yep,if it works and is convenient then im all for it:D
whats the best bios for the E760 when running elpida hyper MGH-E's?
from what i can tell from reading the thread s61j seems to be the best?
I use one of those orange TT fans on my nb, very loud but an awesome spot cooler.
If you got the board used was it tested for max bclk? From what it sounds like it does the same thing my rex3 does, at 215bclk or higher it is very flaky. Also sounded like you were in slowmode but you have qpi freq set to fast. Try running some 3D, like 06 and see how it does. I lost performance at 215bclk on the r3e.
i thought i almost had it figured out.i was able to run normally with the vtt/cpu pwm at stock
byt running x17 uncore.at x16 is when the issues showed themselves.but im still experiencing
strange issues with consistency.after failed OC i clear cmos and get a screen saying this
and it just hangs until i turn it off and clear cmos again.hitting delete does nothing with this screen?
also i get sometimes the normal first boot screen but where it says memory testing the numbers go carzy (i guess its testing memory)but it never stops
until i reboot?
http://i53.tinypic.com/1h2pl2.jpg
I get that screen also after a bad failed oc, or similar. Mine says no keyboard detected.....press F1 to continue lol, Del to enter setup. I hit reset button a couple times and that doesnt fix it I clear cmos. It doesnt recover as well as the Gigabyte, but I really like this board a lot.
i see a lot of people setting the CPU PLL VCore and IOH PLL VCore @ 1.5 , i keep it @ auto which is 1.8 IIRC is that ok or should i lower it to 1.5 ?
my setup : E760 Classified - 980x - 6gb Dominator GT 1866c7
1.8V is default so yes, it's ok. Sometimes lower value gives you small gain but nothing special. It's more important to lower it when you go with subzero (read LN2), but if it works the same on air with 1,8 and 1,6.. why not? :)
i found my problem and it seems to be the opposite to mafio's MB
i can now run with vtt and cpu PWM at stock with both my i7-920's
but i need these to be set to less for anything above 200bclk
CPU impedance - less
QPI signal comp -less
im 100% stable at 21x 215@4505 and absolutely no weird issues i was experiencing.
but if i reboot and set these to auto it starts up.
Nice work radaja, glad you figured it out.
Got it to boot at 4920mhz 4cores 4threads, better than my ud7 did.
http://img830.imageshack.us/img830/2811/e7704900.png
Uploaded with ImageShack.us
nice OC OC Nub:up:
do you run with vdroop or without?
without is LLC enabled correct?
at lower voltages with out is similar to level 1 LLC
on my gigabyte MB but once i go above 1.43v the drop
in load vcore is huge.but i dont like how with is like level 2
slightly higher than whats in bios during idle and load?
Thanks radaja.
I have been running it with vdroop, I dont like the way it over volts either when using without. Would be nice to have 50% or LLC1, maybe EVGA can call "kinda without" lol.
We have Classified3! My Classified(1 or 2? :P ) is going back to EVGA for RMA. :D
So, that CPU and QPI Signal set to less really helps on the BCLK wall?
could help, but it's not sure...maybe your mobo like less, maybe not.
mine with both auto boot at 245 BCLK, with less no boot over 180 BLCK.
but maybe that's another problem of my second crappified.... :rofl:
kup,could you fill in the template for 225 bclk for me so i can compare
other templates and see if i can figure out how to go above 217bclk.thanks
Code:Frequency Control
CPU Clock Ratio ( 21X )
CPU Host Frequency (Mhz) ( 225 )
MCH Strap ( Auto )
CPU Uncore Frequency (Mhz) ( MHz(x16) )
Spread Spectrum ( Disabled )
PCIE Frequency (Mhz) ( 100 )
Memory Feature
Memory Control Setting (Enabled )
Memory Frequency ( 2:8 )
Channel Interleave Setting ( 6 Way )
Rank Interleave Setting ( 4 Way )
Memory Low Gap ( Auto )
tCL Setting ( 8 )
tRCD Setting ( 8 )
tRP Setting ( 8 )
tRAS Setting ( 24 )
tRFC Setting ( 74 )
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( With VDroop )
CPU VCore ( )
CPU VTT Voltage ( )
CPU PLL VCore ( )
IOH PLL VCore ( )
QPI PLL VCore ( )
DIMM Voltage ( )
DIMM DQ Vref ( +0 )
IOH VCore ( )
IOH/ICH I/O ( )
ICH VCore ( )
VTT PWM Frequency ( 250 )
CPU PWM Frequency ( 800 )
CPU impedance - ( )
QPI signal comp ( )
CPU Feature
Intel SpeedStep ( Disabled )
Turbo Mode Function ( Enabled )
CxE Function ( Disabled )
Execute Disable Bit ( Disabled )
Virtualization Technology ( Disabled )
Intel HT Technology ( Enabled )
Active Processor Cores ( All )
QPI Control Settings ( Enabled )
QPI Link Fast Mode ( Enabled )
QPI Frequency Selection ( 4.800 GT/s)
Trying WPrime 8 threads, cant seem to get over 4800mhz. this was my best so far.
Hope that helps ya dude. My VTT and a couple of voltage can happily be lowered but I've not got round to testing fully yet.Code:Frequency Control
CPU Clock Ratio ( 19X )
MCH Strap ( 1067 )
CPU Uncore Frequency (Mhz) (3200MHz) (or whatever would be 3200 @ 200 bclk)
PCIE Frequency (Mhz) ( 101 )
Memory Feature
tCL Setting ( 7 )
tRCD Setting ( 7 )
tRP Setting ( 7 )
tRAS Setting ( 20 )
tRFC Setting ( 60 )
Command Rate ( 1T )
Voltage Control
EVGA VDroop Control ( Without VDroop )
CPU VCore (1.37500) (far to high for my clocks but just for testing)
CPU VTT Voltage (+225) (can go lower)
CPU PLL VCore (1.8)
IOH PLL VCore (1.8)
QPI PLL VCore (1.2)
DIMM Voltage (1.65)
DIMM DQ Vref ( +0 )
IOH VCore (1.2)
IOH/ICH I/O (1.6)
ICH VCore (1.2)
CPU impedance - (less)
QPI signal comp (less)
CPU Feature
Virtualization Technology ( Enabled ) (Doesn't seem to make a difference, personal preference for my Virtual Machines)
thank you much kup:up:
just to be sure,you only need 101 pci-e?and IOH/ICH I/O (1.6) is 1.60v? or 1.16?
going to give it a go and see if i can figure this out:D
http://i54.tinypic.com/35244es.jpg
Like that. :) And yeah, only 101MHz PCIE so far. :)
I will have to try it again, I am bad about saving settings so Im not sure what everything was set to. I know I had CPU Impedance and QPI signal set to less and went up a notch on both VTT pwm and CPU pwm Freq. Vcore and VTT were pretty high but the exact value Im not sure.
