Originally Posted by
ssideratos
I was willing to settle for this when I tried OCCT RAM mode for final stability testing. It consistently fails between 28 and 38 minutes.
I tried to give the vDimm more volts, but whenever I set vDimm at 2.10 (2.20 real) or above in the BIOS the system requires power cycle after each shutdown. 2.08 equal to 2.18 real and OCCT still fails in the same time range.
After 100's more combinations and cycles, I decided to test OCCT at stock.
OCCT still fails at stock 2.4Ghz with DDR-800 5-5-5-18. With any combination of the Ballistix.
I've even tried going back to 0505 BIOS from 0701, but my results are even worse there.
The system is consistently autovolting the NB at 1.46. Any change and there is either a failure to post or the power cycle issue comes back.
I have read every post in this forum and can elements of the issues I'm facing, however most seem to be encountering these issues at overclocks of 3.6 and above.
I am about to crawl up into the fetal position and cry :shrug: or get medieval on this board. Over two weeks of nearly full-time troubleshooting and testing tyring to achieve OCCT stability and I'm ready to trash this thing and get a Dell.
Does anyone have any ideas before I do that? Brief testing of the CPU and RAM combinations before OS installation shows it to be at least memtest stable even at 3.4 Ghz and DDR2-1150 on air (I didn't try higher than that) but the power cycle issue is there after OS installation. Could it be the motherboard again? I don't know if I can endure the pain again of another RMA, installation and testing cycle(s).
If I have to do that, I think I'll just use Prime95 stable at 3.0Ghz, DDR2-800, 4-4-4-10-25 settings for a little while until maybe a new BIOS does better for me, or if I notice any real world instability at all I'll figure out what replacement MB or Dell to get next. (OCCT isn't stable even at stock).
