Well just for you I took the Zally back off and grabbed a pic :toast:Quote:
Originally Posted by NiSMo
http://www.xtremesystems.org/forums/...id=39555&stc=1
You'd think as many times as I've done this I would have grabbed a pic first.. :slapass:
the pic aint working cos i cant see it :P :stick: heheQuote:
Originally Posted by $SOLID$ Necro
Give a Brutha few minutes to edit... :p:Quote:
I noticed it too, and had to go back to the original pic and start over :shrug:
So is it any good?
50Mhz more for OCCT doesn't come easy.
At 1.4V it passed OCCT at 3050MHz, for 3100MHz it needed 1.52V.
http://img.photobucket.com/albums/v6...CT3100MHz1.jpg
Gonna try for 3150MHz now. :)
@Zeus a very nice OC there :) is that a CABNE chip?
Would a 146 CABYE 540 PAW be better over a 144 CABNE 0540, apart from CPU multi?
Are the newer optys coming in the old retail box where you can see the chip through a little window or in the box that monarch shows on their site?
i pulled IHS off my opteron, but my idle and load temps are much higher? i checked 3 times , my WC plock is nicely on ... any help?
check to see if the bottom of your block is resting against the high side of the plastic socket
my #0289 on Water:Quote:
Originally Posted by sumang007
http://i4mark.teknetixx.com/Opteron_...M%2026_266.jpg
rofl. u are genius, i was, i turned plock as it should be, but full load is still like 50*c on stock clocks... maybe i just need to but IHS On, ther is now just AS5 between cpu and IHSQuote:
Originally Posted by T_M
Originally Posted by Pt1t
Nice chip mate! :up:
I tried 3150MHz at 1.6V but couldn't get it to finish OCCT, our CPU's are pretty much the same as far as overclocking goes, mine's a CABNE 0530 APMW with heatspreader still on, what's yours?
Also, temperatures are about the same, can you do 3150MHz OCCT?
The old style box, not the plastic retail pack that they show on the site.Quote:
Originally Posted by TheMeatFrog
My is cabye 0540 FMBW, his is still on alsoQuote:
Originally Posted by Zeus
http://valid.x86-secret.com/cache/48318.png
With 1.69v :toast:
Finaly, i buted IHS back, added some AS5 and my load temp are 5-7*c lower than with stock paste under cpu and IHS :slobber: going to ceck max OC with usal water, soon i will try some iced water
The brother of this chip can finish OCCT at 3.2 GHz :DQuote:
http://home.scarlet.be/~pascpiet/DV/...W_MS@1.58V.png
Edit : (Cause PM), I have'nt this step for sale, sorry !
heya, randomly messing with ma memory which i had runnin at 207mhz on divider before... just tried to get it up a bit before i change mobo... see what loose timings, higher bandwith and freq VS tight timings at closer to 200 would do... as you can imagine, not much at all except give varied millisecond times in super pi and higher sandra bandwith
http://revo21.com/pc/2.9_166div_32m.jpg
Guys quick question...
Which of these is faster for games and benching...
3Ghz (10*300) running 1:1 with TCCD @ 2.5-4-4-7...
or...
3Ghz running a divider (140mhz or whatever) for a total of around 230mhz HTT @ 2-2-2-5...
Is it the divider with tight timings?
Saw that a couple of pages back, very very impressive! :slobber:Quote:
Originally Posted by computersmsa
What kind of watercooling is that?
What the maxTcase on that chip?
Mine 's 67C.
In case you're going to sell it's sister lemme know. :D
Try them both out on spi and see. It's going to be close, can't run 2.5-4-3? That would be faster.Quote:
Originally Posted by Richdog
The divider doesn't matter, only timings.
I havent got any RAM capable of 300HTT 1:1... but my friend is getting 2x sets of Gskill FX sent over from the USA and if he decided he doesn't want a pair he will sell themk to me.
At the moment I have OCZ PC3200, the new BH-5 stuff, so I want to know if it's worth selling them and getting the TCCD... or if it will make no difference in performance in which case i'll pass. :)
http://sponge.ez.pri.ee/data/media/3/27.266.JPG I know , it sucks... cabye 0536 IHS on...
now heres mine: Opteron 146 CABYE 0540FPMW 2.9Ghz stable (290x10). ram @ 9/10, 2.5,3,3,6 1t.
Finally after long long weekend prime95, superPi, memtest stable and decent temps as well.
phil
http://homepage.ntlworld.com/philyau/benches3.jpg
My CABNE 0530APMW finally gets its chance to go under the Prommie after my 144 came up short because the DFI mobo won't give me more than 374HTT. Its off to a good start doing what my CABYE 0528GPMW couldn't do. 3.5ghz only 1M stable now but good enough to do some 3-D which makes it my champ. I'm thinking I'll keep this one. ;)
Just some cheap UTT at crappy timings and not tweaked.
http://img328.imageshack.us/img328/4...x10sp1m6zj.png
Nice work there, thats a killer chip for sure. What do you think of the Koolance Exos?
