Originally Posted by caligula
Whoa, I seem to find a solution. Just lowered insanely the resistance of the trimmer and now I can prime at 2.7GHz, 1.55V. Temperature with 7700AlCu is pretty high, close to 60 in full load :( I ran also superpi at 2.8 but it gets hot like hell and it is unstable. Isn't vdd = vchipset? Also, what fsb termination voltage does? My memory runs upto 285 5-3-3-3 on 2.6V (TCCD) so the timings were pretty loose (8-4-4-3 for any instance). As I increase the fsb, it cracks out at 225 (!?!). Bad, bad, mobo.
lawrywild, I've followed the indications you did in your thread, flashed to 0205 but no difference, I could change vcore with latest bios, so no vcore problem. What I really find funny is that this chip does not even boot or load windows if I increase or decrease the voltage with 0.025V. Pretty tight :) 10x guys.
Later edit: I got this (see below) after flashing with p4gd1 bios (but I think it is not the case) and increasing vcore to 1.58V in BIOS. Definitely the 7700AlCu is not enough. Will the temperature be lower if I switch to Sonic Tower? Did someone test this on dothan ? Or what other cooling solution on air will be the best?
