New Bios DFI Expert 10.07.06
!!! USE AT YOUR OWN RISK !!!
Testet BIOS Savior
Expert 10.07.06 rar
Expert 10.07.06 zip
Merlin
Testet BIOS Savior
Expert 10.07.06 rar
Expert 10.07.06 zip
Merlin
what can one expect from this one ............have you got any more info
Seconded. Would like to know what i'd gain before I update. Anything like increased compatibility with certain types of ram is always nice, provided it's the ram i'm running ;)Quote:
Originally Posted by dinos22
Thanks,
---dens
test bios Expert 10.07.06
ocz tccd rev 1.0
http://hslab.pl/Merlin/2.jpg
http://hslab.pl/Merlin/5.jpg
Ok, what were your results with the previous bios?
is this for the expert only?
so... i dont want to be a guinea pig
Merlin what are the differences
________
California mdecial marijuana dispensaries
What BIOS is it based on?
He posted the same thing over at DFI Street... with NO info either...
well i don't know about NO info..................did you not see the tccd screenshot at 300MHz 2.5-3-3-x 1T >> THAT's pretty significant and would be interesting to hear a comment on how much of an improvement was made over DFI bioses........
Thanks for posting the bios and results. Interesting stuff.
updat: bios 10.07.06
I find very good worth! :)
http://hslab.pl/Merlin/1a.jpg
Merlin
Merlin makes a awesome bios but does not give Americans any info on whats what but if you look in google you'll find that he does share detailed info on the DELUX Forums but it needs to translated! This bios really excells at 200:1:1 but you get no love from the 183 -166 divider
Can be ported to Ultra-D ? :)
HOLY THREAD DIGGER BATMAN!!!Quote:
Originally Posted by Brother Esau
Hey I use the bios and its awesome just not so much on dividers is all but here this is what Merlins bios do with these Redlines for 8hrs of Prime and H.C.I Memtest and I could get a hell of allot more on 200:1:1 but I dont want to fubar the ram seeing how supplys are almost non existant .
My chip has been up to 2980mhz on 166 divider but cant seem to get much more love on the divider though
[b]Genie BIOS Settings
[color=red]
FSB Bus Frequency............................. - 275
LDT/FSB Frequency Ratio....................... - x3
CPU/FSB Frequency Ratio....................... - 10
PCI eXpress Frequency......................... - 105Mhz
CPU VID StartUp Value......................... - Start up
CPU VID Control............................... - 1.375
CPU VID Special Control....................... - auto
LDT Voltage Control........................... - 1.20v
Chip Set Voltage Control...................... - 1.52
DRAM Voltage Control.......................... - 2.64v
DRAM Configuration Settings:
[color=red]
DRAM Frequency Set............................ - 200:1:1
Command Per Clock (CPC)....................... - Enable
CAS Latency Control (Tcl)..................... - 3
RAS# to CAS# delay (Trcd)..................... - 3
Min RAS# active time (Tras)................... - 8
Row precharge time (Trp)...................... - 2
Row Cycle time (Trc).......................... - 7 Bus Clocks
Row refresh cyc time (Trfc)................... - 15 Bus Clocks
Row to Row delay (Trrd)....................... - 02 Bus Clocks
Write recovery time (Twr)..................... - 02 Bus Clocks
Write to Read delay (Twtr).................... - 01 Bus Clocks
Read to Write delay (Trwt).................... - 03 Bus Clocks
Refresh Period (Tref)......................... - 4708 Cycles
DRAM Bank Interleave.......................... - Enabled
DQS Skew Control.............................. - Auto
DQS Skew Value................................ - 0
DRAM Drive Strength........................... - 8
DRAM Data Drive Strength...................... - 2
Max Async Latency............................. - 7
DRAM Response Time............................ - normal
Read Preamble Time............................ - 5.5
IdleCycle Limit............................... - 16 Cycles
Dynamic Counter............................... - Enable
R/W Queue Bypass.............................. - 16 x
Bypass Max.................................... - 07 x
32 Byte Granularity........................... - Disable(4 Bursts)
Originally Posted by Sonic9
Na brother, this is for the Expert ONLY!
OT, but I see youve found XS Brother Esau :p: Welcome.
Originally Posted by ChaosMinionX
@ChaosMinionX whats up? Prey tell what are you doing with that ASUS board in you're rig:slapass: :D
LOVE THE AVATAR MAN.........YOU LOOK VERY DASHING!!!
For those of you that have intrest in the Merlin 10/7/06 get on it , its a :banana::banana::banana::banana::banana:en completely rock solid stable bad ass bios! Now on the other hand the last release he made on DFI-STREET was the 04/11/06 Bios which I just tried and its not stable and its based off of the 11/19/05 Expert bios which was not great at all!!! But I would recommend using this one in a heartbeat though!
Actually just Flashed back to 10/7/06 after 4 hours with his newer one.:slapass:
Yea just gotta love them dancin Bannanas....
The links to DL the BIOS do not even work anymore.
I heard good stuff about this, how does this compare to Tmod's 704-2bta BIOS? Thats what I have rigged right now, I would just like to know the differences.
You mean OCZ Tony's E704-2BT Its much better at least on my board any how!
any idea whould this work with FX-60, the information whould be very helpful.
thanks
well be it that the DL links are no good..........anyone here that has the zip file still care to share with us newer Exprt owners?
Here go to TMods site...http://www.biosmedic.com/forum/viewtopic.php?t=18 ..
He has put both of Merlins bios on the TMod CD9 just read on how to create his Bootable CD and make sure to run a MD5 HASH CHECKSUM on it and make sure that it is not corrupted THIS IS IMPORTANT!!!!:
here is a link but, as you know, use at your risk
http://rapidshare.de/files/33188488/...07.06.zip.html
Yea thats better! I myself only flash from floppy, but I searched for it today and all of the links for the Bin file were down!
