P78K Vantage & Dx11 Heaven 4way SLI on Asus Rampage III Black edition
After a lots of single card benching .
I think lots people are waiting what 4way SLI Direct CUII GTX580 can do .
i totally modded 6pcs Direct CUII GTX580 .
After modding the cards .It takes a lots of times to tweak each of them .
I choosed 4 cards which can do 1500 vantage at least . :up:
4Way LN2 benching is totally different from Single card benching .
U cant pull down to -18x on every VGA pots . Also have to find the best Vcore for the cards .
Finally i find a good way to bench it . New Records are coming also .
Lots people PM me about the pots issue . I think single card u need Fat Vga Pot .
But in 4way , My VGA pots Tek9 6.66 Slim by Kingping are working well with -130~140 under loading .
U just have to torch the pot inside , and let mist condensed on surface inside . then it will let u easy to control the temp what u want .
And u also need 2~3 good PSUs to make whole system going stable under such high power consumption .
:welcome:
CPU : Intel I7 990x
Mobo : Asus Rampage III Black edition
Vga : Asus Direct CUII GTX580 4Way SLI
Psu : Antec HCP1200w X 2
Ram : Adata XPG+ 2200 2GBx3 CL8
Pot : Kingpin F1 Gemini + Tek9 Slim 6.66 GPU pot X4
OS : Windows7 64bit
http://pic.xfastest.com/nickshih/P1020036.JPG
http://pic.xfastest.com/nickshih/P1020037.JPG
Vantage P78K , GPU score is almost 90K , Maybe in my backup :shocked:
http://pic.xfastest.com/nickshih/78072.jpg
Vantage Xtreme 58K !!!
http://pic.xfastest.com/nickshih/58176.jpg
DX11 Heaven , 2500 Memory Mhz is higher enough to scale with core speed
http://pic.xfastest.com/nickshih/6079.jpg
I will bench DX11 when i have time !! :up:
Hopes NV will fix some of the 4way bugs in Futuremark DX11 .
