This is not exactly a BIOS issue or bug, please delete this post and create a new thread if you need assistance.
You should update your BIOS to
G13 (Click me!) and the options should be there for you afterwards.
Flash to BIOS G13.
Nope, that's
Vcore (CPU Voltage )
I tried everything.
Forcing a specific BIOS chip from the jumpers ( tried both BIOS 1 & BIOS 2 forced ).
Set the jumper to "software select with BIOS 1 as default", tried software select with BIOS 2 as default.
And also tried selecting the BIOS chips from the BIOS as well.
I also removed and re-seated the BIOS chips making sure the contact is good.
Still having the flashing problems.
I swapped the BIOS chips, nothing again.
Used only 1 BIOS chip ( removed the other one ).
Tried with 1 BIOS chip in both slots, nothing again ( still flashing problems ).
Tried flashing with ALT + F2 @ POST ( Enter AWDFLASH ), but it doesn't load AWDFLASH no matter what.
It gets stuck at a AHCI BIOS ROM screen.
I'm gonna try flashing with Fox LiveUpdate, but that thing doesn't seem to report if it performed a full BIOS flash or if it skipped or failed to write any blocks, etc.
Flashing with AWDFLASH 8.83 from a bootable USB drive worked flawlessly before, and I don't remember having any failed to write blocks at all.
Now it fails to write 4 blocks if I remember correctly on both BIOS chips.
I'm gonna get some screenies up in a bit.
