Kentsfield X6700 air-cooling tests
Intial tests with Kentsfield and air-cooling
CPU Kentsfield X6700
M/B: Asus P5B Deluxe
BIOS: 0403
Memory: Corsair 6400C3
Cooling: Tuniq Tower 120
OS: Windows Server 2003 Enterprise
http://img.photobucket.com/albums/v3...0/kent3769.jpg
Cinebench @ 3.6GHz
http://img.photobucket.com/albums/v3...cinebench3.jpg
Quad-Prime at 3.3GHz and 1.4V
http://img96.imageshack.us/img96/961...prime33fx4.jpg
Just a quick note about running quad-Prime. If you think dual-cores get hot running Prime, then you ain't seen nothing yet. :D With default VCore, Kentsfield temps will go into the 60's while running small FFT's. I know 30 mins. of Prime won't satisfy some people, but I was in a hurry. :p: Max TCase temp is 100C. Let's hope I never get close to that.
