950 = no post ... because i have E6600 (multi 9, FSB 420)with maximum 3.8Ghz i can use mem divider only 840 (it is great at 8-3-3-3) or 1080 (this not working).... we need fix this memory problem, i hope it is not hardware error only software, and Asus correct it in next BIOSes.
In 4 weeks of BIOS releases for this board, Asus hasn't improved the overclocking of this board one bit. I've been through them all from 0401 to current 0903, and they pretty much ALL clock equally.Quote:
can u let me know what is ur batch number on the cpu? it should be written on the box. thanksQuote:
http://img83.imageshack.us/img83/4286/stickvt0.jpgQuote:
Originally Posted by Shrekogre
here is ...
my is 599 stuck at 3.4ghz. rams can boot at 918 max on cl5 or 4. guess we have abt the same problemQuote:
btw how to get pass 420fsb? seems like alot of people get stuck abt there.
Mine's 600 not prime stable at 3.4 1.55v :(Quote:
In order to pass 420, i had to run my RAM at the lowest divider.Quote:
I can't believe you went from 285 to 420 in one day and not satisfied. :D Also it's NOT a problem as I said, but by design. I personally think ASUS made the right decision since @400+ FSB chipset gets already plenty hot. You wouldn't want to run 24/7 much faster than that. If you want to go for higher FSB, you should find a cooler running P965 board.Quote:
And people remember that ASUS is still the highest clocking board among 975X boards. Seriously, many other boards' BIOS programmers still can't go past 370FSB justs like may of you. :D
I am now successfully running 400*9 (ran R@H over night), but needed 1.60V MCH and only the 1:1 mem divider works. Lowest divider gives me random reboots.
Now I will try to run at higher clocks, but too bad I cant set ram timings manually above 400FSB :/
It seems to work for some guys, which is quite annoying.
I am happy with FSB and CPU ocing, BUT i am not happy with my memory speed, i have great 1100+ memories but i can run them only at 800 ... it is my problem ...Quote:
can't seems to work for me. seems that 370 is a wall, 420 another wall.Quote:
Originally Posted by don_vercetti
Ive seen some ES chips which are stepping 5 with rev b2 I wonder how they clock.Quote:
If you really want to run memory ~1100MHz with 400FSB, try Badaxe. I guarantee you the performance will be lower than 800MHz 1:1 on your board.Quote:
Originally Posted by TONY
ahh the infamous week 24. ..
L624 = week 24 , try to get week 25 next time... week 24 sux ...
Where do you get that Week 25 > Week 24? From your experience?
