This unit was initially used for experimenting, the experiments and testing went great so I finished it off in a basic benching setup, 1 metre flexline with on/off switch.
I have to say I have had some very pleasant benching sessions with this one sofar, the suctionline reaches everywhere and its very cold. Strangely enough the 14cc Electrolux compressor is rather silent and really powerfull :D
Specs:
Compressor: Electrolux MP14FB R404a/R507a
Evap: Chilly1 rev e Captube: 2.6m 0.031
Suction flex: 1 metre 3/8 braided
Gas R402a (Mostly :D)
Controller: none
Temps:
idle: -70c
150w resistor load: -48c
185w resistor load: -44c
On my coldbugged opty 146 at 2.65Ghz 1.68v it pulls -55c and at 3Ghz 1.75v it pulls -53.5c loaded temps.
This unit laughs at high loads, not that the above loads are high but the drop from the voltage and Mhz increase is almost nothing and it pulls the 185w tester to great temps.
Im posting this unit in the for sale section later if anyone is interrested.
Pics:
Benching :D
http://emerald.srv2.com/~sokkiesc/Fo...d/Benching.JPG
http://emerald.srv2.com/~sokkiesc/Fo...losed%20up.jpg
Idle temp:
http://emerald.srv2.com/~sokkiesc/Fo...dle%20temp.jpg
Load 2650Mhz 1.68v
http://emerald.srv2.com/~sokkiesc/Fo...ded%202650.jpg
Load 2950Mhz 1.75v
http://brown.srv2.com/~sokkiesc/Foto...ded%202950.JPG
Open side:
http://brown.srv2.com/~sokkiesc/Foto...ide%20open.JPG
