i just poped in a q9650 and its drivin me nuts
it dont like a 4 gig set no more lol
how bad is this?
radaja dont tell me about the ud3p i rather cut my pecker off than buy 1:p:
how bad is this?
wouldnt even think about it?i know how you feel about gigabut:D
but still your off to a good start there.im sure you will get it up to 500fsb soon:up:
RE is no good with a quad above bus 475 but Giga..., o no, sorry :D just kidding.
Seriously, RE is no good with a quad above bus 475, to much voltage is needed but if you donīt mind just turn on the juice on that PLL, FSB and a lot on the NB, donīt forget to tune those GTL Ref.
Hereīs a Q9650 @ 500, 4,0GHz with 4x1 Dominator 1800C7 @ 1600 777 21 Strong tRD 8
http://i282.photobucket.com/albums/k...8StrongStr.jpg
if i dont make 500fsb the cpu is history:rofl:
man a quad is not fun like a e8600
only reason i got to 475 was +60 on gtls and man this cpu is a vtt whore
i didnt push cpu pll i know i degraded my e6850 @ 1.7
i'm gonna push nb to 1.75
i'm just glad i changed all the sinks the board woulda been on fire:rofl:
nb hit 42c pwm 45c sb 44c
any hope to clock 2x2?
yea i know the feeling,when i had my Q9650,it was fun but then the limiting fsb factored in.Quote:
mainly because i wanted to do some high fsb memory clocking.
Hereīs some 3Dmark result that I did run with my Asus Rampage Extreme / Q9650 / 2x1 Corsair Dominator PC-14400 1800C7 / EVGA GTX 285 FTW
@ various speed, bus 505 - 510, CPU speed 4,545 - 4,590GHz and ram @ 2020 - 2040 888 24 Strong tRD 8
Itīs pretty awesome I most say, consider that it was made with a quad, I did try the same with my EP45-UD3P and Rampage Formula but they couldnīt touch the Rampage Extreme.
http://i282.photobucket.com/albums/k...me/0368286.jpg
http://i282.photobucket.com/albums/k...me/0529017.jpg
http://i282.photobucket.com/albums/k...me/0624018.jpg
http://i282.photobucket.com/albums/k.../VanP14901.jpg
These hot days really annoying me alot. :wth: I do not setup my watercooling yet why there are some parts which I need take them for it first. Because of that I using my stock cooling todays. :( I'll purchase my NB+SB combo waterblock soon and I'll give you some results here. :up: When I oc'ed the system, my NB temps messing up well thats why I do not do anything about oc now. I saw the 56C on it man, thats really sad to me. :eek:
PS: Please anyone share the 3dmarks06 scores here.
Cheers,
Arthur
Hell yea man, you are right about that. Plus I only have my E8600's stock fan here. :( By the way, you can check my some results on page 97, I could take them with my bloddy stock fan LOL. I just do not want to increase my temps more with my RE for a while.
I purchased some fittings to my Thermochills today. I'll purchase my chipset block when my fittings arrived in my hand soon. :up:
Thanks again,
Arthur
i bumped sb to 1.6v n 1.11v:eek:
next step is to use 2x2 stix
dont u guys like the power of a/c
I Love It!!!!:DQuote:
New motherboard returned and I'm up and running. Trying to find stability again is such a pain with this board but I'm testing each module individually to make sure they are working correctly before I proceed with overclocking. I contemplated selling off the processor and board - jumping into the i7 area but it's just not worth it in my opinion.
I noticed that the board came with bios 1201 and it seems ok. Anyone have an opinion on this bios or should I flash back to 1104?
Just flashed and will play with 1202. I removed 2 of the 4 mushkin 996625 module. I forgot my original parmeters but am having difficulty hitting my 440 fsb mark.
Heres a clocking settings thus far:
FSB 400
CPU RATIO 9
CPU SKEW AUTO
NB SKEW AUTO
PCIE 100
DRAM FREQ 1601
7,7,6,20,4,88,12,6
10,5,6,4,6,4,6
21,8,1,9,9
DRAM STATIC DIS
DRAM DYN DIS
AI CLOCK LIGHTER
COMMON PERFORMANCE 8
CPU V 1.45625
LLC EN
CPU PLL V 1.56406
FSB TERM V 1.35191
GTL0 - AUTO
GT1 - -40
GT2- AUTO
GT3- -40
NB 1.60372
DRAM 1.90831
NB DDRVref 12.5
DDR3 12.5
SOUTH 1.51106
SOUTH 1.06
BIOS 1202
Try the settings in this thread. http://i4memory.com/f54/asus-rampage...tml#post119013 Bios 1202 requires lower voltage settings for the NB.CPU PLL. FSB Term.
Wow, 1202 bios is amazing. My NB, vtt volts are much less ( 1.42 ) than my previous settings and are running perfectly. The setting that was actually causing the most headaches was the AI CLOCK and COMMON PERFORMANCE. Setting them to Lighter and 8 worked, anything lower caused problems.
Completely stable at 480 x 8.5 1:1 1601.
Thanks folks and thanks to MushkinSean.
:up:
PS. I can pass Prime95 for 24 hours but OCCT just crashes the system to blue screen. Personally think that OCCT is not a reliable program. Thoughts?
That bios is good for raid0 abductor not to have problem?ŋ my Hw is : E8600 , rampage extreme bios 501 , 2x2 g skill trident 1600mhz , raptor 74gb 16buffer x2 , 850w Modular TT Toughpower, 4850 saphire 512
Hello, guys. Have somebody tried 4GB G.Skill DDR3 PC3-16000 2000MHz Trident with Rampage Extreme? Or any PC3 16000 modules?
I'm now with G.Skill 4GB 1600MHz, but I need 8GB... The Q9550 is at 4.1GHz and I'm wondering, will I reach at least 4GHz with 8GB memory. Can I?
1202 is grate i managed to lower cpu, NB, vtt voltages.
EDITED
OMG also the FSB v.
Purchased 2 sets of 2000 ripjaws and tossed them in. I've never been able to get my 4 X 2 1600C7 (microns) to work stable in this board. Finally I had one set of the 1600C7 and one set of 1333C9 and clocked the 6gb to 1450MHz and gave it to my son. He's had it running for about a year this way. Well, I took the memory out, popped these ripjaws in and changed to the next speed, ie. 1450 --> 1828Mhz. Solidly stable, even in gaming!!!
http://i259.photobucket.com/albums/h...008/System.jpg
http://i259.photobucket.com/albums/h.../Memtest-1.jpg
I haven't even begun to really play with them. They just were stable. Go figure. :)
Cost = $97.00 X 2 for 8GB!
