Sunin, is your computer standing or lying (that is, can the chip/mobo carry the weight of the 9500 vertically)?
Mine is vertical and yes it has no problems holding the weight... it really is more a function of getting it to clamp down sufficiently! I ended up using 2 washer on the post that the clip normally feeds onto and tying the bars to the top of the existing 478 bridge. I have photo's here: http://www.xtremesystems.org/forums/...postcount=1671 I since have moved the bars from upside down to clamping ontop of the holes and using 16gauge wire to secure.Quote:
Originally Posted by malkekoen
its -30C here in Estonia so i tried some oc with aircooled dothan and watercooled X700PRO... so what happened? it was a big mess:slapass:
i got rig as written on my sig..
cpu aircooled with freezer 4 and vga watercooled with home made stuff and vodka
so what happened:
VGA temp @ idle = -15C
VGA temp @ load = -2C
pretty good, i used 40 degrees vodka in watercooling and it phuking freezed
when i used fans to cool the radiator so temp was under -40C:D
so i didnt use fans and got those temps on vga as i mentioned before(-2/-15C)
for cpu i used AC Freezer 4 with Thermaltake 12 fan @ 5.5k rpm
all was good, cpu temp went down to 7C and then it started to rise..
it rose to 120C cos phucking Freezer 4 heatpipes were frozen:eek: :banana:
so i dont recommend coolers with heatpipes for low temps...
mobos temp was -7C and it ran just fine..
damn that Freezer 4:nono: :(
lol, never heard of heatpipes freezing before.
häppens :banana:
i also thought ill test my rig in this freezeing cold (about -25 in tallinn). hard luck cause i also have heatpiped cooler :)
:Dbut it was like that:DQuote:
Originally Posted by skane
gonna try tomorrow with CT479 inbox :p:
estonia is clockland :D
does ur 780 an ES or not ?
its not an ESQuote:
Originally Posted by skirms_fr
Hey guys, will this Pentium M work with the adapter (1.5GHz/400/1M)?
If so, it is really well priced right now...$45.00, plus shipping from mWave for a new retail product.
http://www.mwave.com/mwave/viewspec....iteria=BA03116
It will work but it's neither a good overclocker nor a very fast chip.Quote:
Originally Posted by Reefa_Madness
adapter is for s479
a new small clock for me
100% unstable :D
http://112233445566.free.fr/PM740/3500.jpg
Ok, thanks for the info. :)Quote:
Originally Posted by wwwww
Anyone know why would my system shut off right after I press the power button?
I have tried it with many different BIOSes, but still I get the same thing
Pm 750+ct-479+p4p800-e deluxe
no post whatsoever, it just shuts off a second after I power on the system
Have you flashed the board to the 1006 bios with a P4 cpu first?
of course,Quote:
Originally Posted by Movieman
well not the 1006 bios, but I have tried the p4p800-se bios 1011 (I am on it right now)
as well as the latest p4p800-e deluxe
I am using the board + my 2.4c to type this out now, so I dont think the board is a problem
also, if I take out the 4 pin ATX connector which goes into the motherboard, it does not shut off immediately
I just get a black screen with no beeps/no post
but as soon as I plug the 4 pin atx back in the motherboard, the system shuts off
the 1006 doesnt support dothan, only bioses 1007 and later do.
Did You noticed that Performance on i875 with 2x512MB is uch better than 2x256 ??
10x230 2225 I saw 20s differences in Super Pi 16M
This is because of bank-interleaving. In small calculations like 1m the memory bandwidth isn't so important because much of the data fit's in the L2 cache. During bigger calculations bank interleaving is much more relevant as it increases memory bandwidth and much memory is needed to it the data during the calculation. This is also why K8 cpu's are clock for clock slower in 1m than Dothans but faster in 8m+.Quote:
Originally Posted by yotomeczek
Originally Posted by alexio
well,
so I need advice what 2x512 will clock well on i875 in dual :D
My Geil One W didn't
on A64/i915 258MHz but with i875 only 230 :/
This is also why my 4x512 6-3-3-2@240 no pat was faster than 2x512@240 and pat.Quote:
Hi guys,
I got a P-M 750 (1.86GHz, multi 14x) - it is in a laptop for now - but it does prime95 stable at 1.05V (downvolted from 1.308V). How high do you think that it will go with a CT479, and what would be the maximum reccomended votage for 24/7 ? 10x
http://112233445566.free.fr/PM740/3588.jpg
hop :D
3588 synchro 5222
will try with coef 12 and desynchro
Awesome skirms that on cascade?
Also what jumpers is everyone using on the ct-479 just been told setting it to 400 is better
is it 2x256MB ??Quote:
