here`s my case ...
http://img293.imageshack.us/img293/2558/dscf0017mh4.jpg
here`s my case ...
woww~ nice TEkNØ :D
later I will go to buy one block for chipset of dfi
some user ai it has koolance for mem??
I'm intending to start posting here a bit more often, I thought I might as well start by showing off a bit :D
My first crack at a dual loop system (all internal in a pc65b :D)
http://i20.photobucket.com/albums/b2...r/DSC00079.jpg
my old chilly1/water cooled sli system..
http://i20.photobucket.com/albums/b2...r/DSC00454.jpg
A micro atx system, all 1/2" ID, chipset, cpu and gfx cooled almost fully internal.
http://i20.photobucket.com/albums/b2...r/DSC00235.jpg
my watercooled sn25p shuttle, again all internal, again 1/2" and again nb/cpu and gfx cooled :D
http://i20.photobucket.com/albums/b2...r/DSC01249.jpg
And finally, I missed my dual loop system so much I've gone back to it.. 2 loops, fully internal, 1/2" ID, loop 1 pa120.1, EK s775 block, ddc pump. Loop 2 pa120.1, EK 7950gx2 block, ddc pump and 2 thermotubes on the roof!
http://i20.photobucket.com/albums/b2..._/DSC02424.jpg
More pics of all available if anyone wants them!
matt 100, that prometeia case is veryveryvery nice :D
and joebar, your case is nice and clean man...
Ferrari_Freak...Larger tubes don´t mean better performnce,this is not theory i proved myself,with the same hardware,changed the pump,cpu block and tubing and the temperatures remain the same.Ok larger tube has is beauty ,but "Bigger is better" doesn't aplly here (germans now what they do).:stick: ;More update...zalman Nb cooler.Quote:
Originally Posted by ferrari_freak
http://img404.imageshack.us/img404/2...18largeab6.jpg
http://img404.imageshack.us/img404/7...25largexf6.jpg
Originally Posted by IanY
Originally Posted by Patriote
Originally Posted by Solarfall
Originally Posted by alejo
:toast:Quote:
Originally Posted by logan
Most of my cooling parts are made in Italy: waterblocks by Lunasio Cooling and reservoir by Ybris Cooling.
The second one is called Crystal Trap and it works both as air trap and little res.
Excellent work as always Matt, an ambassador to the watercooling world for the UK :).Quote:
Originally Posted by matt100
Loving the red colours thats for sure
Here's my humble setup after stepping into the world of Conroe....
http://pachome2.pacific.net.sg/~hinstan/case.jpg
http://pachome2.pacific.net.sg/~hinstan/internals.jpg
http://pachome2.pacific.net.sg/~hinstan/waterblk.jpg
http://pachome2.pacific.net.sg/~hinstan/pump.jpg
that is one tiiiiight turn coming from your block, yay for zip ties! :D I always like internal loops, nice and clean :)
Thanks. There's a problem that I was hoping I could find help here though...you see, the placement of the radiator blocks about 1/3 of the intake to the PSU. I'm not sure if its due to this blockage or the proximity of the radiator to the PSU that's causing the PSU to heat up quite a bit under full load. When idling its fine though...Have thought of drilling a hole on the top and mounting the radiator there but that might rob the radiator of even more cool air.
Heres my setup. Temporarily running on a TT TR2-430w PSU. My new Enermax Liberty 500w is on its way!
http://upload.nickfire.com//files/1/DSCF2648_thumb.jpg
Lo0L! Lots of comps there Guys! I see some well build in there!
That's a nice system NickS. I just bought that same case and I'm looking to do something similar. Do you have more shots?
I'll take some more when I get the new PSU man :). In a few days.
Nick I like the case but you cut it (which was fine) but you added on something external!!! :mad:Quote:
Originally Posted by NickS
Hehe, thats temporary man. My regular PSU wasn't enough anymore so I'm using that one for now. My new Enermax Liberty is on it's way here. That will be internal. ;)
good to hear man, or this may happen to it. here's my hoover...eh i mean psu :DQuote:
http://img174.imageshack.us/img174/3...0148sf6.th.jpg
How do you guys like mine :D
not bad for my first setup right :woot:
This was lapped while still in the loop :banana: Not to shabby
http://img176.imageshack.us/img176/306/1001915wu2.jpg
This is just a pic of my 7950 to show how I had to bend the ramsinks
http://img294.imageshack.us/img294/295/1001917pe5.jpg
http://img244.imageshack.us/img244/6578/1001918xb8.jpg
http://img19.imageshack.us/img19/8396/1001919uz1.jpg
And Finally
http://img165.imageshack.us/img165/1389/1001921nw4.jpg
you lapped your gpu blog while it was still in the loop, you are my hero :bows: but seriously nice looking setup you have there. those YSTech 135cfm Fans must be louder that hell.
lol, I get that " OMG YOU LAPPED IT WHILE IT WAS IN THE LOOP" thing alot :D
It just took alot of patience and steady hands
Looks nice man :)
Good lapping job too.
does anyone except me don't see a majority of pictures, like just few of them load, the rest are like they don't exist, there isn't even that small red cross which indicates that the picture failed to load... :confused:
btw. NickS what's that cooling your RAM? seems like a big HS?
OCZ XTC RAM Fan :)
Sweet setup man. I'm looking into the newer version of that case. How's the mounting system? Did u take out the rear case fans because of some problem, if so i'll do the same?Quote:
Originally Posted by umop ap!sdn
