This ddr2 is so much fun to play with:) Cpu on air...
http://img163.imageshack.us/img163/4...shot0595gm.jpg
Volts? How do C3 behave, do they like volts like D9?
Nice Ram...let's see 440 @ 3-3-3-x....where'd you get the board? :p:Quote:
Originally Posted by Dumo
I know where he got it. ;)
Good results, Dumo. But you should try 3-3-3 or even 4-3-3 to see what kind of speeds you can get.
Still on air and 3-3-3 @2.2V (unmoded board)
http://img97.imageshack.us/img97/339...shot0643ds.jpg
@kiwi...I haven't try with >2.2V. Which bios can unlock VID w/out trace connect?
Only hardmod for higher vdimm
J&NCS got new 61802XXX board:)Quote:
Originally Posted by sierra_bound
I meant vcore:)Quote:
Originally Posted by kiwi
Phase...with stock vcore@1.32V:)
http://img113.imageshack.us/img113/8...shot0671eu.jpg
Ah, okay.Quote:
You'll probably want to run with RAS# to CAS# at 3. You will definitely see a difference in Pi. The better 1GB modules can do X-3-X at DDR2-800+. The cheaper stuff will run X-4-X.
who makes this ram? model? looks awsome
Very nice, lets see some Everest Latency shots
It's corsair 6400ul c3's ;)Quote:
Originally Posted by metro.cl
3D again cpu with stock vcore....
http://img113.imageshack.us/img113/8...shot0703ow.jpg
Originally Posted by s7e9h3n
Really??
I think it's Fat D9 1GBX2 Corsair 5400UL
Dumo, care to end this debate :)Quote:
Originally Posted by AndreYang
Can they do 3,2,2?
wow....It's not fat D9, but it's DDR2 900 CL=3 :up:
Very nice :D but very expensive stuff.
tCL (nanoseconds) like with BH-5 tCL2 @ DDR600 (sic!).
But SPi32 stable. :hrhr:
;) :toast:Quote:
Most 1GB DDR2 modules won't run RAS# to CAS# Delay at 2 at very high speeds. In fact many can't even do it at default speed. 3-3-3 or 4-3-2 is about the best you can hope for now. 512MB modules are a different matter.Quote:
Originally Posted by georgesod
What makes the 6400C3's exceptional is that they can run 3-3-3 at DDR2-900. Not many 2GB DDR2 kits can do that.
It is Micron based, I can give you that much. But all the fastest DDR2 out there is Micron based right now, so that's no surprise.Quote:
Vcore still @default 1.32V and mem.@2.2V...
http://img89.imageshack.us/img89/377...shot0838qp.jpg
http://img108.imageshack.us/img108/2...shot0749rm.jpg
http://img230.imageshack.us/img230/7...shot0768vg.jpg
Wow 3.55 at default vcore! Is that under a SS or your cascade?
RAM looks awesome as well!
Looks awesome Dumo, keep up the nice work.
Thanks vapb:)Quote:
Originally Posted by vapb400
Its with unmoded VapoLS...With 1.32Vcore evap. temp. won't go higher than -37.5 load (-42 idle) with fluke's reading...or -51C idle Vapo's led read.
:slobber:
That is exactly what I wanted to see. I just picked up a Chilly1 SS a little while ago, I can't wait for some Conroe action :)
I have completely fell in love with these Corsair 6400C3 sticks.
With stock voltage (2.2V) they seem to be completely stable at DDR1000 with 3-3-3-1 settings. With 2.4V they are SuperPi stable up to DDR1140 with 4-3-3-1 timings.
Simply excellent stuff.
Wanna see 440 @ 3-2-2-X? :p: I'll show you. :DQuote:
That's sick The Stilt :slobber: And this isn't D9?
wow...very impressive. too bad they are like $450 :(
It is highly binned Micron D9.Quote:
Originally Posted by krampak
It is not the "Fatbody" version, but the slimmer one ;)
some ST DDR2-1000 @ 2,5V on P5WD2 / 930@air
http://www.forumdeluxx.de/gallery/da...4-3-9_komp.jpg
http://www.forumdeluxx.de/gallery/da...69DSCN3961.jpg
and what will they do :cool:
old screenshot where bandwidth wasn´t important... actual i have no setup to play with em some further :eek:Quote:
Originally Posted by Waus-mod
maxed out on unmodded p5wd2 @ 1024 5-5-5 @ 2,3V
Yes...please show me the 2gb set that can do that :woot:Quote:
Originally Posted by freecableguy
How bout a closer look at the IC's? ;)Quote:
Originally Posted by Alonso
no, this is 2x512MB :)Quote:
Those chips are D9GKX / MT47H64M8B6-25E rev. DQuote:
http://www.micron.com/products/partd...T47H64M8B6-25E
Then I take it these are an uber screened set...
Thx...any clues to what's under these 6400's? ;)Quote:
Originally Posted by The Stilt
WHY was my post removed from this thread? :rolleyes: I was starting to wonder why I wasn't getting any notifications and couldn't imagine no one was discussing these sticks. I swing by and notice that my post was removed and apparently I was unsubscribed from this thread. What's the deal?? I would appreciate an explanation from a mod, PM or otherwise.
Now if I am allowed to continue in the thread...
Stilt, what's the tightest timings you can get at DDR2-1000 that will boot? I haven't played with the mem tweaker after boot yet, but I can't seem to get it to boot any better than 3-4-3-4 @ 1000. Your sticks look stronger than mine up top too. DDR2-1100 is about all I can bench 32M at. 1120 is "iffy" and 1140 is automatic reboot :(
Having run fatbodies for so long, I am still in awe that *2GB* can run like this on such little voltage.
The difference between you and The Stilt is that you're running a P5WD2-E, and he's running a Bad Axe. ;) Don't fret.Quote:
Originally Posted by boostedevo
Actually I am on a Premium that's been beat to hell for >1 year now. I am going to look for a 304 tomorrow. I was hoping to wait until some other Conroe boards were options, but I am definitely at the point that I can't wait any longer. I've been hold off on getting a new board for 6 months and now I am going to cave with less than 6 weeks to Conroe. Duh. Maybe I'll at least get the 100% OC on the 930 in the meantime ;)
EDIT: Stilt, I forgot to ask, do you have a bandwidth bench there? It's gotta be sick!
Up 1K with memory @ cas3 with vmem @2.2V and cpu vcore @1.465V...
http://img162.imageshack.us/img162/6...shot1099bp.jpg
http://img138.imageshack.us/img138/8...shot1054ms.jpg
