Yes i have an 0550VPMW and heres a little Pic of my little 3 Gig Monster.
http://www.bilder-hosting.de/tbnl/X3EHB.jpghttp://www.bilder-hosting.de/tbnl/X3FOZ.jpg
heh Rufus, it seams that mine and yours ar almost 'brothers' - mine is 569 batch :toast:
is yours naked?
gimme...:slobber:Quote:
Originally Posted by Rufus7
wooow that the ccb1e 0550 vpmw from ebay?Quote:
Originally Posted by no_n|ck
OMG 3ghz with 1.45v in BIOS? insane, I want one now! :D
There are 0550VPMW with 1,375Vc going the 3 Gig without HS.
My is too warm for that Low Vcore.
not egay .. from trend4pc.de .. priming at 3050mhz right now @1.5V, passed 15min ..Quote:
Mine is dual prime stable 24hrs with 1.375v at 2800mhz. I have to agree these things run about 7 degrees warmer than my other chips! I'm currently researching a better cooling method
nice one you have there! Could you tell me what board/mem you have?Quote:
Could i get everybody's 0550VPMW batch #? The one i'm going to get will be 0147 batch.
Asus A8N32Sli, OCZ 2GB EB DDR 500
thank you and also dino22Quote:
The 1387678L505xx are know as the best batchers .. but i found out that almost every vpmw is doing 3ghz, some needs 1.375V (5xx batch) and others ~1.55V ..Quote:
Checkout this forum if you would like to see how acts different batches --> http://www.forumdeluxx.de/forum/show...=203634&page=1
Its in german, but just look on the numbers, steppings and batches :toast:
170 CCBWE 0534SPMW (1.632v cpu-z), Swiftech "Storm" Apex kit, IHS removed
9x315 = 2836 MHz, dual prime at approx 12hours 20mins
http://img377.imageshack.us/img377/9...ours6of.th.gif
9x317 = 2854 MHz, spi32m @ 2854mhz
http://img137.imageshack.us/img137/5...4mhz7zj.th.gif
Very nice overclocks guys?
Anyone managed to do a *Quad* Prime session yet? thats two primes on each core?
I'm doing dual priming on a mono-core Opteron, so if you wanna check that your rig is *uber* stable give it a whirl.
Overclockers Guide to the Galaxy
Chapter 2 - Section 5
"A *Godly* system should be impervious to any kind of hardware failure bought about by extreme and consistant processing load. Any such failure would deem the systems builder as a failure and somewhat of a dimwit:slapass:.
Stability is to be maintained above all else, with sheers processing power following a close second
These 0550VPMW-s are amazing, just got one.:) Does 2,8ghz 1,375v with watercooling but can´t get 3ghz. I can bench 3ghz 1,475v but prime instantly fails, even with 1,625v, seems to get too hot.:confused:
Show us please! :fact:Quote:
Originally Posted by Evil
Yeah,Quote:
With air I don't think I'm going to push more than 1.45v. That brings me to just below my 50C. It looks like I might be able to get away with just that bit of voltage for my 2900mhz to be stable. I think I could hit 3ghz with some better cooling. I'm trying to find a water cooling setup for less than 150 dollars!
Mine is doing great so far; 3GHz @ 1.48V
http://img52.imageshack.us/img52/296...8v2h8ht.th.jpg
Very nice! :clap:Quote:
Give us a longer prime stability shot when u have time.
Btw I want that Windows skin? Can you post me a link pls so I can find out more about it?
Looks good, throw in a SG or MBM5 in your ss when under load please.:) What's your room temp?Quote:
where can I buy a 0550VPMW?
Originally Posted by Grinch
i have a retail box batch 561 brand new, sealed.
I was going to dump my batch 400 and give it a shot, but i am happy.
Imma put it up on eBay tomorrow. Just check there.
Originally Posted by cdelatte
I very much agree! I had to mount a panaflo 120mm 114CFM fan onto my big typhoon. Fixed the problem :)
Still runs hotter though.
Removed IHS + WC :toast:
